EML Build
Discussion in 'Hacks' started by We're Here, Jul 25, 2017.
  1. We're Here
    We're Here Been here awhile
    Feb 12, 2007
    303
    Santa Barbara
    Have not done the actual measurements, but it is more than the EZS rig. The way the brackets and attachments are configured it is what it will be, no adjustments.
    #61
  2. FR700
    FR700 Heckler ™©®℗
    May 4, 2007
    15,730
    Your imagination.
    Once you install the front lower connection I'll be interested to see where it intersects the sidecar frame.
    #62
  3. We're Here
    Feb 12, 2007
    303
    Santa Barbara
    The connections are very solid, I suspect thick wall tubing. There is no lower forward connection. Only two places to adjust, the forward connection at the sidecar frame can be moved up or down, and the sidecar wheel axel is an eccentric, to deal with toe/in. Have not put the straight edges on it yet. (cotter pin on axel waiting for adjustment)
    #63
  4. rg sw wa.
    rg sw wa. Long timer
    Feb 9, 2011
    1,265
    Southwest Washington
    #64
  5. FR700
    FR700 Heckler ™©®℗
    May 4, 2007
    15,730
    Your imagination.
    Interesting.
    I can not see a way of adjusting lean in/out. Is that also fixed?
    #65
    rg sw wa. likes this.
  6. We're Here
    Feb 12, 2007
    303
    Santa Barbara
    There is no adjustment, other than changing ride height via sidecar shock and rear shock.
    I need to move the rig to the garage, with its level floor. I'm as curious as you are as to how it will pan out.
    #66
    rg sw wa. and FR700 like this.
  7. FR700
    FR700 Heckler ™©®℗
    May 4, 2007
    15,730
    Your imagination.
    Thank you for sharing this information, and the most excellent photographs. Much appreciated.
    #67
  8. THEAPE
    THEAPE EML Rocks
    Dec 13, 2011
    218
    PERTH. West Australia.
    The EML Sport I have has no adjustment for Toe in apart from an eccentric on the swing arm pivot as the two lower bike to sidecar attachment links are fixed. I found that the eccentric which is approx. 50 mm in Dia. does alter the lean in and out when setting Toe in.
    #68
  9. davebig
    davebig Another Angry Hun !
    Jan 19, 2004
    9,092
    Minnesota
    I would have thought you knew that ! Shock and dismay ! Also hard to induce lean in and out with wide tires on wide wheels, even the K1100 setup which appears to be adjustable isn't it all only fits one way !
    #69
    draperg1 and We're Here like this.
  10. We're Here
    Feb 12, 2007
    303
    Santa Barbara
    Just in from the painter, still some paint to go on the interior.
    #70
    davebig, Bobmws, Strong Bad and 2 others like this.
  11. DRONE
    DRONE Dog Chauffeur
    Oct 1, 2007
    7,200
    Chambers Bay, WA
    Hardest thing ever is deciding on the paint job. Looks good to me! Is it the lighting, or is the finish all matte?
    #71
  12. ooweel
    ooweel Throwing wrenches one at a time
    Jun 23, 2004
    954
    ShoeMashVille
    You come up with the coolest colors and patterns on your paint jobs. NICE !
    #72
  13. We're Here
    Feb 12, 2007
    303
    Santa Barbara
    Its matte, suppose to to match the tug, fingers crossed.
    #73
  14. ooweel
    Jun 23, 2004
    954
    ShoeMashVille
    I did my Bronco in Hot Rod Flatz paint, its a similar look to this and it came out bitchin. Got compliments everywhere it went.
    Takes some talent to spray that stuff. Had B.A. at Hot Rod Alley do it.
    Did you use Hank to paint this? Or is it the same guy that painted the Expedition (that is waiting in the wings for a fork fix) the guy who shot this?
    #74
  15. We're Here
    Feb 12, 2007
    303
    Santa Barbara
    Used local fellow, Alex, does work for Bobby at the Talbott museum.
    DMC did the paint on the Expedition.
    #75
  16. We're Here
    Feb 12, 2007
    303
    Santa Barbara
    " Expedition (that is waiting in the wings for a fork fix) the guy who shot this?[/QUOTE]
    They have the tool now, and hopefully enough parts, give them a call.
    #76
  17. ooweel
    Jun 23, 2004
    954
    ShoeMashVille
    "They have the tool now, and hopefully enough parts, give them a call.[/QUOTE]
    Steve said "tool is here" just no parts. I'm on the the so called "list". Still riding it tho.
    #77
  18. We're Here
    Feb 12, 2007
    303
    Santa Barbara
    Final assembly. Have the powder coated parts, and Painted tub. This is the fun part. Electric wiring still to go.
    #78
    rg sw wa. and High Octane like this.
  19. We're Here
    Feb 12, 2007
    303
    Santa Barbara
    Sidecar wiring.
    Check toe/in, and put the tub on.
    First ride next week!
    #79
    davebig, FR700 and rg sw wa. like this.
  20. davebig
    Jan 19, 2004
    9,092
    Minnesota
    Did EML have any suggestions for toe ?
    #80
    High Octane likes this.
