Emergency Braking
Discussion in 'The Perfect Line and Other Riding Myths' started by Hambone123, Nov 28, 2017.
  1. Hambone123
    Hambone123 n00b
    Oct 27, 2017
    7
    DC Area
    Hello, I was out yesterday trying to test the limits of my brakes in a remote asphalt parking lot. I have a 2004 1150GS with ABS. The bike is fairly new to me and the brakes are amazing! My question is this: Is there a point where, if I pull too hard on the front brake lever, that the back end of the bike will come off the ground and flip me over onto my head? Seems possible with these brakes, and that would be terrifying obviously.
  2. vanha
    vanha Finnspacko
    Nov 25, 2013
    63
    Finland
    If the ABS system is working properly the scenario you described is impossible.
    Motorius likes this.
  3. Hambone123
    Hambone123 n00b
    Oct 27, 2017
    7
    DC Area
    Good to know, thank you. I've never experienced a brake so strong!
  4. TUCKERS
    TUCKERS the famous james
    Dec 23, 2005
    17,831
    Villa Maria Sanitarium, Claremont, CA. USA
    Anti lock braking doesn’t actuate initially under 5mph, so in a stopping situation you can lock the front wheel. Gas station, road junction, parking lot, when coming to complete stop in these situations use the rear brake.
  5. Patek
    Patek Been here awhile
    Feb 17, 2015
    669
    Raleigh, NC
    If you flip it, make sure you have someone film...
    wmfleet2, Barry, Eatmore Mudd and 2 others like this.
  6. Hambone123
    Hambone123 n00b
    Oct 27, 2017
    7
    DC Area
    I definitely will get a film for you!
    So the front and rear brake are "linked" according to the manual. What then is the best sequence for stopping in the shortest distance possible without flipping over? For instance, when I'm about to eat the car in front of me?
    dtysdalx2 likes this.
  7. aldend123
    aldend123 Long timer
    Sep 1, 2011
    5,070
    Bristol County MA
    You sure about that? A quick parking lot stoppie basically locks the front wheel. But a rapid deceleration emergency stop doesn't.
    It also depends on whether the ABS system tolerates rear wheel lock up, and/or can detect if it's no longer in contact with the ground. I think the answer to this question depends on the system's implementation. Ignoring any electronic safeties, the answer is yes, most bikes can be flipped over. But you'll get some warning as the rear end rises unless you really stabbed the lever while having a tremendous amount of traction. I'm guessing given the era of bike, it has the ability to invert itself.
    A textbook perfect stop typically implies lifting the rear tire a bit. Keeping it on the ground means you're leaving some braking on the table. Granted this depends on bike geometry, tire traction, etc.
    aftCG likes this.
  8. Fastman
    Fastman Been here awhile
    Sep 15, 2002
    539
    Webster Groves, MO
    My technique is to quickly and smoothly apply both brakes hard (focusing on the front) and get my weight back if I can. I try to avoid snatching the lever or stomping the pedal. The front brake will do most of the stopping and the linked brakes will apply pressure to the rear. However, I try to make it a habit to use the rear brake pedal too. Assuming the ABS is working as it should, it'll give maximum braking from both wheels without the rear sliding out.
    #8
  9. Hypersonic
    Hypersonic OnTheRoadAgain
    Jul 14, 2015
    41
    GREECE
    You may lock the front wheel under 5mph and make it slip, but I don't think there's enough force to flip the bike...
    #9
    ydarg and vanha like this.
  10. Bobbrecken
    Bobbrecken Adventurer
    Jul 20, 2013
    87
    Thunder Bay
    On the track where the surface is good I used my back brake just to keep the rear wheel in line. 100% of the braking was the front wheel. I watched a top racer at the time come into the corner lap after lap with his back wheel two inches off the ground. On the street where you don't know what is under the tires you can't do that but you can come close. Antilock brakes seem to take care of everything now.
    #10
    ydarg likes this.
  11. aldend123
    Sep 1, 2011
    5,070
    Bristol County MA
    If you lock the front, and keep traction you can get the rear to hop off the ground a bit. But agreed that unless an extremely steep downhill, I doubt it's ever going to get very high.
    #11
  12. White mt guy
    White mt guy Long timer
    Jan 20, 2016
    1,531
    northeast
    Wet, grassy areas under 5mph will in fact allow the front wheel to slip out from under you, but I've yet to lose the front end on pavement under extreme braking with abs.
    #12
  13. lnewqban
    lnewqban Ninjetter
    Jan 22, 2012
    838
    Florida
    Welcome, Hambone!
    An important part of practicing emergency braking is to recognize when to easy the hand pressure on the front brake lever.
    That would be key mainly in slippery conditions, when a skid of the front tire would suppress your ability to steer the bike and would quickly induce a fall.
