[F700GS] Shorter handlebar?
Discussion in 'Parallel Universe' started by Pete7874, Sep 25, 2013.
  1. Pete7874
    Pete7874 Been here awhile
    Jul 3, 2013
    409
    Michigan, USA
    Does a shorter handlebar exist for the F700GS? If so, who makes one? Looked at Touratech and Wunderlich, but didn't see any.
  2. Camel ADV
    Camel ADV Long timer Supporter
    Mar 4, 2009
    2,499
    Calgary
    Narrower or less tall? Either way ProTaper, Renthal etc have tons of options for height, width and sweep and will be close to the $100 mark.
  3. Pete7874
    Jul 3, 2013
    409
    Michigan, USA
    Narrower.
    I looked on Renthal's website. F700GS isn't listed. When I choose F650GS or F800GS instead, it tells me "There are no results matching your current Bike selection.".
    With ProTaper, I'm not sure how to determine which bar would fit. They don't specifically list any BMW fitments.
  4. Bayner
    Bayner Long timer
    Mar 27, 2008
    2,429
    Penticton, BC, Canada
    If you just want narrower, a lot of guys around here just cut an inch off the end of the bars on their woods bikes.
    Don't know how well that would work with hand guards and all that stuff though...
  5. Camel ADV
    Mar 4, 2009
    2,499
    Calgary
    Lots of large bike shops will have several different bends in stock. You could go down and see what works for you. If you're just looking for narrower a hacksaw will accomplish that but you'll have to figure out something for the threaded insert on the bar end for bar weight or hand guards. You'd need to do that with aftermarket too.
  6. Hamish71
    Hamish71 Been here awhile
    Mar 20, 2011
    500
    Australia
    I have pro taper Carmichael bend on my f800gs. About 2in narrower than stock.
    Some advice.
    1. Most bars will come with a knurled left hand grip. this makes it difficult to fit the left hand assembly onto the bar. I got mine on, but it will never come off again (in one piece anyway).
    2. both sides require a small hole drilled in them for the locator screw.
    If you are handy, its all not that hard. If you aren't, then maybe get someone like Highway Dirt Bikes to provide the bars pre drilled.
    Gatornation likes this.
  7. DivingPixel
    DivingPixel forever n00b
    Mar 21, 2013
    10
    Eastern Yurop
  8. Pete7874
    Jul 3, 2013
    409
    Michigan, USA
    #8
  9. Dorito
    Dorito Dreamer and Doer
    Jul 31, 2010
    7,629
    Maryland
    I have got ask , what attribute are you trying to improve? She is pretty porky on the front and rear...
    #9
