Dual cooling fans? 950 ADV
Discussion in 'Dakar champion (950/990)' started by Rapid Dog, May 19, 2009.
  1. mookymoo
    mookymoo Mookish Mook
    Aug 26, 2007
    4,430
    Either UK or Australia ...
    Nope. Unless youre already drawing heavily on the electrical system.
  2. mookymoo
    Aug 26, 2007
    4,430
    Did you have it overheating a lot before that?
    Overheating means all 7 bars flashing...
    I know that even with the 2nd fan, its still possible to overheat the bike in the right conditions (pyns bike did it in the african sand...).
    But the riding conditions you mention above ... I wouldnt have expected to overheat the bike...
    The only time my bike has overheated was (ironically) just after I installed the 2nd fan. I didnt know it at the time, but the reason for my situation was nothing to do with the conditions. My problem was that my coolant level was really low.
  3. mookymoo
    Aug 26, 2007
    4,430
    You shouldnt need to chop anything. Just remove the rectangular shroud.
    I fit an EXC fan to mine - 2nd-hand, looked just like yours.
  4. kizniche
    kizniche pyro
    Jun 25, 2009
    170
    Georgia
    It hasn't overheated a lot, but as I've said previously, it's a pain when it does and I have to wait for it to cool down to ride again. Also, It's usually in extremely hot weather when moving is the only thing on my mind. When it happens I can feel a negative change in how the engine performs. I'm still and will always be considering the effectiveness of this system, and will alter it if needed.
  5. Trailtwister
    Trailtwister To the peak!
    Aug 13, 2009
    502
    Salt Lick City
    That's a good question.
    My pal's 990 has a different type of front radiator protector than my 06 950. The 990 is more like vanes, like a regular dirtbike, but the 950 is sheetmetal with punched holes.
    I wonder if the thermostat, temperature fan switch, water pump are the same part numbers... I'll do a little checking and report back to yous.
    BTW, sometimes my overtemp light comes on and the fan is not on!! WTF? Obviously the temp sensor and the fan switch are mounted at different places, but they should play together more nicely.
    Also, bleeding the air out seems important. I bled the air from the cooling system per the owner's manual. Then rode the bike and it boiled over. The catch bottle still had coolant above the min line, but it seemed to overheat more easily. Bled the air again. It required a lot of coolant to displace the trapped air, like 12 ounces!
    So it seems if it boils, ya can't just add coolant. Gotta bleed the air too.
    What say the Collective?
  6. Trailtwister
    Aug 13, 2009
    502
    Salt Lick City
    KTM seems to change the PN for all years when new parts are released. For example, the front shroud PN is the same between the '05 and the '09. But my 05 definitely looks different than the picture. Also most of the descriptions include " '03 ".
    Anybody have an original paper parts manual for an 03 - 06 950? Here's the '09 and '05 PNs from AllAmerican KTM. They're all the same:
    <TABLE style="WIDTH: 375pt; BORDER-COLLAPSE: collapse" cellSpacing=0 cellPadding=0 width=500 border=0 x:str><COLGROUP><COL style="WIDTH: 152pt; mso-width-source: userset; mso-width-alt: 7224" width=203><COL style="WIDTH: 49pt; mso-width-source: userset; mso-width-alt: 2304" width=65><COL style="WIDTH: 89pt; mso-width-source: userset; mso-width-alt: 4238" width=119><COL style="WIDTH: 85pt; mso-width-source: userset; mso-width-alt: 4010" width=113><TBODY><TR style="HEIGHT: 13.2pt" height=18><TD style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; WIDTH: 152pt; BORDER-BOTTOM: #ece9d8; HEIGHT: 13.2pt; BACKGROUND-COLOR: transparent" width=203 height=18></TD><TD style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; WIDTH: 49pt; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" width=65></TD><TD style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; WIDTH: 89pt; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" width=119>2009 990 Adv-R</TD><TD style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; WIDTH: 85pt; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" width=113>2005 950 Adv-S</TD></TR><TR style="HEIGHT: 13.2pt" height=18><TD style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; HEIGHT: 13.2pt; BACKGROUND-COLOR: transparent" height=18>Descrip</TD><TD style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent">Find #</TD><TD style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent">PN</TD><TD style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent">PN</TD></TR><TR style="HEIGHT: 13.2pt" height=18><TD class=xl24 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; HEIGHT: 13.2pt; BACKGROUND-COLOR: transparent" height=18><FORM id=aspnetForm name=aspnetForm action=default.aspx method=post>RADIATOR PROTECTOR 03
