EPC and other niceties on Euro bikes
Discussion in 'Dakar champion (950/990)' started by Marotte, Jun 16, 2004.
  1. Marotte
    Marotte Been here awhile
    May 29, 2002
    317
    San Francisco, CA
    First, let me apologize for pushing back this subject.
    I know it has been beaten to death, so much indeed I've been quite confused by the 345 posts about what's where and the 173 ways of getting rid of these 'unnecessary' stuff !!!
    I'm the very happy owner of a new European KTM950 (850 km so far).
    I've just received the Sommer Airbox, which I plan to ask my dealer to put on the bike at the 1,000 km service.
    It's running PERFECTLY, so I want to keep cobbling to a minimum!
    Is there anything like EPC I should get rid of on this 2004 Euro bike ? And what's the easiest way ?
    (I've switched to the KTM aluminium silencers already, so I know I can get rid of the SAS, but do not really see the point).
  2. Flanny
    Flanny Flanny-it-up!
    Feb 18, 2003
    2,739
    Ottawa, Ontario, Canada, the World, the Universe
    There really is no point if you are perfectly happy with the bike and it is running well...I removed my canister and SAS system becuase my tanks were flooding and the bike was posping like mad on decel...if you're bike is 100%, you may as well leave it alone.
  3. Marotte
    May 29, 2002
    317
    San Francisco, CA
    Except going from really really good to amazingly astounding ? :wink:
  4. Greg Minor
    Greg Minor The Trespasser
    Oct 19, 2003
    2,322
    Escondido Ca
    Flanny which exhaust are you running can we remove the sas with stock pipes
  5. motozilla
    motozilla Long timer
    Sep 10, 2002
    5,741
    PHX, AZ
    Herein lies the crux of the matter. If you install Akra or Remus slip-ons you will notice significant popping on decel. I assume others have experienced this??? Anyway it was horrible on my bike so I yanked the EPC and SAS, installed a Factory jet kit (Some say not nessasary, others (me) can't live without it) and slapped Katoom's blanking plates on the heads and viola'!!! Runs like sexually assualted primate! :D
  6. Flanny
    Feb 18, 2003
    2,739
    I am running the stock exhausts....I'm pretty sure that the catalyser will get clogged...I'm taking a chance and living on the edge...
    Even if the catalyst itself gets ruined, I think by the design of the thni gthat exhaust will still flow free..it just won't get catalysed...
  7. woodsrider
    woodsrider .........................
    Nov 22, 2003
    587
    Colorful Colorado
    Yep, I've got some pretty significant decel pop (between shifts also) with the Akras installed on my 2004 ("second release" with black rims) 950.
  8. KTMax
    KTMax Ninth of the Nazgul
    Oct 28, 2003
    1,099
    Amsterdam, The Netherlands
    Nope, not if the idle mixture is set right it won't. Just a mild burble on a close throttle. As it should BTW.
    Did it on both my 950s. Removed the stock cans, fitted Akra's, no problem. On my current bike the carbs were set with the stock pipes even before I fitted the Akra's. Bolded them on, flawless.
    The easiest way to 'get rid' the EPC is to just to unplug both connectors. About 50 seconds work...
    Kind of fun to rewind this tape again... :rofl
    #8
  9. Gert
    Gert Made in Denmark
    Feb 1, 2004
    383
    Covington, GA
    Marotte, as others have said, there is no need to remove the SAS - especially if you do not go offroad or wrench on the bike yourself.
    I removed it on mine, but not for the slight decel burble - it did not annoy me in the first place. Also not for the weight savings. (I'd probably save more by skipping dinner a few times...), I did it to remove complexity from the bike. Less that can break off-road, and more room 'under the hood' if something does break.
    Removing/disabling EPC is something that is not absolutely neccessary either. It only reduces engine power in an RPM/speed range that should only apply under lab test conditions. But the service manual mentions that vibrations against the frame introduced by incorrect mounting/placement of the EPC valves will reduce engine power in all gears and RPM ranges - regardless if plugged in or not. As you have not yet had your 1000km service, i would advise you to have your dealer completely remove it at that time.
    But you can live without both SAS and EPC removal. But when you have your service and the dealer installs the airbox mod for you, there are two other things you need done: raising the carb needle one notch, and installing a 16T front sprocket. These inexpensive modifications really change the character of the bike to the better. You will love it.
    Good luck with it!
    Gert
    #9
  10. K2ride
    K2ride Single track mind!
    Feb 16, 2004
    1,629
    Quebec, Canada
    Never found any trace of an EPC system on my GO!!!! bike (Canada) but got rid of the SAS & the entire charcoal canister system! :thumb
    Btw, still running the stock cans with CATs.
    Do any of you know of a way to remove the CATs in the stock cans without damaging the CATs themselves & is there something else in there that needs to be removed or modified at the same time? :scratch
    #10
  11. Marotte
    May 29, 2002
    317
    San Francisco, CA
    Thanks for your patience in talking about that subject again.
    I'll ask my dealer to do the EPC-sectomy, by leave the SAS
    By the way, the 950 is becoming surprisingly popular here. I've only spotted one KTM950 during the previous 6 month. But when I went to my dealer yesterday (to get my final licence plate), there were 2 other black 950 under 1000km servicing!
    My dealer told me they sold 10 units since the beginning of the year, but 5 of them in the previous month...
    #11
  12. Katoum
    Katoum Adventurer
    Feb 26, 2004
    760
    British Columbia, Canada
    I'm not sure exactly what the Europe version has under the plastic, but if you have a canister and air valves, it is MHO that you should remove it. You will not have a problem till it rears its ugly head. Fuel will make its way into the vent line which is also the same air source for the carb venting, and your bike will run like shit. It could take days for all the gas to purge it's self thru the evaporative canister. You bike will be hard to start also, and will idle very erratically, and run like its running out of gas. All that is required to bring on this situation is to lie it over on its side, or fill the tanks incorrectly, on a hot day. Also if the air valve acts up and does not open when it should, the same conditions will appear.KTM even has a bulletin on this subject, so ask your dealer to read it.
    Cheers
    #12
  13. Gert
    Feb 1, 2004
    383
    Covington, GA
    I think it has been stated here before that the Euro bikes do not have the evap canister - and the problems associated with it.
    #13
  14. KTMax
    Oct 28, 2003
    1,099
    This is getting funny... The Euros don't have the canister but we do have EPC. The Yanks do have the canister but don't have EPC... Or was it the other way around?... :confused :D
    Marotte, You might have read this about 10.000 x on this forum already but ask your dealer to raise the fuel needles one clip to 3rd from top. BIG improvement! Especially with the Sommer airbox cover. I think everybody agrees on this one... :wink:
    #14
