Electrical bike, nuggets style...
Discussion in 'Some Assembly Required' started by nuggets, Oct 9, 2017.
  1. nuggets
    nuggets It's all my fault...
    Jul 13, 2010
    3,585
    Virgina
    I feel your pain. I've got a pile of projects going all the time too. Part of what's delaying this bike build is turning my new garage into a usable shop. It's not going as fast as I would like.
    #61
    GR0NK likes this.
  2. Aggrocrag
    Aggrocrag Meat Popsicle
    Jul 2, 2014
    101
    Colorado
    Well, hopefully the shop will be done, and you'll have the buddy bike running for when I come to town soon(ish)!
    #62
    nuggets likes this.
  3. nuggets
    Jul 13, 2010
    3,585
    Virgina
    :fpalm:fpalm:fpalm
    I finally got to work on this thing again... So, I haven't figured out how to hold the battery in place yet, and I just haven't worked on this at all. So, I got started on it again yesterday evening.
    I started by making this mount so I could hold the bike on the bench. It's ugly, but works.
    Put some new brakes on it... I got some fancy Magura brakes for it after the cheapo brakes that were on it seized up.
    Some KTM hardware to mount the calipers.
    Here it is on the bench...
    I am still not sure how I will hold the battery, so I worked on the wiring... I got it all tidied up around the seat tube.
    Here's the other side with the battery in place.
    The side panels extend back past the battery box and cover all the wiring. They are cut to follow the line of the fender.
    #63
    GR0NK, waylongway and redfishguide like this.
  4. waylongway
    waylongway madmax Supporter
    Dec 16, 2009
    3,993
    NorCal
    #64
    nuggets likes this.
  5. nuggets
    Jul 13, 2010
    3,585
    Virgina
  6. redfishguide
    redfishguide Old Dirt Biker Supporter
    Dec 17, 2004
    1,206
    Beaufort, South Carolina
    I bought a HF band saw 7 or 8 years ago and it has performed quite well much to my surprise. Catch it on sale and with a coupon....can be had for close to 200 bucks I think.
    Buck has given it his seal of approval and he wasn't even around when I bought it.
    Jack and Buck
    #66
    Helibee, nuggets and waylongway like this.
  7. nuggets
    Jul 13, 2010
    3,585
    Virgina
    How does it do with metal?
    #67
  8. waylongway
    Dec 16, 2009
    3,993
    NorCal
    :deal
    Now you have 2 tools....:clap:clap
    #68
    nuggets likes this.
  9. redfishguide
    Dec 17, 2004
    1,206
    That's all I have ever cut with it. Including some pretty heavy steel and even some stainless. I have had mixed luck with H F power tools but I am very pleased with the band saw and figure by now it doesn't owe me nothing.
    I really like the fact that it can be used as a verticle or horizontal. Keeping the blade properly aligned can sometimes be a bit tricky but not a major issue. The stand it comes with kinda sucks but I guess it works well enough. I made a new one for mine and added wheels so I can move it around the shop and get it out of the way when I'm not using it. I read some where on the net that the oil they used was really bad so I put in decent gear oil. I even have had pretty good luck with the blades they sell at H F for it. I do use cutting oil religiously when using it and that's probably why the blades have held up. Also take my time and not push it.
    All in all I have been very happy with its performance....dunno maybe I got lucky for once.
    Jack and Buck
    #69
    nuggets likes this.
  10. nuggets
    Jul 13, 2010
    3,585
    Virgina
    Thanks, what do you think he added to control the motor speed?
    Good info...
    There's a sears one for sale nearby for $100. Hmmm.... Probably a better buy than the harbor freight saw at $370
    Didn't make much progress on the bike tonight. Mostly did some looking and measuring and thinking. Ordered some metal I need for this project...
    #70
  11. waylongway
    Dec 16, 2009
    3,993
    NorCal
    Buy it.....!!
    #71
    nuggets likes this.
  12. more koolaid
    more koolaid Been here awhile
    Nov 5, 2015
    474
    Bel Air Md.
