1. eNewsletter Sign Up
Dual cooling fans? 950 ADV
Discussion in 'Dakar champion (950/990)' started by Rapid Dog, May 19, 2009.
  1. Rapid Dog
    Rapid Dog bikes, booze, broads...
    Oct 28, 2003
    10,464
    Strangel Living West of Hell, SoCal
    #41
  2. SS in Vzla.
    SS in Vzla. Totally Normal? I'm not!
    Dec 31, 2006
    1,231
    Sugar Land, TX
    I was looking for a smaller diameter one (aprox 4.5") in order to make fitment easier, but this is what Ryan Watnem at Universal Parts answer to my inquiry
    So I guess, I'll just go and order that one, after all RCruiser already showed us it can fit in there :thumb
    #42
  3. tahoeacr
    tahoeacr Long timer
    Jan 7, 2007
    2,266
    Lake Tahoe
    500K+ Daytona Prototype with a 400K GT car behind it and guess what we use?
    backside of first car
    #43
  4. tahoeacr
    tahoeacr Long timer
    Jan 7, 2007
    2,266
    Lake Tahoe
    There is aluminum sheet that works good but notice how thick it is. Never work with stock airbox in there.
    Now back to our regular programming.
    #44
  5. DakarBlues
    DakarBlues One-everythinged man
    Dec 12, 2005
    1,427
    The pink lake less circled
    what are those two translucent cables on the right hand side going by the lower frame spar?
    #45
  6. Rapid Dog
    Oct 28, 2003
    10,464
    Those are his carb synch tubes coming from the throttle bodies to a home-made synchronizer.
    I wish someone would show me exactly where to hook my Twinmaster up...:huh
    #46
  7. gweaver
    gweaver NorCal is Best Cal! Supporter
    Aug 20, 2005
    3,526
    Sonoma County, CA
    Looks like he's synching his carbs. I'd guess they run to his manometer (on the yard stick). Two tubes filled with fluid- one connected to each carb, and engine vacuum moves the fluid. Cheaper than the store-bought units, and probably just as accurate.
    G
    #47
  8. RCruiser
    RCruiser Jus' Watchin'
    Feb 27, 2007
    221
    ...sept those aren't carbs in there!
    Hey Tahoe, how ya been, and did you ever get the P3 top finished and working well?? (you see how mine ended, or didn't!?)
    RC
    #48
  9. K2m
    K2m ....58....
    Feb 27, 2005
    2,238
    Sydney Australia
    ATF fluid, 1 tube= 2 ends connected to inlet manifolds
    [​IMG][/IMG]
    #49
  10. SS in Vzla.
    Dec 31, 2006
    1,231
    Sugar Land, TX
    If anybody is interested I found a SPAL 4" fan:
    VA32-A101-62A Fan 4" (pull) SPAL Part # 30103018
    I ordered it instead of the 5.5" because I reasoned that besides being easier to fit, the smaller diameter fan would restrict less airflow when the fan is not turned on (thus requiring less "fan work") am I making any sense ?
    Oh well, it's on it's way, so that's what my bike will have.
    #50
  11. tahoeacr
    tahoeacr Long timer
    Jan 7, 2007
    2,266
    Lake Tahoe
    Made the cover on top(not in the picture) and it's still down 2hp from my other airbox. Haven't had a chance to go back to the dyno. Want to try and see if I can get it to help in the mid range some.
    #51
  12. Rapid Dog
    Oct 28, 2003
    10,464
    Which mounting straps or brackets did you order?
    Not sure how this works...
    Do you just tap into the existing fan's wires?
    #52
  13. SS in Vzla.
    Dec 31, 2006
    1,231
    Sugar Land, TX
    :huh
    I ordered these ones from the same place I bought the fan (A1 Electric) and these ones from Universal Parts Inc which I reckon are similar to the ones used by Pyndon.
    Note that A1 Electric had some pin-style mounts (metal) that looked easier to install just by threading them through the radiator core, but when you go to SPAL's web site they say that the system is sure to cause problems in the long run by rubbing on the radiator (and it's a SPAL product :huh)
    I'm not sure which is gonna work, but since I can't get any brackets here at home, I just took a wild guess. If none of them work, I'll just fabricate some kind of metal bracket, it's not too complicated. The fan is very light.
    Yes, I plan to tap into the existing fan's wires so that they both turn on/off at the same time
    #53
  14. Rapid Dog
    Oct 28, 2003
    10,464
    O.K., ordered from A-1 Electric:
    30103018 Spal 4" Fan (pull) $59.95
    30130011 Fan mounting brackets & Straps (4) $16.96
    That said, what's the correct thermocouple to order to kick the fan on sooner?
    Where do yuo find one?
    #54
  15. viatormundi
    viatormundi Citizen of the world
    Apr 24, 2005
    644
    Mallorca-Spain
    Is it possible to put a second fan in 990 Adv?
    #55
  16. mookymoo
    mookymoo Mookish Mook
    Aug 26, 2007
    4,430
    Either UK or Australia ...
    I cant see why it would be any different to the 950 Adv...
    #56
  17. PG007
    PG007 AKA backdoorphil
    Sep 22, 2007
    323
    Chaiyapum, Thailand
    same mounting straps are $3.99 here (instead of $16.96 at A-1)
    http://www.siliconeintakes.com/product_info.php?products_id=1005
    #57
  18. Rapid Dog
    Oct 28, 2003
    10,464
    Those are not the same. I opted out of the spike type because they say they definitely wear on the radiator after a while.
    I got these...
    #58
  19. Gluaisrothaí
    Gluaisrothaí Feckin' gobshite
    Sep 22, 2007
    565
    Alameda, CA
    I thought about putting some heatshrink on the spikes to avoid abrasion.
    Your thoughts?
    Ken
    #59
  20. Rapid Dog
    Oct 28, 2003
    10,464
    Prolly work, but maybe not forever. Radiators are made of soft metal, I'm surprised they actually offer that kind of mount.
    #60
