Err subframe and a tiny bike ...now a 1400
Discussion in 'Hacks' started by WILL_S, Jan 31, 2019.
  1. WILL_S
    WILL_S OUTLAW POSTIE 001
    Feb 16, 2009
    3,655
    goodly satisfactory place, qld
    Edit ... page 3 it takes a twist from a measly 150cc to 1400cc sidecar ... enjoy :photog
    Looking at building a subframe to mount a cargo style sidecar for offroading . The bike normally has a bash plate that bolts up to the front of the frame and under the motor ,pretty light construction but strong. Want to replace it and build something stronger that also connects up to the rear rack to mount the sidecar off . Is 1.6mm tube going to cut it ?
    Cheers
    'Rett Butler, Prmurat and pops like this.
  2. JustKip
    JustKip Long timer
    Apr 28, 2007
    9,194
    Fresno, CA
    <<< This guy is not an expert (disclaimer)
    I'm assuming you're talking about 1.6mm wall thickness, as the skidplate tube looks to be at least 20mm?
    In my not so expert opinion, you need at least 2.5--3mm wall thickness assuming you're sticking with a double down tube set up, and using a similar OD dimension to what the skid plate is using. I would personally continue both sides back to the luggage rack, and have your front upper and lower, and rear lower using a cross piece that ties both sides together. And I'd make a mounting bolt find its way to the sidestand bolt as well.
    Agent Wayward and WILL_S like this.
  3. WILL_S
    Feb 16, 2009
    3,655
    Sidestand mount and foot pegs are a on one bracket bolted to motor and samwiched between skid/bashplate bottom mount . Think I might weld the subframe to that bracket and then up to the rear rack . Be one piece and can unbolt at each end and motor .
    pops likes this.
  4. WILL_S
    Feb 16, 2009
    3,655
    Template for subframe left side
    Box or round tube ,undecided .
    pops and Pezz_gs like this.
  5. iatethepeach
    iatethepeach Been here awhile
    May 4, 2016
    378
    USA
  6. WILL_S
    Feb 16, 2009
    3,655
  7. WILL_S
    Feb 16, 2009
    3,655
    Started on the rear
    20190217_115233.jpg 20190217_172416.jpg 20190217_172434.jpg 20190217_171858.jpg
    iatethepeach likes this.
  8. brstar
    brstar Long timer
    Aug 17, 2007
    3,140
    Shoalwater Western Australia
    How the experts do it.
    Hard to get good pictures when the owner is trying to earn a living but I got some.
    OK for up to 25mph it seems though with the bigger loads they go slower.
    And a flash little gjigger in the showroom at the new EAON2 shopping centre here in Phnom Phen.
    Pretty neat factory custom and they had a bunch of variations.
    200cc and a triffle small for me.
    #8
    zzzak, Bar None, pops and 2 others like this.
  9. WILL_S
    Feb 16, 2009
    3,655
    Man that's some big old bed frames .:photog
    What I am bolting too it
    Been round the world ... well tested
    Haven't got any old beds.....
    #9
  10. 'Rett Butler
    'Rett Butler Happily Married
    Sep 15, 2009
    1,189
    Phoenix-Sedona-Flagstaff-Crested Butte
    I noticed a CT90 sidecar rig in “Sit, Stay, Ride” movie but I don’t know if you can see the mounting. Might be a friend of Drone?
    #10
    WILL_S likes this.
  11. WILL_S
    Feb 16, 2009
    3,655
    Slowly does it
    Was going to finish the subframe weekend past, but caught up with a mate on another project
    Chopped up the barrier to get the bends I wanted
    Turned up a slug that I can chuck a solid rod end into
    Finished stout
    #11
    pops, Bobmws and brstar like this.
  12. WILL_S
    Feb 16, 2009
    3,655
    Front mount coming long
    Turning time on junior
    Rear lower mount
    Couple bungs for a Dr leaner
    #12
    brstar and Bobmws like this.
  13. WILL_S
    Feb 16, 2009
    3,655
    #13
    iatethepeach and pops like this.
  14. WILL_S
    Feb 16, 2009
    3,655
    Got good mates
    @PRITCH139 popped round and sorted out my mig and said righto lets get this thing done .
    Nearly done tomorrow should see most of the subframe completed
    #14
  15. WILL_S
    Feb 16, 2009
    3,655
    #15
    Nudie and steam powered like this.
  16. Honda-50
    Honda-50 Vet Lurker
    Sep 19, 2006
    453
    SoCal since the beginning
    enjoying the assembly - - - any more pics on the leaner project?
    #16
  17. WILL_S
    Feb 16, 2009
    3,655
    Err yep
    Start a thread on that one soon , it's up chair and swingarm design eh @PRITCH139
    #17
    Honda-50 likes this.
  18. WILL_S
    Feb 16, 2009
    3,655
    Fun part
    Matching up a chair with welded mounts without getting the grinder out
    Whole lot is hinged so it can fold up still attached to bike and fit in a standard motorcycle crate for shipping .
    #18
    iatethepeach and Bobmws like this.
  19. brstar
    brstar Long timer
    Aug 17, 2007
    3,140
    Proper set up for trailer towing.
    #19
    OzCRU, FR700, WILL_S and 1 other person like this.
  20. WILL_S
    Feb 16, 2009
    3,655
    #20
