Err subframe and a tiny bike ...now a 1400
Discussion in 'Hacks' started by WILL_S, Jan 31, 2019.
  1. brstar
    brstar Long timer
    Aug 17, 2007
    2,133
    Shoalwater Western Australia
    Yep that's a project.
    #61
  2. DRONE
    DRONE Dog Chauffeur
    Oct 1, 2007
    8,995
    Tacoma - ish, WA
    This should take care of it!
    #62
    WILL_S and brstar like this.
  3. WILL_S
    WILL_S OUTLAW POSTIE 001
    Feb 16, 2009
    3,414
    goodly satisfactory place, qld
    Looks like I will use the old chassis as a template ..lighter ,stronger ,better suspension .
    The body started life as a single ,then got split up the guts and turned into a double .
    Boot lid and rack will be done in alloy .
    The old fibreglass and timber is freakin heavy
    Roof cage will become a single loop ...most likely alloy .
    #63
    Bobmws, steam powered and -KATO- like this.
  4. WILL_S
    Feb 16, 2009
    3,414
    Off to the blasters
    #64
    steam powered and mrsdnf like this.
  5. brstar
    brstar Long timer
    Aug 17, 2007
    2,133
    Blasters?
    Sounds fairly savage.
    #65
  6. WILL_S
    Feb 16, 2009
    3,414
    It is
    Many warn against
    Seen one done and didn't look too bad
    Got sick of trying to get 5 layers of paint off
    Not sure what media yet
    #66
    FLYING EYEBALL and GotDammitDave like this.
  7. brstar
    brstar Long timer
    Aug 17, 2007
    2,133
    Maybe it's my experience with heavy metal shot.
    They bead blast cars so that it doesn't heat and distort panels.
    Also I think there is soda blasting???
    But I am with you on getting paint of.
    #67
    WILL_S likes this.
  8. WILL_S
    Feb 16, 2009
    3,414
    They have a lot of options and have done all sorts of objects you wouldn't normally think about blasting .
    This is the first fibreglass sidecar they have done . Might end in tears
    #68
    brstar likes this.
  9. WILL_S
    Feb 16, 2009
    3,414
    No tears.......Stripped
    The stretch...
    #69
  10. brstar
    brstar Long timer
    Aug 17, 2007
    2,133
    Sweet so far.
    Is that an Ali mudguard?
    Looks like a previous owner put lots of hours into it.
    Hopefully while there's heaps to do, you input will take less time.
    Mind now that we are all unsociable bastards you have to do something between mouthfuls.
    #70
    WILL_S likes this.
  11. WILL_S
    Feb 16, 2009
    3,414
    Guard is a mix of bog /fibreglass /board and a Bundy inner guard :lol3
    Defiantly a bonus that its been cut to take a bigger wheel than the old 10 they used to run .
    #71
    GotDammitDave, Bobmws and brstar like this.
  12. WILL_S
    Feb 16, 2009
    3,414
    Got some good mates
    One in particular is a creative bugger.
    Went to see him to knock up a boot lid.
    He said wouldn't be fun to build that body out of alloy . Takes a couple of pics starts sketching . Goes from building a djp wide body in alloy to ural style tub widened but nose lines following the gsx fuel tank
    Will be pushing it to the legal limits
    Who knows where this will end....
    #72
    Bobmws and steam powered like this.
  13. brstar
    brstar Long timer
    Aug 17, 2007
    2,133
    Got a big sheet of ali in the garage. 1.5m x 3.6 I think.
    I have a design in mind for the Guzzi but if your plan was interesting I would look at it :1drink.
    You pic shows 1865 max.
    Is that width?
    It's 1850 here.
    Don't have a clue why so narrow.
    Trucks are 2500 or thereabouts plus mirrors.
    It used to be 2.1m here.
    And bikes have grown somewhat since.
    #73
  14. WILL_S
    Feb 16, 2009
    3,414
    Lucky mentioned that it should be 1860mm , qld regs.l can go a bit wider and chuck on some narrow bars if it ever gets questioned . . Another thing interesting is you can't have less than 75mmn trail .
    Got a couple of cad pics through from my mate . Comes in at 21kg of alloy for a 700 x1850 body . Pulled the width in to meet the overall regs and have a bit more space between the tub and bike .
    Next up will be a quote from the laser cutters , Joe reckons it's worth it to save time welding and not have me cut it .
    #74
    steam powered likes this.
  15. brstar
    brstar Long timer
    Aug 17, 2007
    2,133
    Nice.
    If your mate is really good he will put tabs and matching slots in the Laser cut sheets so everything will line up perfect.
    No hammer needed.
    Well maybe only a softie.
    That's 75mm steering trail?
    Standard will be nearly double that.
    I dream of 75mm trail.
    Claude uses 3mm Ali which would make for a solid body.
    Its what I have also.
    #75
    WILL_S likes this.
  16. WILL_S
    Feb 16, 2009
    3,414
    He mentioned tabs. He has a lot of experience in aluminium work and at the mockup stage is looking at 2mm and reckons that would be plenty . Will mention 3mm to him .
    75mm of steering trail . Not sure what i should be looking for ? The qld tmr website is pretty clear on bike mods now with diagrams and measurements and good descriptions . Got me buggered on the width that changes with handlebars .
    #76
  17. steam powered
    steam powered just a regular punk
    Jun 17, 2018
    530
    New Zealand
    FWIW I had to rebuild the rear tub on a Series 1 Land Rover, used 1.6mm ally which was actually thicker than the original tub although I did use 3mm on the floor.
    #77
    WILL_S likes this.
  18. WILL_S
    Feb 16, 2009
    3,414
    #78
    Bobmws, brstar and steam powered like this.
  19. brstar
    brstar Long timer
    Aug 17, 2007
    2,133
    That forklift seat would have to tick a few boxes.
    That and rubber mounting the body perhaps.
    #79
    WILL_S and steam powered like this.
  20. steam powered
    Jun 17, 2018
    530
    New Zealand
    Forklift seat if you can make it work and have sufficient leg room through the full stroke of the seat.
    The other two will require a second frame to hinge off the main frame. With a double fibreglass tub I would imagine the weight would start getting up a bit.
    #80
    WILL_S likes this.
