Drive shaft damper
Discussion in 'Airheads' started by Hook74, Sep 12, 2021.
  1. Hook74
    Hook74 Been here awhile
    Oct 31, 2018
    224
    I'm just passing through. I don't belong anywhere
    Hello
    I have heard of 100mm extended drive shafts used with or without damper (see pic).
    Having to buy a drive shaft, I have a doubt.
    Damper yes or no?
    do you have any advice?
    Thank you
  2. bleaknessengine
    bleaknessengine Been here awhile Supporter
    Mar 29, 2009
    211
    Portland, OR
    i have an extended mono, the shaft is a tapered fit extended bell housing. so no damper. i’ve been riding it about a year and a half, and it is a little more jarring to shift, but that can be mitigated with technique. i also don’t try to go crashing through the gears and i ride pretty gently in general, so maybe i don’t have a typical experience either haha.
    hunterkey and Jim K in PA like this.
  3. OldCrustyStuff
    OldCrustyStuff Adventurer
    Jul 19, 2021
    74
    Normal, IL
    I upgraded my 78 R100RS to the Cush drive driveshaft like that and it’s noticeably smoother IMHO
  4. Beemerguru
    Beemerguru Beemerguru...G/S guy
    Nov 7, 2006
    2,677
    Redwood City, CA
    I've built 6 customs with extended swing arm...both dual shock and mono. Cush drive in all with no problems
  5. Hook74
    Oct 31, 2018
    224
    ...hello...thank U
  6. Arktasian
    Arktasian Feelin the BMEP
    May 23, 2014
    2,278
    BC
    Not sure where you hail from ^ , but I'd recommend having Greg (aka Beemer Guru) build & insert the cush drive if your shaft isn't already modified. Much more forgiving towards any driveline shock loads that might develop, nothing worse than a taper fit assembly coming loose on you mid trip somewhere.
  7. Hook74
    Oct 31, 2018
    224
    Hi, I'm Italian... I think I'll buy the extended shaft close to home or at most in Europe. Definitely with damper. I could also have it built from CNC, with no welding...but I would have to know the type of steel and heat treatment needed.
  8. bleaknessengine
    Mar 29, 2009
    211
    Portland, OR
    contact tagmoto, in italy, they make sweet +100 swingarms. they used to do shaft lengthening, but if they don’t now i bet they have a connection.
    #8
  9. Hook74
    Oct 31, 2018
    224
    hello thank you, I have now contacted Gletter but if I don't conclude maybe I will follow your advice.
    #9
  10. Hook74
    Oct 31, 2018
    224
    Hello,
    Does anyone know which kind of steel is indicated to build a final drive shaft? could it be 42CrMo4 ..?
    #10
  11. Hook74
    Oct 31, 2018
    224
    Hello…I found the right steel to build the extended drive shaft. (39NiCrMo3 or 36NiCrMo16 or 41NiSiCrMo7).
    It will be a 100mm extended drive shaft CNC machined, without welding.
    As a reference measurement I guess I have to take that of the R80 g/s shaft and add 100mm.
    Do any of you have a chance to take this measurement that is shown in the picture?
    A curiosity, are there any airhead models with a shorter drive shaft than the R80 g/s size?
    #11
