Hello inmates, To begin, the driving force behind EPM Performance Imports is Klaus Huenecke. Klaus has been offering his expertise in the motorcycle and suspension industry for over 20 years now, and when you order from EPM, you get the benefit of his expansive and tremendous experience. When ordering one of our Hyperpro, Wilbers, or YSS shocks, they will arrive at your door ready to install with an optimal setup based on Klaus’s experience. This means most customers will need to make minimal adjustments to get the best performance out of their EPM suspension. EPM is the original importer and distributor of Wilbers suspension in the USA, the only Hyperpro USA importer, distributor and service center, and a distributor of YSS suspension products as well ranging from OEM spring replacements and custom shocks all the way to steering dampers to meet all of your motor sport suspension needs. Since the beginning, Klaus has always treated his customers as friends and family, and we will do our best to meet your wants and needs in every way we can. As EPM has grown through the years, our personnel, customer satisfaction and work ethics have not changed, only the brands we sell. BMW ESA Shocks We can proudly say that we have a proprietary method that allows us to rebuild all BMW ESA shocks – even though your dealer says they cannot be rebuilt. We can also shorten the OEM ESA shocks for a lower ride height and supply new springs (Hyperpro progressive springs) for the OEM ESA shocks as well. New ESA replacement shocks are available, with the Hyperpro ESA Hybrid or Wilbers WESA shocks. If the servo drives of your ESA shock no longer function, we also have replacement drives available for $ 355.00/piece including installation while we are servicing your ESA shocks. All servo drives are tested when the shocks are sent in for a service or when the ESA components are transferred to a new Hyperpro ESA Hybrid shock or Wilbers WESA shock. For BMW K1200/1300 GT/S/R owners, EPM is the only supplier in the USA that can provide custom built ESA shocks with the transfer of the original ESA components. Hyperpro Hyperpro hails from the Netherlands, and we have been offering their products since 2007. Their offerings include but aren't limited to: OEM replacement springs for forks and shocks, built to order shocks with 16mm shafts, and supplies steering dampers for all your handling needs. Their standard springs are all progressive rate, with linear rate springs available. Springs are offered standard in purple, and black is optional. Every replacement shock is built to simply bolt on for a perfect OEM replacement. All of their shocks come with a 5 year warranty and free 1st service from EPM. Wilbers Wilbers has partnered with Klaus since 2001 and is a manufacturer from Germany that offers OEM replacement springs for forks and built to order shocks with 14mm shafts that covers several thousand bike models in varying lengths with linear spring rates. Wilbers offers WESA shocks that are the perfect replacement for any bike with OEM ESA components, allowing you to enjoy cutting edge suspension with the added benefit of keeping your ESA adjustments intact. Every Wilbers shock comes with a 5 year warranty. YSS YSS has been our partner since 2006 and is a manufacturer from Thailand that offers twin and mono shock assemblies for the budget conscious rider. All YSS shocks come built for standard weights and they offer a huge selection for thousands of bikes. All YSS shocks come with a 2 year warranty. Be sure to mention "epmperf15" for a 15% discount on your orders! We look forward to hearing from all of you, and don't hesitate to contact us with any questions and concerns. http://epmperf.com/ e-mail: sales@epmperf.com phone: 732-786-9777
Inmates, we've got some new pictures from HyperPro! They recently had a Yamaha Niken GT at their headquarters for fitting and testing for the rear shock; it looks great! Here are some glamour shots of the Niken GT with their gorgeous, fully adjustable 461 shock with hose attached reservoir and their hydraulic preload adjuster, enjoy! What a wild machine! We've heard it handles very naturally even with this wild dual front wheel setup. The 461 shock has a hose attached reservoir as seen above with high/low speed compression damping (see those clickers on the reservoir body?) as well as rebound damping. HyperPro's HPA (hydraulic preload adjuster) makes preload adjustments a breeze and you will no longer have to fight with the bike when adjusting preload for you and your partner, or when you bring along extra luggage!
Brian, thanks for helping me with the 1988 Honda NX650 project. The rear spring, 0469, that you sent is working great. Hyperpro progressive vs OEM rear springs. I put 9.5 mm of preload on the Hyperpro spring then matched the front / rear suspesion rider sag. Wow its a nice bike! Should have got after the restoration sooner than 7 years. Thanks again for your help with this project. It means alot to get this bike road worthy.
