drum brakes, getting the drum off?
Discussion in 'The Garage' started by WIsixfitty, Jul 24, 2011.
  1. WIsixfitty
    WIsixfitty rock and roll the bones
    Aug 7, 2006
    4,866
    west of road america
    my daughters 02 taurus rear drums are in need of some attention.
    what's the trick to getting the drums off when pads have worn in a bit and not letting them slide off.
    drums are loose just being held up by the pads.
    I tried cracking the bleeder w/o much success.
    :ear
  2. cobrags
    cobrags Lost ADVR
    Jun 16, 2009
    667
    SE MN, On the road less traveled
    Keep twisting drum back and forth and tapping with hammer/rubber mallet. Good luck, it will come with some elbow grease.
  3. Maggot12
    Maggot12 U'mmmm yeaah!!
    Feb 21, 2010
    20,681
    Canada's ocean playground
    There's a 1/4 in bead of rust and the pads are worn in the small channel that the pads wear on the drums. hitting the front of the drum (near the studs) usually works. don't hit the drum on the sides. I sometimes use my 2 1/2ft long scredriver to pry the drums over the pads. If you do this be careful not to damage any internal brake parts or the backing plate.
  4. troidus
    troidus Long timer
    Sep 1, 2010
    50,688
    Georgia
    You can't get to the adjusters to back the brakes off? You may have to use a hammer and punch to knock a metal plug out first, if they've never been touched.
  5. WIsixfitty
    Aug 7, 2006
    4,866
    she bought the car used a year or so ago so I would assume they are original.
    Adjuster, plug? On the back side?
    I admit I am a drum brake n00b. Just never worked on this old tech and I'm no spring chicken either. :1drink
  6. Bump Stop
    Bump Stop 2 Wheeled Drifter
    Aug 17, 2009
    8,371
    finding Jesus
    cracking the bleeder won't do any good, at rest the wheel cylinders should be pretty much retracted if you have the drums lose on the hub you should be able to pry them off, it might not be easy but the will come off.
  7. mike
    mike Long timer
    Mar 2, 2007
    5,190
    Missouri
    God I hate drum brakes. Like someone said, back off the adjuster or you might be able to use some kind of puller to wrench it free.
  8. larryboy
    larryboy Stable genius.
    Jan 9, 2005
    28,973
    Über Alles,California
    Yeah, on the backing plate below the "axle" center line there are a couple of stamped ovals, take a punch and hammer, knock them into the drum, through one hole you use a screwdriver to hold back the tab, through the other hole you turn the star wheel to back off the brakes.
    #8
  9. WIsixfitty
    Aug 7, 2006
    4,866
    well it looks like a prybar will be my plan.
    agreed, drum brakes suck donkey balls. :puke1
    #9
  10. WIsixfitty
    Aug 7, 2006
    4,866
    thanks. I'll take a look see tomorrow.
    Gonna chill now with a beer and get ready for that bike race out on the west coast.
    #10
  11. larryboy
    Jan 9, 2005
    28,973
    Don't bend the backing plate if you're going to try the pry bar, brake problems forever is what you'll get if you do.
    #11
  12. larryboy
    Jan 9, 2005
    28,973
    Oh yeah, the race...off to see if I get it on the TV. Somebody pick up my bike, will ya?
    #12
  13. Bump Stop
    Aug 17, 2009
    8,371
    finding Jesus
    I don't mind working on drum brakes, they are actually pretty simple. I would almost rather do drums than rear disks with the parking brake built into the caliper.
    #13
  14. GreaseMonkey
    GreaseMonkey Preshrunk & Cottony
    Jun 16, 2006
    5,960
    The only county in Illinois with no train tracks
    I'd strongly suggest darn near never to try and pry the drum off without retracting the shoes first or there is a possibility that you will be very very sorry if you get it stuck there and then damage the drum trying to hammer it back home as it can then be impossible to get the adjuster to release.
    You need to back the adjuster off, otherwise you are trying to pound a 9.1" peg through an 8.92" hole and something will have to give.
    Google up "taurus brake shoe replacement" or something similar. Here is a link that came up at the top of the page but go ahead and look up your own:
    http://www.justanswer.com/ford/15sh2-ford-taurus-2003-removal-rear-brake-shoes.html
    Good luck, as long as the adjuster turns easily it is not too difficult of a job.
    #14
  15. Benesesso
    Benesesso Long timer
    Jul 29, 2008
    9,898
    West of Phoenix, Arizona
    After you get the drums off, if you don't get them turned, take a grinder and remove the unworn ridge all the way around the edge of the wear surface.
    Well designed drum brakes allow the linings to reach the edge, so no ridge is created.
    #15
  16. Quickv4
    Quickv4 Pro Turd Polisher
    Jul 5, 2009
    550
    Dickinson, Nort' Dakohtah- Orig. from Wiscowsin
    Get a nice big honking hammer and wail on the thing on all different angles. If you smack the bottom, pull with your hand at the top. Smacking the rotor will knock some of the edge off of the drum. I have never broken a rotor by wialing on it, just dont hit the studs!!!!
    #16
  17. Jamming
    Jamming Desert RAT
    Sep 7, 2005
    3,085
    Buckeye AZ.
    That's funny..my Son had the same year and I had the same problem. Fortunately it wasn't my first set of drum brakes. I backed the adjuster off and it still wouldn't budge. I got out my 2 lb dead blow soft face hammer, put in my ear plugs..do it, you can thank me later..... I zapped it at 12, 6, 3 and 9 O'clock on the outside of the drum. It popped right off.
    BTW...replace the wheel cylinder...don't rebuild...they were cheap and I did grind the ridge off as I didn't turn the drum...they were fine and miked out fine.
    #17
  18. WIsixfitty
    Aug 7, 2006
    4,866
    I mainly wanted to get the drum off to see if was still in spec and then go buy the parts needed.
    good info.
    #18
  19. H96669
    H96669 A proud pragmatist.
    Nov 20, 2009
    6,190
    Hiding off Hwy 6, B.C.
    If all else fails, cut the "Nails" holding the shoes in place. There should be 2 of them, you can see the heads from the backside of the mounting plate. A cold chisel usually takes care of that quick, then a pull on the drum and everything will/should fall off.
    Be thankful you are not dealing with a Willys or some other vehicles from the 40's which had a drum set on a tapered axle.:eek1
    #19
  20. larryboy
    Jan 9, 2005
    28,973
    Oh good gawd, those are horrible...even with the right puller I couldn't believe how hard I had to hit it to get the hub to pop. :huh
    #20
