Drz400 Thread
Discussion in 'Thumpers' started by Britmick, May 4, 2007.
  1. Bt10
    Bt10 Long timer
    Dec 18, 2012
    1,048
    Saranac,MI
    Don't leave them out. looks like dirt can enter there. PO probably had a rally fairing on at one time?
  2. PNWet
    PNWet Been here awhile
    Nov 2, 2014
    921
    Puget Sound, WA, USA
    On some bikes (XR250R for example) the steering tube is isolated and you can add a zerk fitting to grease the bearings.
    I'm not familiar enough with the DRZ frame design, but given that the oil goes in the frame (like the XR) maybe you could replace one of those bolts with a zerk?
  3. Honda_Power
    Honda_Power I'd rather be riding
    Mar 2, 2018
    313
    San Diego
    He might have had a really fairing. I think he was trying to make an adventure bike, hence the kick start.
    I could pop a zirk in, will do that or plug the holes with bolts or a rubber cork/silicone.
  4. Fixnfly
    Fixnfly Not found on the book of faces
    Feb 28, 2008
    1,432
    SWPA
    Those holes look too big for zerks, may have to put the bolts back in and forget you saw them.
    DCrider likes this.
  5. interactive3
    interactive3 Been here awhile
    Sep 23, 2008
    359
    Framingham, MA
    A season of the battery issues... I’ve had to keep the bike on a float charger in order to be able to start it. And then tonight my GF noticed the tail light is slightly on.
    The ignition is off. The key is out.
    Turning the ignition on lights it up to full intensity, along with the headlight.
    Has anyone solved a similar issue?
  6. menotknow
    menotknow always n00b
    Jan 30, 2014
    300
    Seattle, WA
    Just to rule out the obvious, the key was in the off position, not the parking lights on one, right?
    Grinnin likes this.
  7. BornAgain
    BornAgain Been here awhile
    Aug 31, 2008
    777
    Rosenberg, TX
    Check your rear and front brake light switches.
  8. Grinnin
    Grinnin Forever N00b Supporter
    Dec 10, 2005
    6,176
    Maine
    With the ignition off and key out, the brake switches don't matter.
    As @menotknow pointed out, the "park" ignition switch position will turn on the taillight and it will allow you to remove the key.
  9. THRASHED
    THRASHED In your helmet, no-one can hear you sing, I hope.
    Jan 4, 2013
    1,142
    San Dimas, CA
    Menotknow, the DRZ doesn't have that..unlike my old Interceptor and my new Triumph...DOH!!
    Not sure if the brake lights work without the key in the "on" position. Looks like an Edge tail light. I would check your wiring and make sure you didn't connect to some constant hot.
    interactive3 likes this.
  10. interactive3
    Sep 23, 2008
    359
    Framingham, MA
    Thanks guys. That is an Edge tail light. I’ll recheck the wiring.
    The LEDs are so dim I don’t think they are visible during the day. It must have some minute electrical current going to it.
    With ignition ON the tail light goes into its normal brightness. Applying either of the brakes the light goes into bright brake mode. Those switches are correctly adjusted.
  11. Honda_Power
    Mar 2, 2018
    313
    San Diego
    Strange issue. There must be some transient voltage making it to the light. Maybe one of your switches is going bad and not fully closing/opening the circuit.
  12. menotknow
    Jan 30, 2014
    300
    Seattle, WA
    Mine does, 2006, 3 positions for the key, in order: OFF, ON, and >P< that leaves the tail light on and lets the key to be taken out.
    Grinnin and Dutch idiot like this.
  13. Fixnfly
    Feb 28, 2008
    1,432
    SWPA
    What about unplugging the ignition switch to see if the lights go out??
    Grinnin likes this.
  14. interactive3
    Sep 23, 2008
    359
    Framingham, MA
    It’s going to be a week or so until I can take a closer look at the electrical issue . I’ll let you guys know what I find.
  15. jeepgeek2002
    jeepgeek2002 Long timer
    Jun 7, 2007
    3,628
    Jacksonville, FL
    Acerbis 3.7g tank for the KLR400r in Natural color vs black.. i can't seem to find anything for Natural color..
    is that not an option? i don't like the IMS tanks.. and the Clarke only comes in 3.2
  16. jeepgeek2002
    Jun 7, 2007
    3,628
    Jacksonville, FL
    actually the Clarke says 3.6 ... has anyone tried the Clarke for the E models?
  17. THRASHED
    Jan 4, 2013
    1,142
    San Dimas, CA
    I stand corrected....On a personal note, I can't stand that option. I've left mine on before, luckily I caught it before draining the battery.
  18. jeepgeek2002
    Jun 7, 2007
    3,628
    Jacksonville, FL
    one would think with such a big display suzuki would have included an RPM gauge
    Dutch idiot likes this.
  19. moragabiker
    moragabiker Been here awhile
    Apr 19, 2006
    110
    SoCal
    Does anyone know when dealers will receive 2020 DRZs?
  20. jeepgeek2002
    Jun 7, 2007
    3,628
    Jacksonville, FL
    no news yet...
