Drilled holes in Tusk panniers, now need to close them up
Discussion in 'The Garage' started by ChopperCharles, May 17, 2018.
  1. ChopperCharles
    ChopperCharles Long timer
    Jun 7, 2006
    1,863
    Durham, NC
    I drilled holes in my tusk panniers to mount them to the OEM luggage racks for my SCR950. After a few hundred miles, I wasn't happy with that setup. I wanted quick-release. So I purchased Tusk pannier racks for a DR650, cut off all the attachment points, and am welding them onto my OEM brackets.
    So... how do I seal up the holes I made in the aluminum panniers? I don't think braizing is necessary, as my only concern is for brief immersion during a stream crossing, and water ingress from the tire slash. (Two of the holes are right at the bottom). I know duct tape will work, but I'm hoping for something a little more... permanent. Some kind of adhesive bandage maybe? Epoxy a thin piece of aluminum over the hole? Open to ideas here.
    Charles.
  2. DirtyOldMan
    DirtyOldMan Long timer
    May 2, 2006
    2,415
    Banjoland
    That real duct tape, the aluminum kind you pull the paper backing off is pretty dang stout. Clean where you’re gonna stick it with an alcohol pad. On stuff that has a bit of thickness to it 1/8” or so, I put tape on the outside, squirt a little dab of silicone in the hole and then a piece of tape on the inside.
    JB weld works good too.
  3. Eatmore Mudd
    Eatmore Mudd Mischief on wheels.
    May 28, 2012
    2,422
    Wet side of WA.
    Go down to the nearest airport or airfield and ask someone to put flush fit rivits in those holes.
    Water proof, looks good and shouldn't cost you more than a beer.
  4. mitchntx
    mitchntx Visit The wick in Seattle
    Apr 21, 2016
    782
    Texas
  5. Mercury264
    Mercury264 Once you go Triple...
    Nov 7, 2005
    24,022
    Masshole
    Duct tape on the inside, fill hole with silicon caulk, put a sticker over the hole.
    Maggot12 likes this.
  6. manstache
    manstache Flounder of ADV
    Apr 3, 2010
    1,859
    Berkeley Springs, WV
    I'd cut out a thin piece of aluminum about the thickness of a soda can and JB weld it on over each hole from the inside. It would be permanent and the JB weld would also fill in the hole and can be sanded smooth.
    VanXR and Bigger Al like this.
  7. Widgeon23
    Widgeon23 Uneasy Rider
    Apr 18, 2017
    91
    Beaverton, OR
    What are the hole dimensions?
  8. Maggot12
    Maggot12 U'mmmm yeaah!!
    Feb 21, 2010
    15,727
    Canada's ocean playground
    Many ways to skin this cat. You can put a small screw and nut, silicon on both ends before tightening.
    I used "well nuts" on my kayak a few days ago, so those would work for your application.
    The idea above of inside duct tape, silicon hole and a decal covering the holes from the outside is probably the least of all efforts with no tools.
    The jb welding of a small plate over them would work too.
    #8
  9. anotherguy
    anotherguy unsympathetic
    Jun 18, 2009
    10,580
    the hills
    #9
    Reddog*, Widgeon23 and phreakingeek like this.
  10. ChopperCharles
    Jun 7, 2006
    1,863
    Durham, NC
    Push in plugs are a good idea, as are the rivets and the aluminum tape. Holes are big enough for an M10 bolt. One of them for an M12.
    Charles.
    #10
  11. phreakingeek
    phreakingeek adventurer Super Supporter
    Sep 17, 2010
    1,697
    VA
    it it were me, i would want the inside as smooth as possible. My gear gets worn enough just from vibrations as I ride, I dont want to introduce any extra places that would induce wearing holes in my bags/tent/mattress.
    I'd probably go with the aluminum can and silicone patch method...or black duct tape. I've had that Gorilla brand duct tape over a couple of other panels on my bike for several years now and still good to go.
    #11
  12. Widgeon23
    Apr 18, 2017
    91
    Beaverton, OR
    When/if you install them, use some liquid electrical tape on the center rim. Flexible, watertight, but if you need to remove at some point it will break free easier than caulking. I use this method on watertight light fixtures.
    #12
  13. Bounder
    Bounder ExternallyDisplaced
    Mar 2, 2011
    1,657
    West Cork, Ireland
    I'd go with some Sugru, Its pretty tough stuff. Has other uses as well.
    https://sugru.com/
    #13
    Little Bike and Widgeon23 like this.
  14. Widgeon23
    Apr 18, 2017
    91
    Beaverton, OR
    That looks pretty neat!
    #14
  15. Bounder
    Mar 2, 2011
    1,657
    West Cork, Ireland
    It is pretty amazing stuff, uses are limited only by your imagination.
    I have a multipack of it in the fridge, I have used it to fix all kinds of things.
    #15
  16. Widgeon23
    Apr 18, 2017
    91
    Beaverton, OR
    The only thing about it is the price. A good tube of silicone caulking is around $3. Liquid etape is $2. I will try it out though.
    It seems like a perfect fit for the op's needs though; if it comes in black. <-- edit, it does
    #16
  17. MrBob
    MrBob Long timer Supporter
    Oct 27, 2005
    15,996
    Boulder county, Colorado
    This. Won't scratch pannier contents and should seal well. If necessary, alter the holes to fit the plugs.
    #17
    phreakingeek likes this.
  18. shovelstrokeed
    shovelstrokeed Long timer
    Jun 20, 2003
    5,293
    South Florida
    Look up 6061.com on U-tube. They have an excellent video on filling holes using TIG. Might be extreme for this application but would be the most permanent of repairs.
    #18
  19. Project84
    Project84 I can haz adventure?
    Jun 19, 2013
    5,001
    Florence Y'all, KY
    I'd use aluminum sheet and gutter adhesive. I use gutter adhesive at work in place of nearly any glue/caulk cause it's tough as hell and holds up well to water exposure, obviously.
    #19
  20. sleazy rider
    sleazy rider Retired
    Mar 6, 2007
    3,553
    White Lake, Michigan
    TIG weld 'em shut. Screw all the patch and plug stuff. Do it right, do it once and be done.
    #20
