Exhaust Cam Replacement 2016GSA
Discussion in 'GS Boxers' started by ckindt, Aug 15, 2019.
  1. ckindt
    ckindt Been here awhile Super Supporter
    May 9, 2008
    458
    Omaha, NE
    Hi.
    I acquired a new set of the updated exhaust cams for my GSA. I have a few questions:
    1. Should I use assembly lube on the bearing surfaces or is it adequate to coat them with motor oil prior to assembly?
    2. Are there any concerns with the break-in of the new cams' bearing surfaces with the old surfaces?
    3. I only plan to replace the exhaust cams, hex bolts and washer; 11 31 8 564 541, 11 31 8 564 542, 07 11 9 907 510, 07 11 9 907 514 and 11 12 8 535 758. Are there other parts that should be replaced with the cams?
    Thank you!
  2. Dogslobber
    Dogslobber Been here awhile Supporter
    Aug 28, 2014
    862
    Palmer,AK
    no answers, following with interest!
  3. LAFS
    LAFS Long timer
    Dec 15, 2016
    1,942
    You can just use oil as that is what you use when you remove the cage and remove the cams to replace valve shims.
    ckindt likes this.
  4. Huzband
    Huzband Team Dirt
    Oct 4, 2006
    10,840
    Cowford, Fl.
    When installing new cams ALWAYS use assembly lube. Motor oil is not sufficient for the new surface on the cams, and the assembly lube will enable proper mating of the new & old surfaces.
  5. Lead Wrist
    Lead Wrist Mehr Gelände Weniger Straße
    May 26, 2007
    8,531
    Zer0-Zer0-Zer0-Zer0
    +100 :thumb
    ckindt likes this.
  6. lewisjr1
    lewisjr1 Long timer Supporter
    Sep 26, 2008
    5,911
    DC metro
    Under $10 at decent auto parts stores...
    ckindt and Huzband like this.
  7. SourKraut
    SourKraut Long timer Supporter
    Nov 20, 2004
    8,938
    Vermont
    How and why were they updated?
    WillieJ likes this.
  8. lewisjr1
    Sep 26, 2008
    5,911
    DC metro
    Presume you're asking about the volume of gear oil for the FD.
    The how was by BMW directive.
    The why followed a bunch of seal failures attributed to too much gear oil.
    #8
  9. WillieJ
    WillieJ MotorMan
    May 8, 2004
    260
    City of Subdued Excitement, WA
    No, I think the question was about why the exhaust cams needed replacement.
    #9
    SourKraut likes this.
  10. SourKraut
    Nov 20, 2004
    8,938
    Vermont
    I was asking about the “updated” exhaust cams.
    #10
  11. Getdrty
    Getdrty Adventurer
    May 30, 2019
    72
    Maryland
    When were they updated?
    This seems like the kinda of thing that should be warranty and have a warranty extension period.
    #11
  12. lewisjr1
    Sep 26, 2008
    5,911
    DC metro
    Oops, I was typing in the wrong thread.
    #12
  13. ckindt
    May 9, 2008
    458
    Omaha, NE
    This thread discusses they why they were updated (presumably). The decompression mechanism is deployed at low engine speed.
    I'm not sure when they were updated.
    I'm replacing mine for two reasons:
    1. I'm really driven by obsessing over really little things that are usually quite frivolous in nature. Especially as I get older.
    2. I have experienced the same symptoms as discussed in the linked thread.
    In my case, the tap or clap noise only occurs if these conditions are met:
    1. engine thoroughly warmed up
    2. ambient temperature is very hot. >90F
    3. engine at idle
    4. momentary stumble in engine rpm at idle
    The noise is only audible one time at the moment the stumble occurs. It seems to be on the right side.
    This scenario repeats it self at no particular frequency. Sometimes a few seconds and other times tens of seconds apart.
    As soon as the engine speed is greater than idle, there is no re-occurrence of the noise.
    As the temperatures cooled down here, I haven't even heard the noise at all.
    And for the record, all of my cams are in very good condition. There is no abnormal wear associated with the soft cam issue with just over 11,000 miles on the odometer.
    #13
    1coolbanana and Huzband like this.
  14. SourKraut
    Nov 20, 2004
    8,938
    Vermont
    Got it, I am guilty of actively ignoring any noises these tractors make so no idea whether my 16’ GSA is afflicted with this feature. I will file this as a “need to know basis” and continue to wear earplugs.
    #14
  15. LAFS
    LAFS Long timer
    Dec 15, 2016
    1,942
    Again there is no need to use assembly lube on the cams. When you replace shims you pull the cam cage and cams to get to the shim buckets.
    There is NO ONE using assembly lube to put those cams back in the cage. I mean no one! I have to look but I am sure it is not called out in the BMW DVD either but will check to be sure. There just is no need whatsoever to do so.
    I just checked the DVD there is no mention of using ANY lubricant in replacing the cam shafts. Not even motor oil.
    Again after 20 or so removals of cams in wetheads I have always just wiped them clean with a lint free rag and then wipe them with motor oil.
    #15
    Dale402, BluByU and bajaburro like this.
  16. LAFS
    LAFS Long timer
    Dec 15, 2016
    1,942
    Well hopefully you do not have any mating! That is the problem the cam lobe is mating with the cam lobe follower.
    It is not called out and you do not use assembly lube in swapping cams or doing valve adjustments on a R 1200 GS/GSA/RT motor.
    The cam lobes are supposed to be harder then anything it comes in contact with and that is the issue there is a batch out there that is not.
    If you were pressing bearing and such yes, but these float in a oil bath in that cage there is no bearing just a flat running surface with a oil channel in it.
    #16
  17. Huzband
    Huzband Team Dirt
    Oct 4, 2006
    10,840
    Cowford, Fl.
    You & I answered the OP's question differently, it's up to him to decide how he re-assembles his engine. That's as far as I'm going.
    #17
  18. ckindt
    May 9, 2008
    458
    Omaha, NE
    hmm. :hmmmmm
    I think either would be fine as long as the surfaces aren't dry during initial start up.
    I'm not sure, after briefly searching the web, that assembly lube is necessary in my case; I swap cams and go ride.
    It seems the value of assembly lube is in its ability to not drain away as the assembled engine sits for an extended period of time.
    Whereas oil would seep out of the bearing area and leave it dry for the initial start up.
    Assembly lube vs. camshaft lube:
    I haven't read much on the differences except that molybdenum based cam lubes shouldn't be used in an engine with a wet clutch.
    There is a possibility that the moly can cause problems with the clutch and it can also clog oil filters.
    My current thought (65% committed) is to just use motor oil to lube the new cams, then go ride.
    Thanks to everyone's input so far!
    #18
    mikegc, Dogslobber and LAFS like this.
  19. LAFS
    LAFS Long timer
    Dec 15, 2016
    1,942
    Here is the DVD procedure. No assembly lube required. Of course your motorcycle you can do what you like. Everyone can do their work how they prefer. I like to stick with the information that the manufacturer provides. The Haynes manual makes no mention of any lube either.
    https://lafsbmw.s3.amazonaws.com/cam.docx
    #19
    ckindt and lewisjr1 like this.
  20. ckindt
    May 9, 2008
    458
    Omaha, NE
    Great info. Thanks!
    My previously stated commitment level has risen to about 85%.
    #20
    Dogslobber, lewisjr1 and LAFS like this.
