Ducati Monster Muff on a DR650
Discussion in 'Thumpers' started by SeanF, May 11, 2010.
  1. SeanF
    SeanF Long timer
    Jun 11, 2004
    2,280
    Tucson Arizona USA
    I wanted to reduce the weight & bulk of the DR650 exhaust while maintaining a relatively low noise volume. I did a dry fit of a muffler from a wrecked '94 Ducati Monster 900 and figured it could be made to fit. The 80 dB rating helps too.
    First, I cut off the midpipe from the stock DR exhaust. This will make it easier to mount the finished product to the header pipe.
    The intake end of the Ducati muff turns inward at a pretty good angle...too much to meet the DR midpipe. So I cut it off as well, with the intent to rotate & have it re-welded in the correct position.
    After dry-fitting the peices, and measuring for clearance from the tire, swingarm and brake caliper, a friend with the necessary skills welded it all up. I made a simple hanger from galvy steel.
    Result
    I painted the section forward of the muffler with silver heat resistant paint, which for some reason turned a brown/bronze color.
    Under the hanger strap is a few turns of muffler repair tape to separate the steel of the strap from the aluminum muff body.
    Snug fit.
    The stocker weights 13.2 lbs, this one 7.9 lbs. And it sounds great! :clap
    Cheers
    Sean
  2. Fubars
    Fubars What would Scoobydo?
    Aug 20, 2003
    2,058
    Ventuna, California
    Nice job. I like it.
    Now for the dumb question--is it louder than stock?
  3. Ben99r1
    Ben99r1 Long timer
    Mar 2, 2006
    3,114
    Pomona, Calif.
    Does it have a spark arrestor? Ben
  4. SeanF
    SeanF Long timer
    Jun 11, 2004
    2,280
    Tucson Arizona USA
    To my ear it is the same volume as stock.
    Good question about the spark arrestor. Do street bike muffs have them?
    Sean
  5. TexBiker
    TexBiker Been here awhile
    Oct 4, 2006
    815
    East Texas
    Every can I've seen with a spark arrestor was marked "USFS Approved". Not sure if that's a universal thing or not.
