dt250 innards
Discussion in 'The Garage' started by esworp, Jun 8, 2008.
  1. esworp
    esworp ADV Social Worker
    May 11, 2008
    27
    Panama City, FL
    has anyone got a link to or is willing to post pics of the insides of the dt250e (78) engine? I'd really like to replace the right-side crank seal, and have a clymers in the mail.. but i'm bored today and was thinking I could tackle it.
  2. dunkee
    dunkee life is elsewhere
    Oct 15, 2005
    21
    here and there
  3. stainlesscycle
    stainlesscycle Long timer
    Jun 6, 2008
    2,329
    morgantown, wv
    from memory.
    same procedure on almost all yamaha air cooled 2 strokes (and most air cooled 2 strokes..) . remove kicker. remove clutch cover. remove pressure plate/clutch plates. hold clutch basket with clutch holding tool, or a penny/gear jammer in the primary gear. and loosen/undo primary gear nut. remove clutch hub and basket - pay attention to thrust washer locations. remove primary gear and woodruff key - might be a sleeve there to remove also. some yamaha have o-ring on primary shaft. remove oil seal. reinstall oil seal. reassemble in reverse order. pay attention to primary sleeve direction - some have chamfer (chamfer goes inboard). careful on lining up clutch basket 2 'notches' in back. make sure clutch basket is fully seated on the kicker and primary gear.