    </TD></FORM>
    <TD class=xl24 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" align=right x:num>50</TD><TD class=xl24 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" align=right x:num="60035040000"><FORM id=aspnetForm name=aspnetForm action=default.aspx method=post>60035040000
    </TD><TD class=xl24 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" align=right x:num="60035040000"><FORM id=aspnetForm method="post" action="default.aspx" name="aspnetForm">60035040000
    </TD></TR><TR style="HEIGHT: 13.2pt" height=18><TD class=xl24 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; HEIGHT: 13.2pt; BACKGROUND-COLOR: transparent" height=18><FORM id=aspnetForm method="post" action="default.aspx" name="aspnetForm">FAN COWL L/S 03
    </TD></FORM>
    <TD class=xl24 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" align=right x:num>51</TD><TD class=xl24 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" align=right x:num="60035044000"><FORM id=aspnetForm name=aspnetForm action=default.aspx method=post>60035044000
    </TD></FORM><TD class=xl24 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" align=right x:num="60035044000"><FORM id=aspnetForm name=aspnetForm action=default.aspx method=post>60035044000
    </TD></TR></FORM>
    <TR style="HEIGHT: 13.2pt" height=18><TD style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; HEIGHT: 13.2pt; BACKGROUND-COLOR: transparent" height=18>Fan</TD><TD class=xl24 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" align=right x:num><FORM id=aspnetForm name=aspnetForm action=default.aspx method=post>54
    </TD><TD class=xl24 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" align=right x:num="60035041000"><FORM id=aspnetForm method="post" action="default.aspx" name="aspnetForm">60035041000
    </TD></FORM>
    <TD class=xl24 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" align=right x:num="60035041000"><FORM id=aspnetForm name=aspnetForm action=default.aspx method=post>60035041000
    </TD></TR></FORM><TR style="HEIGHT: 13.2pt" height=18><TD class=xl24 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; HEIGHT: 13.2pt; BACKGROUND-COLOR: transparent" height=18><FORM id=aspnetForm name=aspnetForm action=default.aspx method=post>THERMOSWITCH LC8 102DG '03
    </TD></FORM>
    <TD class=xl24 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" align=right x:num>45</TD><TD class=xl24 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" align=right x:num="60035045000"><FORM id=aspnetForm name=aspnetForm action=default.aspx method=post>60035045000
    </TD></FORM>
    </TD></TR></FORM><TR style="HEIGHT: 13.2pt" height=18><TD class=xl24 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; HEIGHT: 13.2pt; BACKGROUND-COLOR: transparent" height=18><FORM id=aspnetForm name=aspnetForm action=default.aspx method=post>THERMOSTAT 75° CPL. W. CASE 03
    </TD></FORM>
    <TD class=xl24 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" align=right x:num>22</TD><TD class=xl24 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" align=right x:num="60035017000"><FORM id=aspnetForm name=aspnetForm action=default.aspx method=post>60035017000
    </TD></FORM>
    </TD></TR></FORM><TR style="HEIGHT: 13.2pt" height=18><TD class=xl24 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; HEIGHT: 13.2pt; BACKGROUND-COLOR: transparent" height=18>RADIATOR CAP SMALL 20,3 PSI</TD><TD class=xl24 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" align=right x:num>2</TD><TD class=xl24 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" align=right x:num="58035016000"><FORM id=aspnetForm name=aspnetForm action=default.aspx method=post>58035016000
    </TD></FORM>
    </TD></TR></TBODY></TABLE></FORM>
  7. SS in Vzla.
    SS in Vzla. Totally Normal? I'm not!
    Dec 31, 2006
    1,231
    Sugar Land, TX
    From your description, it seems your 06 950 has the KTM Hard Parts Rad Protector http://www.ktmtwins.com/950adventure/60035040100.html instead of the OEM plastic one... Someone must have swapped it somewhere down the bike's life.
