Drz400 Thread
Discussion in 'Thumpers' started by Britmick, May 4, 2007.
  1. Fixnfly
    Fixnfly Not found on the book of faces
    Feb 28, 2008
    1,442
    SWPA
    It may just be the seal behind the shifter, easy fix.
  2. mwitt08
    mwitt08 Adventurer
    Oct 12, 2018
    67
    Dayton, Ohio
    I’m not sure which I’d prefer. I thought they were similar enough in the broad spectrum of ADV bikes to be equals. Maybe I’m off base there.
    I have a KLR650 now and find it heavy and awkward. So I’m selling it.
    I’m 5’ 11” and 200 lbs.
  3. NorskieRider
    NorskieRider Long timer
    Mar 19, 2011
    1,174
    Minnesota
    I'm familiar with the S and E but didn't realize there was an SE ? Or was that a typo?
    Which year is it?
    Either way, $1000 for something that usually sells for > $2000 and only requires a $20 part is fantastic.
    I'd go with the DRZ400, it's much more bike than the DR350. But we don't know how you plan on using it.
    Or the crankshaft seal, also an easy fix. Hopefully these shaft seals aren't masking a bigger problem.
  4. mwitt08
    mwitt08 Adventurer
    Oct 12, 2018
    67
    Dayton, Ohio
    After looking in depth, it’s not a S (SE was a misquote by me using dr350 naming conventions).
    It’s actually a 2001 kick start model.
    I would need to mod it to have the S rear sub frame as I’d want it set up for ADV.
    It’s already been plated and has a Baja light kit installed.
    Any big issues with the early year runs of the DRZ?
    slime likes this.
  5. Dutch idiot
    Dutch idiot Crazy, not stupid
    Jan 31, 2016
    260
    belgium
    Maybe take a look at the cam chain tensioner. This automatic one is often changed by later models or manual ones. Leaking needle in carburetor, along with leaky vacuum pet-cock (often changed by manual - off/on/res. one) can cause gaz in oil. Front forks of later model drz's are better constructed. Just a few things.
    slime likes this.
  6. kenstone
    kenstone worn out
    Mar 3, 2013
    1,858
    Boysee
    That would be a "K" model...
    :clap
    slime and Fixnfly like this.
  7. Fixnfly
    Feb 28, 2008
    1,442
    SWPA
    The K models are noticeably lighter that any other version, kinda rare.
    $1000 is a damn good deal even if it needs a little work!
    Leaking oil is no big deal as long as someone kept checking the level.
    slime likes this.
  8. NorskieRider
    Mar 19, 2011
    1,174
    Minnesota
    Does the K get the E goodies (FCR39, higher compression, bigger header) ?
  9. NickSoOr
    NickSoOr Adventurer
    Mar 23, 2016
    45
    Medford Oregon
    Yep all the goodies. Just no Estart.
    Fixnfly likes this.
  10. Bt10
    Bt10 Long timer
    Dec 18, 2012
    1,057
    Saranac,MI
    K is the decade of mfr. There are 3 motors - kick dirt, electric dirt, and slightly lower compression electric street. ‘04+ cam chain tensioner is better. ‘02 forks are more adjustable.
    Edit to add: Street cams and carb are less as well.
    AZ TOM likes this.
  11. Fixnfly
    Feb 28, 2008
    1,442
    SWPA
    How many years was the kickstart only model made ?
    Looking through parts diagrams it seems like only
    01,02,03 ?
  12. NickSoOr
    NickSoOr Adventurer
    Mar 23, 2016
    45
    Medford Oregon
    MotoChris521 likes this.
  13. Honda_Power
    Honda_Power I'd rather be riding
    Mar 2, 2018
    314
    San Diego
    Wow an extra 30lb.s between the E and S is surprising. I wonder how much weight you can easily shed off of an S or SM...
    13 lbs for the e start is a lot. Might have to ditch it
  14. Desertskyy
    Desertskyy Always looking for an adventure
    Mar 25, 2007
    112
    So Cal-Ventura County
    Using a lithium battery helps with the weight
    Plus removing that elephant trunk rear license plate holder and tail lights. Move to a light weight LED type brake and blinker set up
    Good luck
    slime likes this.
  15. NorskieRider
    Mar 19, 2011
    1,174
    Minnesota
    The 'S' subframe and metal gas tank are large contributors to the weight difference.
    slime likes this.
  16. Green Mtn Rider
    Green Mtn Rider Husky Rider
    Jul 20, 2008
    174
    Vermont
    My 03 400 S with a 3.5 gal plastic tank full of fuel with all the protection installed ready to ride 340 pounds on the scales.
  17. jeepgeek2002
    jeepgeek2002 Long timer
    Jun 7, 2007
    3,640
    Jacksonville, FL
    15/47 on the S model doesnt like chug along technical trails.. where the E with 14/47 seems to do it with easy.. is it the gearing or the pumper carb that helps the E vs S?
  18. Marco Moto
    Marco Moto Voyager Supporter
    Nov 14, 2008
    1,578
    Tuscany and Michigan
    ...probably both.
    Also, stock gearing on the "S" model is 15/44
  19. dazz
    dazz Falling off motorcycles for over 50 years.
    Aug 27, 2006
    351
    Ohio
    KTM or DRZ? Kaw KLR? How about a DR350? BETA. 500cc of bad ass KTM. You're going to have to realize that to be happy you need more than one bike. So make a choice. One bike does NOT do everything good. It may do everything, but not as well as the specialized machine.
    I sold my 450 KTM EXC to get the 2000 DRZS. I had to search for the older model with the wimpy forks and constant velocity carb. The 450 was too racy for me in the woods. Tired me out. Suspension hurt my back.
    But all you guys come from different parts of the world. The sand is different. Mud is NOT the same. Woods are not the same all over this country. Riding in Florida does not compare to Arizona! Fat boys and skinny boys need different bikes! Young guys (40s and 50s) can do stuff more mature men can't do. Short and tall, etc.
    Don't forget this is the internet !!!!
    Happy trails to you.
  20. jeepgeek2002
    Jun 7, 2007
    3,640
    Jacksonville, FL
    @Marco Moto i regeared the rear sprocket on the S to 47 because i like the feel of the E's torq.. But i got lazy and impatient and left the 15 CS..
    i ll swap the 14 over to see if thats it.
    Thanks guys
    Marco Moto likes this.
