Ducati MultiStrada 1200
Discussion in 'Moto Bellissima: All Other Dualsports' started by Paulvt1, Sep 10, 2008.
  1. Achtung
    Achtung Wicked Pisssah Adventurer
    Nov 1, 2002
    2,648
    Waltham MA
    “Bike is in great condition body has small scratches. The big thing is that the timing belt snapped on it and the top end of the motor needs to be replaced. Other than that great bike. Garage kept all winter.”
    Ouch. I think this guy is dreaming if he thinks this bike is worth 8k with a busted motor.
    26,000 miles
    BobcatSig likes this.
  2. Motodisiac
    Motodisiac Moto Terrorist
    Jan 13, 2006
    3,951
    City Of Angels
    Lol. It's worth 8k with a running motor.
    Tripped1 and Achtung like this.
  3. Tripped1
    Tripped1 Smoove, Smoove like velvet.
    Aug 6, 2009
    29,642
    Nippon
    I paid 1100 for my last desmo service, that also included the valve/belts as well as new tires AND a chain.
    $1500 should only happen if they need to shim everything.
  4. Tripped1
    Aug 6, 2009
    29,642
    Nippon
    Two years ago the NADA value of my Pikes was over $15,000 bank counter offered me more than I asked for buying it.
  5. expatbrit
    expatbrit Still pretty much a n00b.
    Dec 10, 2009
    932
    Duke City, NM
    I’m paying significantly more than that even at NM shop rates. I think last one was $1700, actually, though not at the Duc dealer.
  6. Tripped1
    Aug 6, 2009
    29,642
    Nippon
    You bought all of their tools then. The dealer I used to use In Albuquerque shut down years ago (PJs) no idea what is left without going up to Denver.....the shops in El Paso where all shit.
  7. Achtung
    Nov 1, 2002
    2,648
    Waltham MA
    Haven’t heard of any Multistradas actually breaking the timing belts, although I haven’t been paying much attention. Any chance that the valves just need replacing or is it much more likely the cylinder, head and piston are all destroyed?
  8. BobcatSig
    BobcatSig They call me... Huckajawea
    Aug 15, 2014
    2,508
    Protestlandia, OR
    Homeboy probably never ever changed the belts.
    Achtung likes this.
  9. expatbrit
    Dec 10, 2009
    932
    Duke City, NM
    I used to use PJs — they were just down the street, but they weren’t cheap either. Then had Desert Desmo do it.
    I know they had the tooling :) did a good job. I actually take it to Triumph now because of the crew there — it’s a lot of the old PJ people who I have personal relationships with
  10. smokeeater495
    smokeeater495 Been here awhile
    Oct 14, 2008
    655
    Melbourne, Florida
    Has anyone done a Decat on these bikes? I have a 2011 Multistrada S Touring. Looking to reduce heat back by the rear brake reservoir as it's really hard on the brake fluid. Will this require ECU reflash?
  11. Florida Lime
    Florida Lime Long timer Supporter
    Sep 5, 2008
    8,548
    As stated and not often enough in Robbinsville, NC
    I did the full system Termignoni on my 2016 1200S Touring, which replaces the cat. It came with the up-map key, so I'd say any decat would require the ECU flashed to accommodate the differences in fuelling. Made an impressive difference with mine.
  12. Motodisiac
    Jan 13, 2006
    3,951
    City Of Angels
    I hear the argument about brake fluid getting hot because it's near the cat all the time. I honestly doubt it's a factor. Even the cheapest brake fluid has a boiling point of about 450 degrees F. It's designed to get got. I doubt brake fluid reservoir located 5-6 inches from the cat that is partially covered by the heat shield can get more than lukewarm hot. Rear brake in the Multi simply sucks because it's poorly designed. Bleed it often and remove caliper when you bleed.
    By the way I used to run decat (for other reasons) and while the bike runs marginally better with proper mapping it was deafening. I'm back to stock cat with different maps, still runs as good, not crazy loud and I'm not polluting. Win Win Win .
    shil likes this.
  13. Lee113
    Lee113 Been here awhile
    Sep 20, 2018
    107
    Rio Rancho, New Mexico
    Charlie, you’ll need to check out my new replacement for the GS... :-)
    Lee
    SMIFFXC likes this.
  14. BobcatSig
    Aug 15, 2014
    2,508
    Protestlandia, OR
    Yes. Mine came with the full Termi + upmap. I know others who have used the Leo Vince mid-pipe and kept the OEM tips. Most did a re-map. Worth it.
    I noticed my rear brake fluid much longer. But then again, this is a sport bike with monster front brake and I rarely need to use the rear brake.
    Eww, gross. Wrong thread. :D
  15. expatbrit
    Dec 10, 2009
    932
    Duke City, NM
    Haha!
    I figured that was you. :) I’ll look forward to seeing it soon.
  16. SMIFFXC
    SMIFFXC Been here awhile
    Mar 23, 2012
    311
    Maine
    We lost our local dealer a couple years ago. It's way to far to the next nearest one so if I ever replace my Multi I believe this will be the bike. Love this paint scheme. Enjoy.
  17. Baggi'tard
    Baggi'tard If I don't answer I'm ridin' or shootin' Supporter
    Sep 20, 2006
    3,167
    Farmhouse Inn, Tellico Plains, TN
    I "think" you might be on the wrong bike thread..:bash
  18. Samtech79
    Samtech79 Two wheeled lunatic
    Feb 27, 2014
    1,393
    NorCal
    +1 on the termi and upmap. Runs better, seems to throw off less heat too.
  19. Tripped1
    Aug 6, 2009
    29,642
    Nippon
    The Upmap sucked on my bike with the full tremi
    Felt like it had carbs with the pilots too big, bogged and coughed till 3500-4000rpm then went lean and took off smoothly.
    I added a bleeder to the rear circuit on the ABS module (amusingly the the original caliper bleeder from the crappy P4s) and my bakes very rarely need to be bleed.
  20. expatbrit
    Dec 10, 2009
    932
    Duke City, NM
    Did it fit under the seat? I tried that with a speed bleeder and ended up having to totally rebleed at the caliper after replacing it with the stock banjo
