F700 16T sprocket = Gear indicator failure?
Discussion in 'Parallel Universe' started by MrMac, Apr 3, 2018.
  1. MrMac
    MrMac Long timer Supporter
    Aug 19, 2007
    2,823
    Dacula, Ga.
    A few months back I purchased a used 2017 F700GS for my wife. She was having problems stalling in first gear, which IMHO, was way too tall! So, did my research an installed a 16T front sprocket.. Much better we thought..!
    Well, not long after, she started having problems with the gear indicator going out. It only happened once she hit 6th gear and would randomly come back on after gearing down. Sometimes it would take awhile (even after stopping and starting), sometimes it would come back right away. Figured it was the potentiometer, which the dealer replaced (bike still under warranty). But that did not fix it.. Happened again not long after we picked the bike up (as soon as she hit 6th!).
    So, took it back and now they are telling me it was the sprocket change that is causing the problem! Apparently, the computer gets 'confused' once the bike is in 6th, and can't really tell what gear it is in. From reading the forums, a lot of people have made this swap and yet I've never seen where anyone has experienced the same problem! The bike is still at the shop, waiting for a new 17T (stock) sprocket.. I suppose I could put the old one in just to check and see if that fixes this, but it is a bit worn so it would have to be replaced soon anyway..
    But my question: Does this make sense? Has anyone else swapped a 17T for 16T (or any other swap on a BMW twin for that matter) experienced this same issue? Or is this something unique to the 2017+ models? And yes, I've searched through the forums and haven't found this mentioned..
    Changing sprocket sizes is such a common thing on motorcycles, and yet I've never heard of any others having such issues.
  2. zero war
    zero war Zee
    Oct 14, 2009
    524
    North Bergen, NJ
    I have a 16T on my 2015 BMW F700gs and I have zero issues with the gear indicator.
    MrMac likes this.
  3. bmwroadsterca
    bmwroadsterca RadioFlyer
    Jan 3, 2007
    1,188
    Lanark County near Ottawa ON
    Can't see how sprocket size and gear indication can be related. The sensor has no idea what sprocket is fitted.
    woodsguy, NaMi, MrMac and 1 other person like this.
  4. sieg
    sieg Wearing out tires......2 at a time, day after day. Supporter
    Jul 9, 2008
    8,929
    Southern Illinois USA
    ^ Yeap dealer BS, I've run 16 and 17 on our 800, 650twin and 700 GSs.
    Just humor them let them put the 17 on and find that that doesn't fix it, it's warranty so they're wasting they're own time.
    MrMac likes this.
  5. The Maz
    The Maz Clueless and lost
    Feb 14, 2013
    561
    Medicine Hat , AB
  6. AndyBoundy
    AndyBoundy Adventurer
    Mar 1, 2017
    81
    Merida, Mexico
    I run a 16t (from an 800) on my ‘17 700 and my neutral indicator is intermittent now. Interesting that you’re having issues too.
  7. MrMac
    Aug 19, 2007
    2,823
    Dacula, Ga.
    Well, actually I could see this IF, for some reason, they wanted to compare engine speed (RPM) to ground speed (picked up from the rear wheel sensor I would guess). If the actual values are different from 'expected' values, then something is amiss. Now why they would do this, I don't know. Apparently there was a change to the fueling (?) system beginning in '17 that had something to do with EU compliance. I can't imagine this being the cause though.
    morfic likes this.
  8. MrMac
    Aug 19, 2007
    2,823
    Dacula, Ga.
    #8
  9. bmwroadsterca
    Jan 3, 2007
    1,188
    Yes, I considered that but quickly dismissed the possibility. Even BMW doesn't make things that bizarre.
    Sent from my SM-T530NU using Tapatalk
    #9
    cgguy09 and MrMac like this.
  10. bmwroadsterca
    Jan 3, 2007
    1,188
    There are lots of reports about gear indicator failure that have nothing to do with the final drive.
    #10
    MrMac likes this.
  11. MrMac
    Aug 19, 2007
    2,823
    Dacula, Ga.
    Interesting.. However, if you are not have the exact same issues (loosing the indicator when you hit 6th gear), then that is important. I would expect the same fault from the same cause. This still leads me to believe it is in a switch or potentiometer, as would yours.
