DR650 tire suggestions
Discussion in 'Thumpers' started by fullmosey, Apr 27, 2006.
  1. fullmosey
    fullmosey n00b
    Mar 4, 2006
    9
    Austin, TX
    I have burned thru my original Trailwings on my new DR650. Any recommendations for the wee tiny 17" wheel? Experiences, thoughts, psychotic rubber ramblings are welcome.
  2. Max Kool
    Max Kool Xtankteam™
    Jan 19, 2004
    4,855
    Los Angeles
    You might wanna start by telling us where you ride mostly?
    single track offroad only
    the occasional fire road
    tarmac only
    etc.
  3. yater
    yater Long timer
    Oct 10, 2004
    8,517
    Texas
    I have 3 favorite rear tires for 3 different conditions. For dirt, I like the kenda trackmaster II, for dualsport or multi-day trips with plenty of dirt and plenty of pavement, I like the kenda 270. For street, I like the stock trailwings (I find them cheap as throw-aways).
    Fronts are different. I don't like the dunlop 606 front AT ALL. The mt21 is better but not great. I'd rather use a generic knobbie (cheap, non dot) than either of those two. The 270 is alright for long pavement stretches. The trailwing is good for the street.
    What are you doing with the bike BTW?
  4. sleepywombat
    sleepywombat the DR650 pig
    Feb 20, 2006
    456
    perth, western australia
    im after a similar answer i want a front tyre for a dr650 that wont wash out on gravel i dont mind the stock rear tyre , when the back slides out the fun begins, so any suggestions for a good poriced front tyre would be helpful
  5. davorallyfan
    davorallyfan Commonist
    May 2, 2005
    18,329
    Capitalist
  6. CJBDRdude
    CJBDRdude Ridin'offroadCJ
    Jan 7, 2006
    593
    Upstate NY.. rockin it in Valatie!!!
    Get the metzeler Karoos. Street legal knobbies> excellent wear and R rated for 106 mph. Don't waste your money on those crappy kenda 270s. They wear out quick and have absolutely no traction offroad after they wear about 200 miles. After replacing the k270 tires every 500-600 miles, I switched to the Karoos. More $$, but the first set has lasted for over 2400 miles, still going strong and thats true dual sport> 50/50 riding. The karoos were developed for these kind of bikes and this kind of riding.
  7. yater
    yater Long timer
    Oct 10, 2004
    8,517
    Texas
    This is nonsense. My 270s have outlasted all other tires I've run...except the stock trailwings. I get about 3k out of a rear.
  8. 2 SPOT
    2 SPOT bring the rape whistle
    Dec 14, 2005
    6,067
    Payson AZ
    i've tried alot of tires over the years. the 270's are ok, pretty good mileage but they really skidded around on the hard dry stuff i ride here in AZ. pretty sketchy on fast dirt. i'd call it a good tire for slabbing and easy to moderate dirt. i have almost 2500 miles on my mich bajas now, still about a 1/4 tread left on the rear, it'll prolly just about make 3k miles. with the awsome traction they have offered me on dirt i call it a good buy. noisy on slab, but thats ok. front tire design wanders on slab but hooks up like a bitch offroad. proved to be a good tradeoff tire favoring dirt with better than average mileage for its aggressive knobs.
    i think for a tire to be as good as can be in both environments you should stick to a tire with large un-directional tread blocks. the teek, MT21 and 606 are a few that come to mind. these tread styles will offer good offroad traction while providing a stable and predictable slab manner as well, not the best in either world, but a fair compromise to both i think. if you look at past posts on these and other similar tires you'll see a pattern develop, good on the street, good on the dirt, but not great at either.
    #8
  9. CJBDRdude
    Jan 7, 2006
    593
    Yeah and you're probably riding on the road 90% of the time. K270 are awful offroad tires. If you're riding dual sport for real - not that pavement stuff all the time, you'll find the Kenda are basically road tires - period.
    BTW, the trailwings are nonsense!!!!
    #9
  10. Hannda
    Hannda Short, fat, bearded, old & slow
    Apr 27, 2005
    43,162
    Not yet far enough away from town
    When the stock rear wore out on my KLR the shop put on a Gripster. Great road tire, just awful off-road. After 500 miles I switched to TKC80 front and rear. Perfect. I doubt I'll run anything else. Great on road, great off road. Couldn't be happier for a 50/50 mix tire.