    I have the 12" version and its the most used power tool I have and use a metal blade for everything.
    Cool bike by the way, can't wait for a ride report
    #72
    nuggets likes this.
  13. nuggets
    Jul 13, 2010
    3,585
    Virgina
    I sent an email... We'll see. Looks like used is the ticket.
    #73
    waylongway likes this.
  14. nuggets
    Jul 13, 2010
    3,585
    Virgina
    Well, no bandsaw for me I guess. I'm getting no response on that bandsaw. I'll wait, and one will turn up.
    I miss my metal lathe :(
    I'm watching for another one...
    I figured out one of my issues. Well, the bike's issue.
    A drawing.
    I've got some 3/8 thick bar stock scrap. Here's the setup to cut.
    So, the angle grinder and cut off wheel plus angle iron for edge guide isn't too accurate.
    I use the sander to clean up.
    It's labor intensive with the tools I have, but I eventually get to this. A reasonably square little block in spite of the caveman tools. Did I mention I miss the lathe?
    I get creative with the vise grip, so I can make marks in the right spots.
    Drill and tap. This little block is 3/8 inch thick, and about 20mm square.
    Now I have a threaded mount point for the side cover. I have to make seven more.
    I'm ordering some bar stock from McMaster since it will be a lot more quick and accurate than carving up weird shaped chunks of scrap.
    #74
  15. nuggets
    Jul 13, 2010
    3,585
    Virgina
    @waylongway
    I got some foam to try your idea. It's the pick and pluck foam from a pelican case.
    #75
  16. Salsa
    Salsa Long timer
    Dec 12, 2006
    1,252
    Arizona, Alaska
    Looks like a good heat insulator to me.
    Don
    #76
    nuggets likes this.
  17. redfishguide
    Dec 17, 2004
    1,206
    Last I checked the H F metal band saw is $249 add a 20% coupon or maybe a 25% (if you can find one) and your almost at $200. Also I find I do most of my cuts with the saw in the horizontal position. You will have to square off the blade but cuts are pretty accurate.
    Jack and Buck
    #77
    nuggets likes this.
  18. nuggets
    Jul 13, 2010
    3,585
    Virgina
    True, I'll leave as much air space as I can.
    Gotcha, I thought we were talking about the 14inch woodworking bandsaw. I think that might be a better fit for what I do.
    No bandsaw for me right now. It's on my tools list, that and a lathe.
    I got three more of the tedious little blocks made, and then I had another idea (see the riveted test piece). If I make 3/8 x 3/8 x 1 in pieces, then I can add a threaded hole, and use rivets to attach the little blocks. That will be easier than keeping track of a bunch of loose blocks. I'll still need a few of the little blocks with the two threaded holes.
    #78
  19. nuggets
    Jul 13, 2010
    3,585
    Virgina
    Got some metal and drill bits from brown santa.
    I bought myself some metric bits for tap and clearance holes for M5 and M6. I had been getting by with close as in hand grenades bits, but taps work best in the proper size hole it turns out.
    I got a couple more of these little blocks made.
    And I installed them. A few more blocks and I'll be able to mount up and finish the side panel.
    I also thought you guys might enjoying seeing my other electric bike. This one is a bought electric cargo bike with a rear hub motor. It's not nearly as fast as the hotrod ebike I am building up, but it's a daily driver and way more practical. It's got some minor mods for lighting, and modifications for towing other bicycles. I tow the kids bikes to school with it in the morning and leave the bikes for them there. They ride the bus to school, then I meet them at school in the afternoon, and we all ride home together. I've got 1000 miles on the cargo bike, mostly from going back and forth to work.
    #79
  20. nuggets
    Jul 13, 2010
    3,585
    Virgina
    I got back to working on mounting the side panel.
    I decided to make four rivet on threaded mounting blocks. Here's the drawing and the pieces of stock cut to size.
    And here they are with all the holes drilled, tapped, and ready to mount.
    And I have started mounting the side panel and trimming it down to size.
    #80
    invisa-bill, waylongway and Foxed101 like this.
