Electric Motorcycle Armchair Engineers Discussion Thread. Truths, Half-truths, and Myths.
Discussion in 'Electric Motorcycles' started by T.S.Zarathustra, Mar 22, 2019.
  1. Mambo Dave
    Mambo Dave I cannot abide.
    Oct 7, 2011
    20,712
    11 ft. AMSL
    You got me feeling bad that I just bought a 2019 Prius. But... I'm saving fuel costs (and maintenance costs - it's not only super-economical in one area), so the environment can suck it!
    :D
    T.S.Zarathustra likes this.
  2. liberpolly
    liberpolly Nu, shoyn, nudnick!
    Sep 21, 2015
    5,278
    Seattle
    A report published in 2011 about what they think would be a 2015 model vehicle. That's your claim?
    Look, I'llt ry reasoning with you one more time. The only major part that inherently needs emitting carbon in vehicle production is the steel - adding coal to peel oxygen from the iron is an essential part of the technology. Everything else, aluminum, copper, lithium, plastics, etc. can be produced using electricity. Electricity to produce and charge the vehicles can be produced without emitting carbon - by nuclear power stations, solar, etc. So while you're trying to make an impression that electric vehicles *inherently* emit carbon, this is bullshit - the current processes that are emitting carbon exist *because* of historical reliance on fossil fuels, and are being rapidly replaced. Not rapidly enough, but still.
    diffis924 and wheresbaoskee like this.
  3. magnussonh
    magnussonh Adventurer
    May 2, 2019
    28
    Iceland
    Don't forget that batteries lose more than just capacity when they get older, they also lose the capability to maintain voltage under load. Loss of capacity only means loss of range. Loss of voltage means loss of power.
    PS. I had to look up the word. By the way it has been used here I thought it meant something different. :D
    "Snarky is a witty mannerism, personality, or behavior that is a combination of sarcasm and cynicism. Usually accepted as a complimentary term."
    "Snarky is used to describe speech with a specific emotional tone, typically a form of sarcasm informed by cheekiness and a mild, playful irreverence."
  4. T.S.Zarathustra
    T.S.Zarathustra Been here awhile
    Apr 26, 2018
    381
    Noord Holland
    Why would you feel bad about that? By the way, I have never said that electric cars, or hybrids, are bad for the environment. Just that they are not as good as some make them out to be. They pollute more when made, but pollute less while running. If you keep them running long enough, they'll pollute less than similar ICE.
    Here is a Paradox. If you keep one ICE running for much longer than another identical ICE. Then the one that runs longer will pollute more. But it will pollute less per mile than the one that ran shorter.
    Thank you for the praise. I also think they have different meaning in mind for that word. :lol3
    Do you have sources for that claim? Just kidding :jack.
    I had forgotten about that. Not only do your cells lose capacity and therefore range. They also drop the voltage under load, and as you point out, lose power. But it is even worse. The voltage drop is on top of effectively smaller capacity batteries. It's a double punch, your power will drop on top of your range reduction. Of course, if you drive slower your power loss will matter less, and your range will increase again. Maybe you're on to something.
    Mambo Dave likes this.
  5. T.S.Zarathustra
    Apr 26, 2018
    381
    Noord Holland
    Hmm, these must be wrong then.
    "In 2011 direct (process) emissions of greenhouse gas (PFCs, carbon inputs, fuels) were 1.87 tonnes of CO2-e per tonne of aluminium."
    https://aluminium.org.au/climate-change/aluminium-smelting-greenhouse-performance/
    "Several tonnes of carbon dioxide are being released, even before electric batteries leave the factory."
    https://www.thegwpf.com/new-study-large-co2-emissions-from-batteries-of-electric-cars/
  6. liberpolly
    Sep 21, 2015
    5,278
    Seattle
    From your own link:
    over 80 per cent of smelting greenhouse gas emissions are indirect (electricity-related) emissions
    From your second link:
    The calculation is based on the assumption that the electricity mix used by the battery plant is based by more than half by power generated by fossil fuels.
    Clear enough?
  7. magnussonh
    May 2, 2019
    28
    Iceland
    Basically the only sources are the pile of textbooks I had to plow through to get my degree in electrical engineering. Here are some books that some people would gain something from reading. Some I had to study, other were recommended by my professors and colla as a way of widening my knowledge of the business.