    The ABS system will help you by automatically easing that "hand pressure" for you, even if you don't.
    I believe that the ABS might not help you in the event of inducing a stoppie, because it can't feel a problem if both tires have stopped rolling.
    Due to the relatively long distance between the wheels and the low center of mass, your bike may tend to skid the front tire (break traction at the contact patch) before it can become a solid fulcrum and develop enough forward inertia to flip the bike over your head.
    In that case, ABS may help keeping the front tire rolling rather than skidding, creating an additional safety margin.
    #13
  14. windblown101
    windblown101 Long timer
    May 17, 2010
    4,120
    Star Tannery, VA
    Yes, the bike can do stoppies and therefore yes, it is possible to flip. But highly unlikely as just getting the rear to come up on a fairly long wheelbase bike takes some effort.
    In practice you should be able to feel the rear end lift and be able to just let off the brakes without worrying about landing on your head.
    Found this on the net with a quick search:
    #14
    lnewqban likes this.
  15. vanha
    vanha Finnspacko
    Nov 25, 2013
    63
    Finland
    Stoppie is something you don’t end up doing by mistake-it needs skills and effort to perform and has nothing to do with the original question about emergency braking.
    Just like other members posted that 5mph is not enough to flip over your bike even if the front wheel locks it just skids a bit and on tarmac you’ll plant your feet to prevent the fall.
    Not sure if that 1150 has the Rear wheel lift detection system..? That bike on the wheelie/stoppie video sure didn’t have it or it was deactivated, maybe abs and other systems were deactivated too?
    It’s important to know how these safety features work so read the manual of your own bike and its safety systems.
    There are also videos on Youtube about emergency brakings with ABS bikes, have a look. No flipping over the bars:D
    #15
  16. slartidbartfast
    slartidbartfast Love those blue pipes
    Dec 23, 2003
    8,845
    Southern Louisiana or Southern England or ...
    Stoppies like that would require a non-ABS bike or disabling the ABS.
    The 1150 GS does NOT have linked brakes.
    The limited dive from the telelever front end makes hard braking much easier than on many other bikes (and stoppies harder to perform deliberately, let alone accidentally.) You will probably make better use of your brakes but will wear your front tire faster.
    Keep practicing. Learn how hard you have to brake to engage the ABS. You should aim for the hardest possible braking JUST short of that point in order to get the best possible stopping distance.
    #16
  17. CopaMundial
    CopaMundial Wow, that broke easy
    Jun 27, 2008
    1,740
    US, SE PA & Central ME
    Best braking technique is to practice always using both brakes so it's reflex when needed, regardless if the bike you're riding has linked brakes or not.
    Also once you have concluded that there is no way around an object then braking full force is your only real option (stoppie or not). If the rear wheel starts to lift off the ground trust me you will feel it way before the bike tips any appreciable amount.
    #17
    JETalmage likes this.
  18. drtyrrel
    drtyrrel "don't look down"
    Apr 29, 2013
    312
    Schroon Lake NY
    You will probably skid the front tire before you do a stoppy without abs. With abs you will feel it release the front brake instead. The best way to stop in the shortest, safest distance is to do exactly like you are doing now. Practice doing it in a safe place. Mark a point to begin your braking and practice at the same speed in 2nd gear several times watching how far you went from the braking point. Make sure you are looking straight ahead with your head and eyes up not looking at the ground or front tire. Make sure you shift to 1st before you are stopped. Use both brakes at the same time squeezing or pressing them with progressive pressure. No grabbing or stomping. Kinda like a hand shake with an old friend that starts light and you slowly squeeze until somebody says "peanuts":D. I took an advanced riders course last year and practiced this at up to 35mph speeds in 3rd gear. A lot different feel on your own bike than doing this on the little 250's at the MSF class.
    #18
    Barry and lnewqban like this.
  19. mb90535im
    mb90535im '05 R1200 GS
    Jun 8, 2008
    6,687
    NW GA
    When I first got my GS it was the first "modern" technology bike I had ridden. I was practicing emergency stops and was surprised that even though the bike didn't want to come up and over, I quickly realized that my body momentum was a different story. Almost dropped it on the first one, then learned how to hang on with my legs. Actually put it to good use when a kid in a VW looking straight at me pulls out in front of me and the GS stopped cleanly from about 45 mph about 18" from her door as she screamed and flailed her hands uncontrollably. The combo of ABS and the GS's suspension is something to behold in emergency situations.
    #19
    FJ Fun, lnewqban and drtyrrel like this.
  20. ydarg
    ydarg Miscreant
    Nov 11, 2015
    1,397
    Above the Equator
    Not enough traction on a normal street to "flip" the bike just by jamming on the front brake.
    Yes, the brakes can lock the wheel up. No, you won't go over the bars.
    #20
    Rockred and lnewqban like this.
