DR350 Thread
Discussion in 'Thumpers' started by leonphelps, May 16, 2007.
  1. Jeff@TheQuadShop
    Jeff@TheQuadShop TAT survivor
    Nov 28, 2004
    8,045
    Crestwood, Kentucky
    Rare and expensive are two different things.
    MrPulldown likes this.
  2. plugeye
    plugeye MC rescue
    May 11, 2007
    7,236
    Garland, Texas USA
    pm sent
    $500 shipped conus
  3. mentolio
    mentolio King of the island of unwanted toys...
    Jul 14, 2016
    1,429
    Small battery, small starter. Sure it might work and work well when conditions are ideal. Knock that bike over in the mud, in the cold, flood it, and battery not in perfect shape with NO decompression…I think that combination is just increasing the chances of being disappointed and stranded. Risk vs. reward = unnecessary imbalance.
    rockt likes this.
  4. 603MTBRider
    603MTBRider Adventurer Supporter
    Feb 14, 2020
    13
    SW New Hampshire
    Anyone know if there is an alternate chain guard that would fit a 1998, need it for inspection in my state but can't seem to find one for a reasonable price. Assuming making one with sheet steel for the inspection is probably easier. Any help would be appreciated, Photo to get your attention love this thing.
    mtn.moto.adv likes this.
  5. slartidbartfast
    slartidbartfast Life is for good friends and great adventures Supporter
    Dec 23, 2003
    13,706
    Southern Louisiana or Southern England or ...
    They actually check that stuff?
    In Louisiana, if they look at your bike AT ALL (which they frequently don't) functioning headlamp and (maybe) horn will get you through the inspection.
  6. 603MTBRider
    Feb 14, 2020
    13
    SW New Hampshire
    I've just been riding it around un-inspected, but registered which is fairly common. Trying to go full legit but don't want to have to make multiple trips to an inspection station.
  7. MrPulldown
    MrPulldown Long timer
    Aug 18, 2009
    9,176
    Truckee
    Your in luck. Ramman is selling one for $10
    For sale - DR650 and DR350 Parts | Adventure Rider (advrider.com)
  8. 603MTBRider
    Feb 14, 2020
    13
    SW New Hampshire
  9. History
    History Adventurer
    Jul 10, 2021
    10
    NC
    Guys I'm still reading from the beginning and see that running the engine low on oil can destroy the cam bearing surface pretty quick. I'm only on page 400ish so I haven't seen this asked yet or mentioned, can insert bearings be place in the head for the cam saving an otherwise useless head?
  10. MrPulldown
    Aug 18, 2009
    9,176
    Truckee
    Bearing insert isn't a typical fix. Custom machining/engineering would be costly.
    I'd be more inclined to just buff out the cam journals and run it till it blows. I am sure half the Dr's out there have have pretty rough journals.
  11. Trixie
    Trixie Adventurer in my own mind
    Jul 19, 2001
    5,877
    Stuck between Massholes and Syrup heads
    Somewhere in this thread, (or maybe on maximum suzuki?) a machinist wizard did an oiled bronze cam bearing replacement . It was a rather complex process. I doubt the photos are still up, but hopefully you'll come across the post as you read through.
  12. Dirt4life
    Dirt4life n00b
    May 10, 2013
    3
  13. mentolio
    Jul 14, 2016
    1,429
    I just sent them an email to find out if they service/are willing to service Suzuki. I’ll post here if they reply.
    I remember hearing that there were shops that did this kind of repair on the west coast. Basically weld-up some meat on the journals, resurface, and line-bore the weld to factor spec? Haven’t seen this service advertised in decades…maybe there’s a reason? It would be super-sweet if someone started offering this type of repair. I’m tired of passing on “affordable” heads that clearly have journal issues on eBay. I’m cheap, but I’d gladly pay a few hunnert if I knew my journals would be properly aligned and have a like new surface.
  14. History
    History Adventurer
    Jul 10, 2021
    10
    NC
    I know they are doing inserts in Ford model A engines to replace the "Babbitt" bearings so surely someone could do this to the DR's head at an affordable price. Mine is good but just in case.
  15. Ibraz
    Ibraz Been here awhile
    Feb 11, 2017
    608
    Québec
    There’s a big engine shop in Quebec that does just that.
    They overhaul so many atv/marine/bike/sled engines that they have engines ready to ship in exchange of blown ones.
    You ship the worn head with new parts (cam, valve seals, valves, (rockers?)) and they weld/machine/assemble the thing.
    Their work is supposed to be quote: « OEM quality or superior »
    Last DR350 quote I heard is 400CAD + parts + shipping.
    Google Cvtech AAB.
    Fishnbiker and MrPulldown like this.
  16. mentolio
    Jul 14, 2016
    1,429
    Huh, will do. Thanks for the suggestion!
  17. rockt
    rockt Long timer
    Oct 13, 2003
    3,231
    Canada
    I had a 2-stroke crank (RD400) rebuilt by Cvtech and it was perfectly done, like a brand new crank. I just checked and they have a U.S. shop in Franklin, WI.
    MrPulldown and Ibraz like this.
  18. mentolio
    Jul 14, 2016
    1,429
    Just heard back from “Engine dynamics.” They regret to inform me that while they DO repair aluminum cylinder heads, the DR series of heads are not included.
  19. mas335
    mas335 xendurist
    Jun 17, 2006
    2,740
    Advance, NC
    Is anyone running a 80/20 rear tire? I'm working on a set of wheels that will be for road use, probably 90% of the time. I am having trouble deciding what size tire to run on the rear. I have been very pleased with Shinko 705 tires but they only offer a 120-80 and a 4.10 tire. The 120/80 seems way to big, don't want it to look like a Harley. The 4.10 seems a bit narrow to me. The only 110/100 I have found is made by Fullbore, I have no experience with them regarding quality or ease of mounting on a rim, etc. So tell me what you are running and if you are happy with the tire size and performance on pavement. I like my Kenda 270's but I want something with better grip for faster twisty paved roads.
    Jeff@TheQuadShop likes this.
  20. slartidbartfast
    Dec 23, 2003
    13,706
    Shinko 705 is a 90/10 at best - but they are great street tires - Quiet, stick ok in all weathers, wear well, great price. I have run several of the cheap 50/50's without any real issues but I was never excited about them off-road. My DR is currently on D-606,s which are close to being street legal knobbys IMO. I'd call them 30/70s. They wear well and handle surprisingly well but OMG they are LOUD on the street.
