DR650 sputtering with throttle
Discussion in 'Thumpers' started by gpops, Oct 26, 2020.
  1. gpops
    gpops n00b
    Oct 18, 2020
    3
    Pennsylvania
    Hi all, I have a DR650 that wasn't starting, so I tested and replaced the battery. Then cleaned the spark plugs. Then I bought the stock carburetor rebuild kit from ProCycle and cleaned it well and replaced the o-rings and jets.
    The bike starts great now. I rode it down the street and as I'm giving it a little throttle, it sputters and feels like it's going to die. But then it breaks through and rides a little jerky, but not awful. Shift into second gear and it just feels a little off. I have a feeling it's the fuel mixture screw. I read it should be 1.5 turns out and set it there. I have the California emissions still on the bike if that makes a difference.
    Should I take the carb off again and turn the screw until it's 1.25 turns out? Or could this be something else?
  2. crazybrit
    crazybrit Defying any self identifying Super Moderator
    Mar 16, 2006
    9,551
    Portland, OR
    I very much doubt 1/4t on the mixture screw would cause the symptoms you describe. I'd be more inclined to look at the pilot jet. I realize it's a new jet but I've seen them pick up crap right away or be blocked from new.
    gpops likes this.
  3. boulet_boulet
    boulet_boulet Long timer
    May 14, 2018
    1,629
    Maine
    GPops-you’ll find tons of great advice over at the DR650 thread, including from Jeff, aka @procycle , who is very generous with his time and knowledge. You might consider posting there as well. It can be a bit much to keep up with that loquacious bunch, but they always chime in with mechanical advice when asked.
    gpops likes this.
  4. gpops
    gpops n00b
    Oct 18, 2020
    3
    Pennsylvania
    Thank you for the quick reply. I let the bike sit for a half hour and started it up again. Took it around town and it's riding fine now... weird. Glad I did the install correctly haha. I was worried I'd have to take it apart again like you suggested.
    Good advice, I just started following that thread for the future. My problem went away after riding the bike a second time. Weird! Thanks for your reply.
    boulet_boulet likes this.
  5. crazybrit
    Mar 16, 2006
    9,551
    Portland, OR
    Glad it was something that simple :thumb
