Exhaust coating/paint
Discussion in 'The Garage' started by ColumboNH, Aug 23, 2019.
  1. ColumboNH
    ColumboNH Been here awhile
    Apr 14, 2017
    136
    New Hampshire
    I have an exhaust header from a twin cylinder snowmobile engine that I would like to have coated or high temperature painted. Does anyone have a recommendation for a shop I could send this to for this job? I’m open to diy ideas too, but the typical bbq paint, etc does not last on this application. Thanks in advance!
  2. kantuckid
    kantuckid Long timer
    Nov 29, 2007
    9,083
    Kentucky-Eastern that is!
    There are other high temp paints besides BBQ paint. One I used was same brand as box stores sell and I called the mfg to get a couple cans to paint a SS flue green on my great room stove which was also green. It's been on there since 2004. Play on google for high temp paints.
    edit:
    I may have mis-spoke for a header though as ceramic makes sense.
    Mark G likes this.
  3. markk53
    markk53 jack of all trades...
    Dec 20, 2007
    17,986
    Delaware Ohio
    There is no substitute for ceramic coating. I've done both Jet Hot and Aesthetic Finishers in Troy OH. Both did good. I will do Aesthetics on any further work because it was a bit easier to deal with them. Jet Hot has several plants and your parts have to be sent wherever they decide to do it. AF has the plant in Ohio, where I happen to live.
    The coating does not corrode as long as the prepped surface has no corrosion. I'm not sure Jet Hot sufficiently cleaned the megaphone for my pipe and it got rust bubbles under the coating. That is why the parts went to Aesthetic Finishes for the second job. I will say it holds heat in, radiating less heat than bare or chromed steel and it requires no upkeep. I also learned that the coating is silver in color, that any other colors are a dyed coating applied over the silver, a scratch may show silver. The coating has a galvanic effect, which means smaller scratches will actually "heal over", no rusting. In about 20 years of use my head pipe had no rust develop in spite of scratches and my never cleaning/polishing the pipe. The megaphone held up well on the outer finish.
    Expensive, but well worth it. Wish I would have had it on my Kaw triple in 1975, could have saved some sand blasting and a bunch of heat proof paint.
    SmittyBlackstone and ColumboNH like this.
  4. mslim
    mslim If it's worth doing... it's worth overdoing
    Jan 11, 2015
    1,285
    Austin of the Ozarks
    My bike came with a vintage black Luftmeister 2-into-1. I had the local Cerakote gun guy redo it in satin black. It's held up well and was under $100. As with painting, good prep is the key to a durable result. YMMV depending on the applicator.
    SmittyBlackstone likes this.
  5. vtduc
    vtduc Been here awhile
    Dec 25, 2006
    392
    I used the Cerakote air dry version on the headers for my Ducati Elefant, and it's been holding up perfectly, albeit it's only been 8 months of riding so far. The nice part is that I could spray it myself and didn't have to send them out (I do have access to sandblast equipment to prep the header)
  6. markk53
    Dec 20, 2007
    17,986
    Delaware Ohio
    Interesting...
  7. ColumboNH
    Apr 14, 2017
    136
    New Hampshire
    Looking at cerakotes site I saw a max temp of 500 degrees unless I was missing something?
  8. vtduc
    Dec 25, 2006
    392
    #8
    concours likes this.
  9. markk53
    Dec 20, 2007
    17,986
    Delaware Ohio
    So is Cerakote like paint in application?
    #9
  10. vtduc
    Dec 25, 2006
    392
    Yes, it's like paint. I used a touchup style spray gun to avoid wasting too much material in overspray. The cerakote has a lot of solids that like to settle out, so the bottles that it comes in have to be well shaken / mixed, and I tried to shake the gun periodically as well. I purchased my two colors in 4 oz "tester" sizes, and had a lot of material left over. The Elefant has 2 headpipes and a single exhaust and I don't see why two similar bottles wouldn't coat a 4 cylinder dual exhaust system.
    #10
  11. markk53
    Dec 20, 2007
    17,986
    Delaware Ohio
    Thanks, interesting possibility for rusted head pipes on my Zephyr. The exhaust looks great on the bike, coating the header would keep the pipe set up for far less cost than an exhaust system.
    #11
  12. DilanYah
    DilanYah Adventurer
    May 21, 2019
    18
    London
    Actually any sort of paint or coating will just flake off if you put it on a rusty exhaust. You really need to clean it to bare metal and then paint or get ceramic coatings on it.
    #12
  13. markk53
    Dec 20, 2007
    17,986
    Delaware Ohio
    I realize that, point actually is once rusty no way to clean up without something over the metal. It would just rust again. So I get it blasted off, then coat it. Sure would have been nice on the Dencos on the 400 triple. No matter what the prep, the head pipe to the cone would burn away near instantly then rust.
    #13
