Engineman makes bad decisions: An Electra Glide story
Discussion in 'Some Assembly Required' started by engineman, Jan 8, 2019.
  1. villageidiot
    villageidiot Long timer Supporter
    Apr 29, 2010
    15,849
    Orange County, CA
    I’d have a paintless dent guy have at that tank. Minimize the amount of filler, and then I’d paint it.
    #21
  2. IronButt70
    IronButt70 You don't have to be crazy to do this but it helps
    Jul 16, 2018
    576
    Classified
    How many miles on the speedo? I believe 06 was the last year for the problematic spring loaded cam chain tensioners. I would highly recommend you have them checked out if the bike has over 30k miles. If you're good at wrenching there are youtube videos to show you how. If the fail while you're riding you'll probably grenade the engine. Replace them with the updated hydraulic tensioners before your trip if possible.
    #22
    Webman and Helibee like this.
  3. AK650
    AK650 Long timer Supporter
    Jun 26, 2013
    2,292
    Alaska
    +1, along with the inner cam bearings, while in there.
    #23
    Helibee likes this.
  4. IronButt70
    Jul 16, 2018
    576
    Classified
    :thumb
    #24
  5. engineman
    engineman Long timer Supporter
    Sep 26, 2012
    1,050
    Eastern Iowa
    Great info, thanks! There's 41k on it so I'll check into this.
    #25
    boatpuller likes this.
  6. dbarale
    dbarale Squiddly slow
    Oct 20, 2008
    2,909
    Western NC
    Making it pretty will increase its resale value but may reduce the enjoyment you will get out of it. There’s something freeing and highly enjoyable about riding a bike that’s mechanically fine but looks rough. Never having to worry about another scratch or having to wash it is awesome!
    #26
    CCitis, Webman, Traxx and 4 others like this.
  7. villageidiot
    Apr 29, 2010
    15,849
    Orange County, CA
    if you think you can save the fairing and stuff, i know its not expensive to have those bits shot at a place like Maaco, or another quick moving auto paint place. it'll look great from 10 feet.
    you can also get colored/tintable "raptor liner" and if you reduce it, and shoot it with a little more pressure, it doesn't get as clumpy as bed liner, won't look half bad, and is durable as hell.
    #27
  8. JimVonBaden
    Feb 11, 2005
    94,918
    Alexandria, VA
    #28
    engineman and scot_douglas like this.
  9. engineman
    Sep 26, 2012
    1,050
    Eastern Iowa
    Yep- This is generally how I feel. Especially since I live at the end of 5 miles of gravel. I cannot hope to keep a bike like this Harley remotely clean if I plan on actually riding it and if you don't ride it, whats the point
    #29
    Webman and Traxx like this.
  10. lesman
    lesman Live easy, Brake Hard
    Sep 7, 2006
    4,072
    Baja Okahoma
    Great bike. A buddy has a problem with low oil pressure / kinda loud with his 2003. Changed the chain, tensioner and the oil pump with Screaming Eagle parts. It was pretty frightening how close it was to grenading. Bike ran flawless after the change. Excellent oil pressure. 4 years the parts were $ 700-800
    #30
    engineman likes this.
  11. engineman
    Sep 26, 2012
    1,050
    Eastern Iowa
    I'm planning on opening it up as soon as it warms up a little bit in my shop. The PO has no end of doodads and farkles on this bike so I'm really hoping I find a nice S&S gear drive in there. :D
    #31
    Webman, shadagee, smolt and 3 others like this.
  12. AK650
    Jun 26, 2013
    2,292
    Alaska
    That'd be ideal. I got lucky, and had less than .002" TIR on both the pinion and crank side of mine, so I went with gear drive cams. Good luck!
    #32
  13. b1pig
    b1pig Long timer
    Jan 16, 2013
    2,699
    Over There
    You're braver than I am. After my experience with this Fat Boy we have, I never want to buy another bike I intend to take on long rides without spending at least half an hour on it first. On this particular bike, the wind rolls off the top of the windshield right onto the top of my helmet. I get horrible headaches from it. I've heard the EG/RG bikes don't suffer as much from this, but I've never ridden one.
    #33
  14. engineman
    Sep 26, 2012
    1,050
    Eastern Iowa
    Definitely going to put some miles on it before we leave. Odds are there will be at least a day or two in early march when its fit to ride here.
    #34
  15. engineman
    Sep 26, 2012
    1,050
    Eastern Iowa
    Little bits of progress:
    Passing lamp mount bolt was broken. In the spirit of more time than money I made a new one by drilling through a bolt I had on the shelf
    Started Inner fairing disassembly. Lots of wires in there
    To help me put it back together I always mark the connections, letters, numbers, shapes, colors, just something to help me rememember
    #35
    zzzak and AK650 like this.
  16. Trackjunkie21
    Trackjunkie21 Been here awhile
    Nov 20, 2018
    400
    Staten Island, NY
    Awesome score! As mentioned before, while checking the cam chain tensioner, go the extra mile and replace the inner cam bearing and measure the crank runout. for piece of mind.
    #36
  17. engineman
    Sep 26, 2012
    1,050
    Eastern Iowa
    ALL of the brackets are broken. I'm hoping the used fairing I have coming from EBAY included them, I'f not I'll buy new ones. I probably could weld these back together but if they broke from fatigue before the crash they're otin gto be pretty brittle already
    #37
  18. engineman
    Sep 26, 2012
    1,050
    Eastern Iowa
    #38
  19. Trackjunkie21
    Nov 20, 2018
    400
    Staten Island, NY
    #39
  20. engineman
    Sep 26, 2012
    1,050
    Eastern Iowa
    Found some work I could bring in the house since it's 0 degrees this weekend.
    Recovering the rashed speaker box
    Lady on ebay makes and sells new covers, pretty simple fix
    Got some help from the crafty one in the family
    Good as new
    #40
    panhead_dan, zzzak, FR700 and 2 others like this.
