Sold EccoTemp Mini Hot Water Heater - Brand New
Discussion in 'Other' started by Jolly Roger, Oct 6, 2019.
Thread Status:
Not open for further replies.
  1. Jolly Roger
    Jolly Roger Been here awhile
    May 29, 2008
    806
    British Columbia
    New in Box EccoTemp EM-4.0 Mini Tank Water Heater.
    Located in Surrey, BC, Canada (pick up only)
    SOLD THANKS
    The Eccotemp Mini Tank 4.0 water heater is a larger form of the EM-2.5 Point-of-Use mini tank water heater with a holding tank capable of holding 4.0 gallons that is designed to supply instant hot water on demand to any faucet without long hot water pipe runs or to supply a stand alone sink or faucet instantaneous hot water without wait. It can be used in most under the counter, point of use applications. The EM-4.0 is designed to supply hot water for all hand wash and kitchen sinks in a residential, commercial or industrial environment. The EM-4.0 can replace traditional central hot water heaters thereby conserving water and reducing energy waste. The EM-4.0 can also be plumbed in series with the central water heater and act as a booster. It is lightweight and compact and manufactured for easy installation. It can be mounted on the wall with included hardware, or freestanding and is designed to operate at 150 psi maximum water pressure. Install a pressure reducing valve if your water pressure is greater than 150 psi.
    - Tank Volume: 4.0 gallons
    - Heating Capacity 1440 Watts
    - Easy installation with 120V outlet plug
    - Point-of-use, ideal for under the sink providing instantaneous hot water
    - Adjustable temperature range 50F to 140F
    - No need for costly re-circulating lines and pumps
Thread Status:
