Dumb question about the crash bars, can I run with out?
Discussion in 'Dakar champion (950/990)' started by dino1, Jan 9, 2020.
  1. dino1
    dino1 Been here awhile
    Aug 3, 2010
    629
    cen tex
    Getting my bike back up and running, took me several months to check the valves and get the bike back together : (
    Yes it is shameful.
    Need to get it off the stand and burp the coolant and get the throttle bodies balanced.
    Thinking of running with out the crash bars for a bit while I get that sorted.
    Bike will see mostly commute duties for a bit as well. Also shameful.
  2. cjracer
    cjracer AWD please!!
    Sep 26, 2005
    4,050
    Mukwonago, WI
    Yes. Ride it
    gearheadE30 likes this.
  3. Salzig
    Salzig Long timer
    Oct 17, 2008
    1,677
    Cremona, Italy
    You should.
    And never put them back on :D
    Simosez and gearheadE30 like this.
  4. bobone
    bobone Been here awhile
    Jul 7, 2016
    274
    italy
    yes
  5. NitroAcres
    NitroAcres MotoBiggots Suck Supporter
    Mar 28, 2010
    1,206
    A ChickenHouse in NorthGeorgia
    Mine have been off for over two years..moved my LEDs off the crashbars and replaced with short lightbar under the headlight.
    Whodatschrome likes this.
  6. gearheadE30
    gearheadE30 @LC8Adventures
    Jan 20, 2012
    2,251
    Indiana
    Yep, go ride it. These things crash just fine without them, plus it is weight (and width) reduction! :lol3
  7. DirtyADV
    DirtyADV Long timer
    Jan 13, 2007
    4,398
    SWEDEN, Norsjö
    The only things they are good for is mounting highway pegs and making maintenance a headache!
    /Johan
  8. Hipster
    Hipster Long timer
    Aug 31, 2004
    2,572
    Mpls, Mn.
    I like crash bars, my crash bar bags is where I carry my spare tube, 12v pump and tools. It keeps the weight down low.
    #8
  9. DirtyADV
    DirtyADV Long timer
    Jan 13, 2007
    4,398
    SWEDEN, Norsjö
    Forgot mounting points, also adds some weight
    Might also help that bike is not as flat if tipped over... BMW boxer light
    /Johan
    #9
  10. crazybrit
    crazybrit Long timer
    Mar 16, 2006
    9,009
    Portland, OR
    Is it a 990 or a 950? I think on the 990 the immobilizer will kick in if the OEM crash bars are removed. I think you can cut a wire to work around it.
    #10
    cjracer, NitroAcres and Whodatschrome like this.
  11. DirtyADV
    DirtyADV Long timer
    Jan 13, 2007
    4,398
    SWEDEN, Norsjö
    Must be something on only bikes with the handlebars on the right side have
    Normal 990s for driving on the right side of any road work fine without crash bars.
    You can actually remove a whole lot of stuff and it will still run.
    And the OEM plastic protectors do a great job but will need replacement after a hard slam into the pavement and a long slide down the black stuff.
    /Johan
    #11
    gearheadE30 and Salzig like this.
  12. albani
    albani Been here awhile
    Jan 3, 2017
    228
    SF Bay
    Yeah ditch em. The tanks are fiberglass reinforced nylon. The SW-Motech bars add a good 15lb to your bike. They make an otherwise fairly easy wrenching experience a mild frustration. Numerous threads on this topic here as well.
    I just bought the 990 skids. The only reason the crashbars are still on this bike is to protect the tufflic orange paintwork. The skids will be for desert operation as crashbars only add to the heft that has to be hoisted out of the sand. Crashbars will be retained for tarmac use.
    #12
