Err subframe and a tiny bike ...now a 1400
Discussion in 'Hacks' started by WILL_S, Jan 31, 2019.
  1. Jeff 8
    Jeff 8 Been here awhile
    Feb 4, 2013
    218
    Sydney, Australia
    You can simplify the gearshift by using a GS500 one like I did on my Bandit. See the pictures, the shift pattern even stays the same.
    WILL_S likes this.
  2. WILL_S
    WILL_S OUTLAW POSTIE 001
    Feb 16, 2009
    3,414
    goodly satisfactory place, qld
    Nice
    Got more pics of your bandit outfit ?
  3. Jeff 8
    Feb 4, 2013
    218
    Sydney, Australia
    I have had a few people ask, so I will do a separate thread.
    Bobmws, brstar and WILL_S like this.
  4. WILL_S
    Feb 16, 2009
    3,414
    Looking forward to it
  5. Reklaw59
    Reklaw59 Faster than your Nan.
    Feb 14, 2010
    1,113
    Perth. West Oz
    Will, in post #100 there is a photo of "one of those" pipe benders.
    How is that working for you, some love em some hate em.
  6. WILL_S
    Feb 16, 2009
    3,414
    Slow and steady is ok, its one of those tools you have to get a feel . No big radius jobs on it atm . A mate had a old Australian made army one it bends nicer than my china one .
    Aussie army bender
  7. WILL_S
    Feb 16, 2009
    3,414
    Water jet swingarm parts are cut .
    Knocked up a bracket to hold sidestand switch in the up position .
    Spent a bit of time trying to workout out leading link dimensions .
    Then off to see a mate and measure his . Probably won't be built the same way but measurements are in the ball park
    Next weekend might see a mocked up swingarm and a tacked together partial chassis .
  8. WILL_S
    Feb 16, 2009
    3,414
    Some bits have come out of the computer into the real world .
  9. WILL_S
    Feb 16, 2009
    3,414
    It's the little things
  10. brstar
    brstar Long timer
    Aug 17, 2007
    2,133
    Shoalwater Western Australia
    Hmm noice swarfe.
    WILL_S likes this.
  11. DRjoe
    DRjoe Long timer
    Sep 6, 2007
    7,196
    Sunshine coast qld
    Nice will. lets hope my math was correct and i’ve given you the correct dimensions.
  12. brstar
    brstar Long timer
    Aug 17, 2007
    2,133
    Your mate could design and cut out some triple trees with increased offset ???
    I wonder what thickness Ali can be water cut?
  13. WILL_S
    Feb 16, 2009
    3,414
    That he could
    I was thinking that in your thread
    @DRjoe ?
    Haha maths, dimensions and 100km apart .... It's all numbers .. we shall see tomorrow
    Swarfe porn ...hot swarfe @brstar
    mrsdnf, DRONE, Bobmws and 1 other person like this.
  14. WILL_S
    Feb 16, 2009
    3,414
    20200607_133738.jpg Lunchtime update
    Collecting burger n beers while Joe hangs at the shop
    High Octane and brstar like this.
  15. WILL_S
    Feb 16, 2009
    3,414
    More puzzle pieces
  16. DRjoe
    DRjoe Long timer
    Sep 6, 2007
    7,196
    Sunshine coast qld
    i don't have a water jet cutter so just use a big mob that do.
    They can cut pretty thick stuff but i doubt you could get bores accurate enough for clamping forks even with the 5 axis cutter.
    You could get a blank cut out with most of the material removed and then bring the important bits to spec on a manual mill with boring head.
    That would be cheaper than having it cnc machined and probably a bit easier than manual machining the whole job.
    Who ever your local waterjet cutter is might be able to organise the whole job for you.
    Bobmws and brstar like this.
  17. High Octane
    High Octane Long timer Supporter
    May 31, 2013
    2,520
    South Dakota
    Me likes it. But I’m not so sure about the small bolts. Have you calculated the sheer on them? I don’t know what to expect in use so I usually way over build. But I’d rather build light like yours if I could be more sure of the actual loads.
    brstar likes this.
  18. WILL_S
    Feb 16, 2009
    3,414
    No I haven't. My partner in crime is smarter than i and i trust his work even when my own brain is farting numbers eh @DRjoe .
    Just going with the size of the original shock bolts . Most holes are 8 or 10mm on the parts .
    It's all shock and swingarm adjuster related
    Did some load numbers when making the subframe and there are 2 bolts that I would wince at . The thing is with the other 2 larger bolts and the clamp force it was surprisingly good. Real world testing will tell .
  19. DRjoe
    DRjoe Long timer
    Sep 6, 2007
    7,196
    Sunshine coast qld
    Are your meaning the 3xm8 bolts used for holding the removable swing arm section on?
    i haven't run the numbers, not smart enough for that as im not an engineer.
    The original idea was to use m8 shoulder bolts in reamed holes but i think it’ll just be plain m10 bolts now with maybe 2 locating dowels.
    We’ve also designed in a key and keyway for the swingarm plate to locate on but that was more to aid in assembly when changing a tyre.
    would love any suggestions or feedback.
  20. High Octane
    May 31, 2013
    2,520
    South Dakota
    I don’t know what the loads are on the removable swing arm. Probably not too much unless the axel is small and wants to flex. I might add a 1/2” dowel or two just to be sure the bolts don’t sheer. Here’s a pic or two of how Claude built the one I now have. His swing arm is a bit different. I like yours better. But I up sized the axel to 22mm iirc when I installed the rim from a Suzuki dl1000. The rim he originally installed didn’t hold up to my abuse!
    891E23A5-C4B5-4D66-8933-36AEFF0AD31C.jpeg 13DC0175-2877-426D-AFFD-5E32A71138F5.jpeg BE2F9606-FD44-4E75-BA45-1EFCCB7F665F.jpeg 5FC863D8-5F6F-4013-9635-C77A4F04F246.jpeg
    WILL_S likes this.