  8. Trailtwister
    Aug 13, 2009
    502
    Salt Lick City
    Ahh, good eye. Hopefully better than the plastic one.
    Still curious if KTM changed any of the cooling system parts from '05 to '09 or '10.
  9. mookymoo
    Aug 26, 2007
    4,430
    Yes, the impeller and housing have changed in '09.
    There are some posts on here about it here with some comparison pics.
  10. killurtv
    killurtv free range moron
    Aug 26, 2008
    640
    central oregon
    My Bike over heated in the Nevada desert this September, temps in the 90's with lots of hill climbing at speeds in the 20-30 mph range. I actually "cooked" the oil, took the filter out and it was like "pudding" on the filter. Upon closer inspection of the bike I found that a mouse had built a nest around my air filter restricting air flow! Strange thing was though, the bike never got above 5 bars on the temp gauge!!! I am going for the dual fans and checking my air box more often when out on trips!! Thanks for all the great info and pics!!:clap
  11. Bronco3738
    Bronco3738 Mike
    Jun 19, 2009
    505
    Just South of Phoenix, Arizona
    I don't think that "pudding" is from overheating. Sounds more like your water pump is going. Extreme overheating results in black oil. Pudding as you state is usually water in oil.
  12. Autostream
    Autostream Long timer
    Aug 1, 2005
    5,833
    Belgrave, Victoria, Australia
    I agree, sounds like the dreaded "spooge" due to water pump failing to me.
    If it was getting hot enough to cook the oil and the dual fans were going to help then your temp guage would have been getting much higher than 5.
    5 is just normal temp.
  13. catalina38
    catalina38 Long timer
    Oct 24, 2006
    1,842
    Stingray bay CA.
    Temps in the 90's, slow speeds, climbing hills, fan coming on and it never got above 5 bars?
    Sounds like your cooling system is working perfectly. Excerpt for the water in the oil part:huh
  14. killurtv
    Aug 26, 2008
    640
    central oregon
    This is what I thought as well, but when I got back from the trip (rented u-haul to get bike back) I did not have time to look into it myself so I dropped bike off at the dealer, told him my thoughts, water in the oil, he dug into it and said no sign of water. I have been riding it hard since then and it is fine so far, but I am paranoid about the water pump, I have 24,000 miles on the bike, so it is getting rebuilt this winter.
  15. brewer90
    brewer90 Been here awhile
    Dec 13, 2004
    762
    Livermore, CA
    This heat wave has my fan running more than ever in stop and go traffic so I did a search and ran across this thread. I found a guy on ebay selling the SPAL pull fans in this thread for $38 shipped which is about $25 less than any other place I found. I bought mine on Tuesday and received it on Friday. Brand new. I don't know him but thought I'd pass on the info in case anyone else stuck in hell is thinking about this mod.
    http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=190557264240&viewitem=&sspagename=ADME%3AL%3AOC%3AUS%3A1123
  16. dad2bike
    dad2bike Retired! Cranky Old Fart Supporter
    Aug 12, 2007
    16,504
    Las Vegas, NV
    I think that's the seller I got mine from long ago. Glad to see they are available again. :clap
  17. Uller
    Uller Done with this BS
    Jun 18, 2008
    1,595
    In a town, FU
    Thanks for the link! :clap
  18. Grayjet
    Grayjet Ride on!
    Jun 14, 2008
    627
    Va Beach
    Thanks for the link, Brewer. I just received mine and plan to add this to my new-to-me 990. I have a question about the wiring, though. Where are you guys tapping into the bike's harness? Downstream of the left side fan plug? That seems to be what Pyndon alluded to in his post, but I am not sure. I assume there is enough current flowing through that plug to run both fans without issue. True? Wiring just isn't my gig.
    Thanks for any help you can provide (and any pics!).
    Lance
  19. bikyto
    bikyto Dans le doute...gaz!
    Jun 15, 2009
    2,348
    Northern Cali
    Sorry no pix right now but yes you can tap into the left one. Works just fine!
  20. SS in Vzla.
    Dec 31, 2006
    1,231
    Sugar Land, TX
    That's where I wired mine. Been working perfectly for over a year.
