Ducati MultiStrada 1200
Discussion in 'Moto Bellissima: All Other Dualsports' started by Paulvt1, Sep 10, 2008.
  1. asphaltsurfer1
    asphaltsurfer1 CatManDew
    Jun 24, 2011
    544
    By the pool
    950S was what I saw at COTA last month with spiked wheels
    Kavalier likes this.
  2. expatbrit
    expatbrit Still pretty much a n00b.
    Dec 10, 2009
    1,105
    Duke City, NM
    So. It appears that they’re no longer available. I have a 2011 S, and the guards are the Ducati Performance racing or Enduro or something. Full aluminium bar that connects to the bar end and the master mount.
    They do. Of course. Totally preclude the use of an RCS clutch master. The angled design of the ‘semi-radial’ appears unique to the MTS afaik so stuck with that. And that ‘clutch pump’ is sodding expensive (NOT $200!) so that’s a thing.
    Grumpy now! And it’s too early for a beer to salve my battered soul
  3. expatbrit
    Dec 10, 2009
    1,105
    Duke City, NM
    Boudicca multistrada! Spikes!!! :)
  4. Kavalier
    Kavalier Dorkar Adv Poseur
    Feb 15, 2014
    121
    the Pacific Northwet
    An early prototype
    asphaltsurfer1 likes this.
  5. Tripped1
    Tripped1 Smoove, Smoove like velvet.
    Aug 6, 2009
    33,172
    Nippon
    https://www.revzilla.com/motorcycle/brembo-rcs-hydraulic-clutch-master-cylinder
    I did note 100 dollars more than a rebuild.
  6. expatbrit
    Dec 10, 2009
    1,105
    Duke City, NM
  7. asphaltsurfer1
    Jun 24, 2011
    544
    By the pool
    LOL. Wondered if I’d get comments
  8. expatbrit
    Dec 10, 2009
    1,105
    Duke City, NM
    The temptation was way too much. Even when you know os just a slight typo.
  9. Tripped1
    Aug 6, 2009
    33,172
    Nippon
    Your right of course. And that is to facilitate the handgards
  10. expatbrit
    Dec 10, 2009
    1,105
    Duke City, NM
    “Hooray”.
  11. Baggi'tard
    Baggi'tard If I don't answer I'm ridin' or shootin' Supporter
    Sep 20, 2006
    3,476
    Farmhouse Inn, Tellico Plains, TN
    Question for the group. Anybody have a tip, or otherwise had luck, getting a tubeless tire with "too narrow" of space between the beads to take air and mount onto the rim? I got a tire today that seems to have gotten kind of squished by the banding during shipping, or is just made with the beads close to each other (as an unmounted tire). When I put the thing on the rim, there was just almost no natural force of the tire wanting to push outward, so I just couldn't get enough air in it to get it to mount. I took it back off and am just going to let it sit and see if it recovers, but barring that, WTF.
    I guess I might try taking the valve out of the stem and using my air nozzle (which also has a rubber tip) to get more air in quicker, but who knows.
  12. Samtech79
    Samtech79 Two wheeled lunatic
    Feb 27, 2014
    1,401
    NorCal
    Put a ratchet strap around the middle of the tire and squeeze it around its circumference. Makes it spread out a little.
    Yossarian™ and Revolve like this.
  13. Baggi'tard
    Sep 20, 2006
    3,476
    Thanks, two guys on my Husaberg thread said same on the ratchet strap so I'll try that. Kinda makes sense as I was able to gain a little by pushing the tire and bouncing it a bit while airing it up, just wasn't enough. I use my NoMar lube, usually tires bead up at like 5-10 psi, so that wasn't an issue. Maybe if I let that thing heat up in the sun it will relax back into shape a bit.
  14. BobcatSig
    BobcatSig They call me... Huckajawea
    Aug 15, 2014
    3,602
    Protestlandia, OR
    You can also remove the valve core and get air in there much faster. Once the bead is set, air the tire down and install the core and air up to desired pressure.
  15. Baggi'tard
    Sep 20, 2006
    3,476
    Yeah, but my air chuck only works when opened by the valve stem, so I'll try the air nozzle when I do it again probably.
    BobcatSig likes this.
  16. Frank_Jameson
    Frank_Jameson n00b
    May 19, 2019
    9
    Jackson County
    Hello all. I have been reading through this thread, but 384 pages takes a minute. I have been eyeballing some 2010-2012 multis and was wondering if there is anything in specific to be aware of or specifically ask the seller about. Also, how bad is the maintenance to do yourself? I have had an SV650 for 11 years, but my aging body can't deal with those ergos for very long any more, and this looks like the ticket. The bump up in power has absolutely nothing to do with it.:hide
    ETA: I'm 6'4" 35 years old with the body of a 55 year old. (Thanks Army.)
  17. Baggi'tard
    Sep 20, 2006
    3,476
    They aren't any "harder" to work on than any other brand of motorcycle. You will be learning "how many screws" does it take to hold body work on though. Off the top of my head I don't think of anything specific to ask, other than has the maintenance and upkeep been done, and what't the overall condition of the bike? Oh, make sure you get all the keys and codes. Personally I'd prefer a well used, and well maintained and well loved bike over a garage queen that sits on a trickle charger all the time.
  18. expatbrit
    Dec 10, 2009
    1,105
    Duke City, NM
    Coolant swap? There were some of those that are their heads and exhaust valves (DAMHIK). Never was sure if it was miles or age. I’d think you’d know on a 2010 or 2011 by now though
  19. Tripped1
    Aug 6, 2009
    33,172
    Nippon
    Getting the tank off is a major PITA otherwise the valve/blet maintenance isn't really any harder than a traditional shim under bucket...though getting to the vertical head is sort of a "who thought this was a good idea" type of deal. Its nothing too crazy.
  20. Baggi'tard
    Sep 20, 2006
    3,476
    Thought it was actually a bad batch of coolant thing, like it was acidic, and wasn't it only the earliest 2010 models? I don't recall either specifically, but would agree it would have been taken care of by now.