    #11
  12. bmwroadsterca
    Jan 3, 2007
    1,188
    There is an adaptation reset function for the gear potentiometer using a GS911. I'd try that first.
    #12
  13. MrMac
    Aug 19, 2007
    2,823
    Dacula, Ga.
    Thanks! Will look into that. I'll be back at the dealer tomorrow anyway so hopefully we'll get this resolved.
    Thanks to everyone for the replies! And if there is someone out there who has made the same sprocket switch on a 2017 F700 without any problems at all, I"d still like to hear about it just to have a good point of reference!
    #13
  14. BygDaddee
    BygDaddee Long timer
    Oct 26, 2012
    13,395
    Bris
    It wont be the sprocket
    Are you sure you didnt damage or dislodge or disconnect the gear indicator sensor ?
    #14
  15. MrMac
    Aug 19, 2007
    2,823
    Dacula, Ga.
    Yep, I'm sure. The potentiometer was just replaced anyway, pretty sure they would have noticed if something was wrong .
    #15
  16. Arbolmano
    Arbolmano Not so Studly
    Feb 1, 2014
    795
    Commiefornia! 93420
    I put a 16 tooth on my 15 F700 with zero issues. Sure awakened the bike.
    #16
    AndyBoundy and MrMac like this.
  17. AntReed
    AntReed Been here awhile
    Nov 17, 2014
    298
    Kent, UK
    When I have installed aftermarket gear indicators on bikes I have had to select each gear and run it through the Rev range whilst on a centre stand or paddock stand which I assume was to calibrate the wheel speed to the engine revs?
    If that is the case with the way the onboard indicator works then it could be the sprocket change would cause issues.
    It might be that in 6 at a certain speed the bike is expecting the revs to be x when they are actually y and that throws the error.
    Having said all that, lots of others are having no issues but the dealer have changed the only other thing that could cause the issue so it is a bit confusing.
    #17
    MrMac likes this.
  18. Tigershark48
    Tigershark48 My other BMW is a Roadster.
    Mar 18, 2017
    1,488
    West Bend, WI
    No doubt the sensor communicates back to the ecu via wiring. Could be somewhere in the harness. Could also be something in the ecu.
    I could see the ecu throwing an error if rpm doesn’t match mph sensed off the wheel, but I don’t see how it could cause a false gear indication. That makes no sense.
    Not to mention people change sprockets routinely, so the ecu should not be affected.
    #18
    MrMac and sieg like this.
  19. SpaffyPD
    SpaffyPD Adventurer
    Mar 27, 2015
    29
    Santa Clarita, CA
    I put on a 16T sprocket on my F700gs; at high RPMS [usually in 6th on the freeway] my gear indicator goes blank or or will sometimes display 5th gear when I'm in 6h - as I recall. No issues with ride-ability, shifting, or neutral light. It come back and displays the proper gear when I shift. It had no issues with the 17T nor would I expect it to if I switched back. Not a concern of mine.
    If it has a year basis my 700 is a 2015.
    #19
    MrMac likes this.
  20. MrMac
    Aug 19, 2007
    2,823
    Dacula, Ga.
    A little update: Went to the dealer this AM (for some work on my Triumph), and they still stand behind their diagnostics. Can't really blame them.. A couple of things to note:
    1- This is what their diagnostics tool is telling them. Although I'm not sure why they didn't get this the first time, except that maybe there was originally something wrong with the potentiometer as well. And this problem is consistent with similar issues they have seen in other models, just not the F700!
    2- BMW will not authorize any additional diagnostics (under warranty anyway) until the bike is put back in 'stock' condition. So, no matter what I or anybody else thinks, we have to put a 17 tooth back on before going any further.
    Honestly, it wouldn't surprise me that much if this fixes it. Crazy perhaps, but after talking for a bit with the owner of the shop, it is the direction many manufacturers are going in order to tweak performance in every possible way. It is quite possible my F700 has a software version that depends on a stock final drive.. Hopefully I'll know for sure in a day or two. Stay tuned!
    #20
    Tigershark48 likes this.
