    Dismiss Notice
Electric bicycles
Discussion in 'Shiny Things' started by configurationspace, Mar 19, 2015.
  1. MrBob
    MrBob Cisgendered Supporter
    Oct 27, 2005
    22,645
    Tallahassee, FL
    This guy has electrified a number of Townies, which is essentially the same frame as my cruiser.
    #61
  2. liberpolly
    liberpolly Lazy rider
    Sep 21, 2015
    6,719
    Seattle
    Did you try conductive glue? http://www.thinkgeek.com/product/b70c/
    I didn't try it myself, but I know it exists :)
    #62
  3. liberpolly
    Sep 21, 2015
    6,719
    Seattle
    I would be very hesitant to electrify a bike without suspension and disk brakes. Maybe something light, like 250W front hub?
    #63
  4. spagthorpe
    spagthorpe Long timer
    Aug 9, 2002
    18,949
    San Diego
  5. ctromley
    ctromley Long timer
    Oct 18, 2012
    1,180
    PA
    You don't want to do that. When talking about "conductive" with respect to glues, pastes, films, etc., both electrically and thermally, that actually means "bad insulator." It's significantly better than no connection at all, but not much. Read the specs carefully and compare them to copper and you'll see what I mean.
    With the amps a battery pack needs to dish out, "conductive" glue is asking for trouble. Its relatively high resistance will heat up the interconnect and put the entire pack at risk of fire. Or crack and separate over time and compromise the pack. Spot welding is the only way to go.
    #65
  6. 2whlrcr
    2whlrcr gooligan
    Jan 30, 2005
    16,027
    Dubuque, Iowa
    I like to suffer. But I want a small hidden motor in my frame, so I can make my competitors suffer more.
    #66
    garrett likes this.
  7. MrBob
    Oct 27, 2005
    22,645
    Tallahassee, FL
    #67
  8. DriveShaft
    DriveShaft Long timer
    May 17, 2005
    5,499
    Personally, I'm aiming to try this with my dc power supply and the transformer from an old microwave to spot-weld the tabs on. .
    <iframe width="560" height="315" src="" frameborder="0" allowfullscreen></iframe>
    #68
  9. NikonsAndVStroms
    NikonsAndVStroms Beastly Photographer
    Jun 23, 2007
    75,737
    The Hub of the Universe
    How cheap are new electric bikes getting? I remember there was a lot of media behind that fat tire 500 dollar one but that it was too good to be true. So what's out there now? I'm wondering if selling my bike and buying a new one would be worth it VS the hassle of rebuilding it. I do love the thing and have some great memories with it but it just sits in my studio right now and my body hasn't been up to using it much. And last time I could the battery was about half of what it used to be. I can use it around town still but it's range is shrinking by the year.
    I'd be fine with specs similar to my current one.
    Range 20-30 miles
    Pedal assist (I do want this since the main point of the bike is to give my legs some low resistance exercise)
    Max speed on electricity 18 MPH
    #69
  10. DriveShaft
    May 17, 2005
    5,499
    That's generally the principle behind regenerative braking. It won't eliminiate recharging, because it consumes energy to work, so you will go slower. But it will make your battteries last longer. Or do someting useful like power a light or someting.
    If you take that idea and shrink it, you can squeeze it into the hub, in which case, you have a hub dynamo
    I've got this, which is a 14-speed gearbox, a hub dynamo, and a light:
    #70
  11. MrBob
    Oct 27, 2005
    22,645
    Tallahassee, FL
    Suspension good, extra weight bad, so it's a trade off. The V brakes on the Electra are so good that I'm having a problem with the back tire spinning on the rim under hard braking.
    #71
  12. liberpolly
    Sep 21, 2015
    6,719
    Seattle
    That one is all over cragislist now as people try to unload it for few $100 profit. https://www.electricbike.com/sondors-fat-2016-review/
    Other than that, the battery tech is advancing so fast it makes sense to buy a new one with an external replaceable battery. It seems they coalesced on 2 or 3 designs.
    I also find out that I use throttle much more than pedal assist - I can pedal most of the time without an assist, and use the throttle only on steep hills. Also, as I build muscles, I use less and less of it.
    #72
  13. MrBob
    Oct 27, 2005
    22,645
    Tallahassee, FL
    Why are people trying to unload the Sondor bikes?
    #73
  14. Cat0020
    Cat0020 El cheapo
    May 1, 2002
    6,773
    NW of Philly, Hoboken, Brooklyn.
    #74
    liberpolly likes this.
  15. SRG
    SRG Long timer
    Nov 18, 2004
    3,160
    Central Va.
    Mr. Bob - the pic of your electra shows an "s" bend in the downtube at the bottom bracket. The Townie's frame has a straight downtube. The Bafang mid drive motor wants a straight downtube. The s curve in your frame is going to stop the motor from rotating up. It's going to contact the frame and sit a low angle, dangling down like the balls of a prize winning stud goat.
    A hub drive will work/fit the electra better.
    #75
  16. liberpolly
    Sep 21, 2015
    6,719
    Seattle
    No idea, but check the craigslist, there's several of them at any given moment.
    #76
  17. SRG
    SRG Long timer
    Nov 18, 2004
    3,160
    Central Va.
    #77
  18. MrBob
    Oct 27, 2005
    22,645
    Tallahassee, FL
    Interesting, thanks for pointing that out.
    #78
  19. MrBob
    Oct 27, 2005
    22,645
    Tallahassee, FL
    How do you like that A2B? A shop in Longmont, CO has been selling them for a while and used units are coming onto the market.
    #79
  20. liberpolly
    Sep 21, 2015
    6,719
    Seattle
    Old tech and fairly heavy, and the chain is noisy, but I like it for riding the trails too fast for a bicycle and too slow for a motorcycle :) Big tires and full suspension are great. It will not pull you up the hill without you pedaling. There's no pedal assist, only throttle, which suits me fine. The battery is getting long in the tooth, and replacements are more expensive than what I paid for it used. Overall, would buy again for under $1000.
    #80