    #10
  11. rockt
    rockt Long timer
    Oct 13, 2003
    2,584
    Canada
    #11
  12. slideways
    slideways Norway
    Mar 1, 2003
    11,680
    Norway
    The two best front tires I found for use on my DR650 were the Dunlop D756 and the D739F. These are not street legal tires but they worked well on or off road. They were used tires that I took of my MX bikes but they still had plenty of tread left on them for DS use.
    If you want your tires to work well on the DR you have to get the suspension dialed in. With the stock suspension the best tires you can put on the DR will only deliver marginal performance.
    #12
  13. ram1000
    ram1000 Long timer
    Feb 14, 2004
    1,883
    Tricities Washington
    I've gotten long miles on 270's as well but the best 50/50 tires I've used are Kings 966. They do better than 270's on pavement and as good on gravel. I use them on my wifes bike on sand washes, but she couldn't do that without full knobs. They last a long time on street when aired up to 30 or so.
    They chunk off a little when I use them on my x-LC4 but the DR650 doesn't have the power to chunk them.
    #13
  14. Tholund
    Tholund Adventurer
    Apr 29, 2005
    87
    Various locations in SOCAL
    If more than 50 percent on-road, Dunlop D606. If more dirt (sand) MT-21's
    Dan
    #14
  15. sleepywombat
    Feb 20, 2006
    456
    just got a dunlop 606 front tyre fitted today for $100, going to take it for a ride tomorrow to test it on gravel/dirt.... first impressions on tarmac are good, though it did feel a little slippery ...but i put that down to it being a new tyre....will let you know how it goes tomorrow:evil
    #15
  16. fullmosey
    fullmosey n00b
    Mar 4, 2006
    9
    Austin, TX
    I began this thread but I think I recently answered my own question. I had used the Kenda 270 on a previous bike with good overall mileage but poor filth performance. The Trailwings the DR comes with are crappy offroad. I now have Metzler Karoos front and rear. I have put about 1000 miles on them, approx 800 street and 200 dirt. They're great! The knobs are firm enough to reduce wobble at highway speed. The knobs are also further apart than the TKC 80's or MT's, thus allowing for the clearing of mud from the tire on a recent adventure. Ahhh mud. Aired down a little, they should be great in Moab country next month. Thanks for everyone's advice.
    BTW, anyone want to ride in Canyonlands around June 19-20th?
    #16
  17. David_S
    David_S Long timer
    Feb 8, 2003
    1,130
    Sullivan, Ohio
    Be aware that the Karoos wear very quickly in hard rocky terrain. I recently took a trip to Mexico's Copper Canyon which has terrain similar to Moab and the tires wore very quickly. I wouldn't expect to get a 1000 total off road. They hold up well on pavement but wore very quickly on the rocky stuff. A riding partner had a DRZ with 606 rear MT 21 front combo and his tires were barely worn and my rear is about done. Just something to think about. I've read similar report on the Karoos. Great pavement and mud tire but not so great on rocks.
    DS
    #17
  18. crane
    crane n00b
    Sep 3, 2007
    2
    just thought i'd chime in and say that the kenda k270's seem like a well-balanced tire for a DR...pretty good on the road and not too bad on the trails. Since you ride a DR650, I assume that you are looking for something that is well-balanced.
    #18
  19. eyedragaknee
    eyedragaknee McGuyver
    Jul 27, 2004
    2,319
    Triangle
    TKC-80's work great in anything but real mud because of the close blocked tread.. I've run them on quite a few bikes and like them a lot and mileage is good. Good profile to hit the curves on asphalt as well as good knob placement. The Karoos felt really squirmy leaned over because of the knob edge. Off road Karoos are a little better but don't last long for me. Also Karoos are noisy as hell if that matters at all.
    #19
  20. Collarbone
    Collarbone Been here awhile
    Jan 16, 2007
    477
    Viroqua ,Wisconsin
    So far I like my 606's I haven't done to much dirt just some sandy trails and they did alright.I mostly ride gravel and black top about 50/50 and I like the way they take it I can take most corners with just a little backend slide and thats usually brought on by my right hand.I figure I'll get 3000 out of the rear but there won't be much left. Front will still have some miles left.running same psi as I did the tw's and there wearing even.TW's were good road tires but didn't last any longer than the 606's and were alot squirmer on gravel.I am also very suprised how far I can lean it over with the 606's just another plus.I'm not sure how they will do in the snow but ask me next spring and I'll let you know.
    #20
