DR350 Thread
Discussion in 'Thumpers' started by leonphelps, May 16, 2007.
  1. MrPulldown
    MrPulldown Long timer
    Aug 18, 2009
    9,176
    Truckee
    That is how I usually do it. Getting a knee in there at times too. But it is always a struggle. The jack made it effortless. Getting g old I guess.
  2. mentolio
    mentolio King of the island of unwanted toys...
    Jul 14, 2016
    1,429
    When I did my rebuild and I reinstalled the rear wheel, it was the first time I noticed the offset. Thinking something was “wrong,” I stripped-off the tire, etc. (full disclosure: I did try to “fix” it with the tire on…bad idea), and started “working the spokes” to shift the wheel over to center. Got it pretty close too!
  3. mas335
    mas335 xendurist
    Jun 17, 2006
    2,740
    Advance, NC
    Could not be happier with this decision, cranks with confidence. Thanks Jeff for steering me in the right direction.
    Jeff@TheQuadShop likes this.
  4. Jeff@TheQuadShop
    Jeff@TheQuadShop TAT survivor
    Nov 28, 2004
    8,045
    Crestwood, Kentucky
    Great! I've had mine for a little over 3 years now, it still starts strong even after sitting for many weeks.
  5. mtn.moto.adv
    mtn.moto.adv Been here awhile
    Nov 10, 2019
    345
    USA
    I ran into a strange issue, my battery terminals must've gotten too dirty cause today when I tried to start my bike today all the power was killed after pushing the e-start. I tried to test the voltage with my voltmeter in the dash but I found out the fuse was burnt out too. So I cleaned the battery terminals and connected everything back up, turn on the ignition and started the bike up and everything was working fine.
    But then I went to turn off the bike and for some reason it continued running with the ignition switch turned off, I had to use the kill switch to turn off the bike. Restarted the bike and the issue persisted. Did my ignition switch just take a crap on me? do I need to replace it or is it something that can be fixed at home, or an entirely different issue all together?
    edit: I forgot to note earlier that when I turn off the key ignition all the lights and everything turn off as normal, it's just the engine itself continues to run until I hit the killswitch
  6. plugeye
    plugeye MC rescue
    May 11, 2007
    7,236
    Garland, Texas USA
    i have one doing that as well. the normally closed pole is shot. you can sometimes wiggle to kill, but just use the stop switch for now. i ended up bypassing it with a rocker switch, now keyless and the freedom is great.
  7. mas335
    mas335 xendurist
    Jun 17, 2006
    2,740
    Advance, NC
    Are all the DR keyed ignition switches the same and connect to the main harness without a problem?
  8. mtn.moto.adv
    Nov 10, 2019
    345
    USA
    Is it possible to find new OEM ignition switches from Suzuki or am I going to have to go the used route? All I was really able to find on Ebay were cheap switches being sent from China
  9. Trixie
    Trixie Adventurer in my own mind
    Jul 19, 2001
    5,877
    Stuck between Massholes and Syrup heads
    Boblosi111 likes this.
  10. mtn.moto.adv
    Nov 10, 2019
    345
    USA
    Mine's a 1995 SE model. The previous owner swapped out the forks so none of the original dash is there or the handlebar lock assembly stuff, just the plastic housing for the key tumbler and switch remains (idk if that makes any difference but figured I'd make notice of it)
    edit: I couldn't seem to find that part on Rocky Mountain when searching the part # but did find it on Revzilla so will go ahead and order it. I was planning on doing a little overnight camping trip ~100 miles away this week, do you guys think it'd be okay running there with the shot ignition switch or should I postpone an extended trip until the new one arrives?
  11. mtn.moto.adv
    Nov 10, 2019
    345
    USA
    Update on the ignition issue: I went back into the battery and cleaned up all the connections really good and noticed the ground wire for one of my accessories had a weak terminal, replaced it and also bought some longer battery terminal screws (since the original ones didn't want to reach the nut with the aux terminals connected to the battery without some work), also my dash's volt meter fuse was blown so replace that as well.. started up the bike and then turned off the ignition and now everything's back to working like normal. Started it up and turned it off a handful of times and getting consistent results.
    Can't say for certain what fixed it but I can only assume the issue was somewhere within having a bad ground perhaps? Whatever it was I'm just glad I didn't have to drop $60+ on a new ignition.
  12. Ibraz
    Ibraz Been here awhile
    Feb 11, 2017
    608
    Québec
    Here are pictures of a head of a local DR350 rider that just came back from an overhaul at CVtech.
    Cam journals and rockers were repaired.
    C8714514-F149-4985-A2AD-D190CBC966BB.jpeg B0053EBF-5AF9-4406-8C14-D22058B6AF27.jpeg
  13. Jeff@TheQuadShop
    Nov 28, 2004
    8,045
    Crestwood, Kentucky
    I picked up this 97 yesterday, I already have a new 441 cylinder and piston sitting here so I'm going to build this motor for my personal bike and end up with two motors. I'll also be installing a wide ratio gear set.
    drhippie2, Tygen1, MotoDane and 7 others like this.
  14. mentolio
    Jul 14, 2016
    1,429
    Noice!
  15. markk900
    markk900 Long timer
    Oct 13, 2012
    1,019
    Ontario, Canada
    Does anyone have any idea why the S/SE model gas tanks have those silly plastic ears on them? You can't take them off without making the bike ugly but that's 6 parts (4 screws and 2 panels) and 2 extra steps on the assembly line for what? The tank was unique to the DR so why not just press the tank into the shape they wanted and solve both the aesthetic (if that was the reason) problem and the assembly optimization all in one go?
    I ask because @Jeff@TheQuadShop 's new acquisition is missing them.....and its been bugging me for a while.
  16. MrPulldown
    Aug 18, 2009
    9,176
    Truckee
  17. MrPulldown
    Aug 18, 2009
    9,176
    Truckee
    I have thought about this too. I assumed it was for crash protection. The lower corner gets hit easily. Replaceable crash panels. ???
    Jeff@TheQuadShop and markk900 like this.
  18. markk900
    markk900 Long timer
    Oct 13, 2012
    1,019
    Ontario, Canada
    Could be but have you *ever* seen someone replace them? (Well maybe Jeff has to now! :) )
  19. markk900
    markk900 Long timer
    Oct 13, 2012
    1,019
    Ontario, Canada
  20. Jeff@TheQuadShop
    Nov 28, 2004
    8,045
    Crestwood, Kentucky
    I have a couple spares. LOL
