Enduro Strom 1000 weight loss with number
Discussion in 'The Welcome Mat: New Member Introductions' started by Yvon Nulpart, Mar 23, 2019.
  1. Yvon Nulpart
    Yvon Nulpart Adventurer
    Oct 6, 2018
    10
    Ste-Martine, Quebec
    Hi everyone !
    I just jumped on a sick deal so i bought a superb DL1000 2005 for real cheap :)
    Planning to do some serious weight loss like i did on my DL650 2006 in this tread :
    https://www.stromtrooper.com/stromt...173-2006-dl650-naked-weight-loss-numbers.html
    The monster in question have some clutch vibration and erratic grip issue and hasn't move since aprox 4 years,
    So i did some work today, there some pics, the metal plates were glazed so i sand them a little
    there was also medium groove on the clutch basket, file them seem to be a good idea to save some money
    i will do a little test ride tomorrow and the weight loss will come after i fixed all the mecanic
  2. Yvon Nulpart
    Oct 6, 2018
    10
    Ste-Martine, Quebec
    some more pics
  3. Yvon Nulpart
    Oct 6, 2018
    10
    Ste-Martine, Quebec
    More :)
  4. P 0 P E Y E
    P 0 P E Y E Bald rider Supporter
    Nov 13, 2008
    1,982
    southern Connecticut U S A
    Hello and welcome aboard.
    Did you check the bearings?
    Does the basket wobble?
    That is significant wear
  5. Yvon Nulpart
    Oct 6, 2018
    10
    Ste-Martine, Quebec
    Hi Popeye, Thanks for the suggestion, i did visualy inspect the two larges bearing, the push rod bearing and they seem to be in good condition, there was no play from the basket bearing from side to side ( wiggle, push one side and pull the other ) however there is lateral play from the basket and the big gear behind it, causing some idle hammer that i will fix later, could this making this kind of problem ?
    When i release the clutch slowly and gives gas it vibrate and of 1 of 3 times it grips very snatchy ( like if i dump the clutch ) but i release very slowly
    I will make a video if the problem persist
    Thank you
  6. Yvon Nulpart
    Oct 6, 2018
    10
    Ste-Martine, Quebec
    Sooo, i test ride it today, the clutch feels better but the problem still there,
    i made a little video, there's the link:
    if anyone ever have this problem, please share :)
    thinking of basket bearings or plate contaminated maybe or worn ?
  7. Yvon Nulpart
    Oct 6, 2018
    10
    Ste-Martine, Quebec
    Welcome back ! i did the shim mod from this site : https://www.vstrom.info/Smf/index.php/topic,11745.0.html ( damn i forgot to take pictures but it look like this )
    and it improved the low rpm riding much better from 2000rpm with no chudder ( back and fourth annoying movement at low speed ) and no more loud idle hammer + that took care of the take off vibration issue :)
  8. Yvon Nulpart
    Oct 6, 2018
    10
    Ste-Martine, Quebec
    Weight reduction has begun !
    Mufflers weight 13lbs each = 26lbs
    Fairing assy with turn signals, speedo 25lbs
    Bar end weights 2lbs
    Rack passager 7lbs
    Rack luggage 6lbs
    Both peg passenger = 3 lbs
    Side panels = 1 lb each = 2 lbs
    Battery = 10lbs
    More to come soon ! :)
    #8
  9. Yvon Nulpart
    Oct 6, 2018
    10
    Ste-Martine, Quebec
    Here's some news !
    I found 2 exhaust in the Ecocentre recycle :D , and made a shorty that only weight 3lbs so that's 23lbs savings ! :)
    I did also IAT ( Intake Air Temp ) sensor mod to fool the ECM thinking it's colder outside and make it richer, the stock IAT is 2.7k OMH at 25 Degrees C, I did a swap with a 5.2k ohm Thermistor at 25 degrees c so ECM will '' think '' it's 20c colder outside plus it will be relocated to the front of bike for better precision
    #9