    You are right in that less speed requires less power. So you can have lighter motors and fewer batteries. This leads to lighter vehicle that increase range. Alas, too many people are blinded by "Too much power is not enough" for that to actually work.
    diffis924 and T.S.Zarathustra like this.
  8. liberpolly
    Sep 21, 2015
    5,278
    Seattle
    The problem is that if an electric motorcycle is too slow, it becomes a heavy electric bicycle, and its utility becomes severely limited.
    The weight also doesn't matter as much as it may seem to an electrical engineer :) At constant speed on even surface it doesn't matter at all; with the proliferation of smart regenerative braking, whatever you lose on assent and acceleration, you mostly gain on descent and deceleration. In the end, it becomes a rounding error compared to the weight of the rider and luggage.
  9. SteveAZ
    SteveAZ Long timer
    Sep 23, 2002
    2,149
    AZ
    With the electric bike air resistance is by far the greatest impact on speed vs. efficiency
    I'll be it's pretty much the same with motos
    liberpolly likes this.
  10. T.S.Zarathustra
    Apr 26, 2018
    381
    Noord Holland
    I've "ploughed through" 4 of those, and many similar. :-)
    You're right. Make the Tesla Model 3 ~ 110 hp instead of ~ 330. That should be enough for at least 80 mph, not much, but enough for all law abiding citizens. Motor and control unit weight could probably be cut in half, batteries probably by maybe 20%, so total weight of the car would drop quite a bit. Since most power is used when accelerating (as can be seen by cars having lower mileage in cities, even if average speed is lower than the highway), dropping the weight would increase the range close to the same as current car. It would also decrease rolling resistance from the tires. And, of course, it would decrease the pollution from building the car. Win, win and win. :D
  11. liberpolly
    Sep 21, 2015
    5,278
    Seattle
    Tesla 3 motor weighs less than 100 lbs, battery weight is about 1/4th of the total car weight, so the overall reduction in weight will be what, 5%? Not worth it for Tesla to lose the market share.
    You people are really looking for gains in all the wrong places. The reason the electric motors on EVs are over-powered is to compensate for the missing transmission, which is, overall, a huge improvement in weight, efficiency, and reliability.
    Monkeyshines and MJSfoto1956 like this.
  12. magnussonh
    May 2, 2019
    28
    Iceland
    Zarathustra has said that when you purchase new EV it has caused more pollution than comparable ICE. EV will make up for it by polluting less when being used. You are borrowing pollution against future cleaner EV running. That math works nicely as long as nothing happens.
  13. T.S.Zarathustra
    Apr 26, 2018
    381
    Noord Holland
    Nice way of putting it. Your return depends on how clean your energy sources are.
  14. liberpolly
    Sep 21, 2015
    5,278
    Seattle
    But a lot of things are happening, and have happened since the math he relies on was done. The numbers from 2011 he used are not even nearly correct today, and will be even less relevant in the next 8 years.
    MJSfoto1956 likes this.
  15. WagonWillie
    WagonWillie Been here awhile
    Nov 3, 2015
    184
    California
    Not the case with my Zero SR: I only get back about 10 to 15% with regeneration. I think it's mostly due to the charger not being able to shunt the regen quickly enough due to its limited capacity.
    magnussonh likes this.
  16. WagonWillie
    Nov 3, 2015
    184
    California
    Yeah, that's why this looks promising: https://newatlas.com/linear-labs-hunstable-electric-motor/60974/
  17. liberpolly
    Sep 21, 2015
    5,278
    Seattle
    Yeah, they need to up the ante here.
  18. SteveAZ
    SteveAZ Long timer
    Sep 23, 2002
    2,149
    AZ
    Catching regen energy from hard braking is difficult - batteries just can't take the energy quickly enough
    Maxwell makes "supercapacitors" up to the task but that adds size, cost and weight that in smaller vehicles may be hard to justify
    https://www.maxwell.com/products/ultracapacitors/
  19. liberpolly
    Sep 21, 2015
    5,278
    Seattle
  20. liberpolly
    Sep 21, 2015
    5,278
    Seattle
    Yeah, probably not that important for a motorcycle where most of the energy is spent on overcoming air resistance.
