Drill hole through center stand arm?
Discussion in 'GS Boxers' started by 8MoreMiles, Jun 28, 2020.
  1. 8MoreMiles
    8MoreMiles Adventurer
    Jan 9, 2008
    94
    North Country, NY
    Many years ago I installed new cases and a new exhaust (05 1200GS). The new exhaust changed the route slightly which meant the bump stop didn’t align properly and the center stand would hit the swing arm.
    So I came up with a janky solution using some hose clamps and a bit of rubber clamped on the center stand to hit the now shifted stop on the exhaust. As I’m taking the time now to fix MacGyver’d work on the bike, I want to fix this.
    Plan: drill and tap M6 hole from front to back through the center stand and place a rubber threaded bumper on it. I’ll use a lock washer and loctite to keep it from backing off.
    should I worry that this will significantly damage the structural integrity of the stand?
  2. Lead Wrist
    Lead Wrist Mehr Gelände Weniger Straße
    May 26, 2007
    7,033
    Zer0-Zer0-Zer0-Zer0
    Or, you could maybe rotate that clamp not to interfere with the CS? :hmmmmm
  3. szurszewski
    szurszewski Long timer
    May 26, 2010
    3,402
    Olympia, WA
    Or is the clamp there on purpose so it hits your rubber bits on the stand because otherwise the stand would swing up all the way and just hit the pipe?
  4. 8MoreMiles
    Jan 9, 2008
    94
    North Country, NY
    The clamp on the exhaust is rotated so it hits the rubber piece, otherwise the right side of the stand comes up and smacks the swing arm.
  5. Lead Wrist
    May 26, 2007
    7,033
    Zer0-Zer0-Zer0-Zer0
    The exhaust has rubber bumper to prevent this or it should've had rubber bumper. :deal
    There was also a hard stop for CS - rubber just prevents the "noise"...
  6. Lead Wrist
    May 26, 2007
    7,033
    Zer0-Zer0-Zer0-Zer0
    There's something wrong in that "picture" that you described, as it's not stock configuration - ymmv... :deal
  7. 8MoreMiles
    Jan 9, 2008
    94
    North Country, NY
    Correct, this is not the stock exhaust and routes in closer to the bike so there’s no longer a rubber stop. I put the hose clamp contraption on in a hardware store parking. The previous bump stop isn’t available so I made one using some left over rubber and the exhaust clamp.
    szurszewski likes this.
  8. Lead Wrist
    May 26, 2007
    7,033
    Zer0-Zer0-Zer0-Zer0
    ^^ Sounds good... :thumb
    #8
  9. Rick92040
    Rick92040 Adventurer
    May 30, 2018
    36
    San Diego
    I don't think a small hole will affect the structural integrity of the stand enough to matter.
    #9
    lewisjr1 likes this.
  10. 8MoreMiles
    Jan 9, 2008
    94
    North Country, NY
    Thanks, I think it’ll be ok with a bolt through it and it’s a stable load once on the stand. It’s not like I’m turning the post into Swiss cheese.
    #10
  11. TUCKERS
    TUCKERS the famous james
    Dec 23, 2005
    19,973
    Villa Maria Sanitarium, Claremont, CA. USA
    I'm pretty sure a 6mm hole will affect the integrity of the stand.
    #11
  12. side-burn
    side-burn Long timer
    Apr 28, 2019
    1,254
    Colorado
    I wouldn’t do it, but that’s just me. I’d figure something else out, call me crazy.
    #12
  13. Boxerbreath
    Boxerbreath 2017.5 GS Black Storm
    Feb 7, 2018
    3,896
    Lost Angels County
    Not to worry
    #13
  14. 8MoreMiles
    Jan 9, 2008
    94
    North Country, NY
    Trust me, I’ve been browsing McMaster-Carr looking at options.
    Also considered a clamping option to the skid plate as I don’t see removing that in my future.
    #14
    side-burn likes this.
  15. The Fabricator
    The Fabricator I didn't know it wasn't possible so I did it.
    Mar 30, 2018
    214
    Petaluma, Ca.
    I would fabricate and braze a bracket to the side stand. This could be done with the center stand mounted.
    A hole would be a stress point where a crack could initiate. A lot of weight on the center stand and a lot of torque generated when the bike is twisted on the center stand.
    #15
    8MoreMiles likes this.
  16. side-burn
    Apr 28, 2019
    1,254
    Colorado
    Just make DMAN sure you spray that hole with protectant so it doesn’t rust. Once it starts you’ll be in trouble.
    #16
  17. cpallen
    cpallen Nearly Adventurer
    May 26, 2003
    1,884
    Panora, IA
    I have had good luck (mis)using these anchor cable clamps for various things on my bikes. Maybe you can use one to mount your rubber stop instead of drilling a hole in your center stand.
    If you drill a hole in the stand - I wouldn't tap it. I would drill it oversize and use a sleeve over the bolt so you don't crush the tubing when you tighten it up. A nylock nut would look ok and you could trim any excess bolt so it would be less of a snap or puncture hazard.
    #17
