F750/850GS Accessories
Discussion in 'Parallel Universe' started by apexal, Jul 12, 2019.
  1. AdamChandler
    AdamChandler Ascending n00b
    Feb 29, 2016
    10,192
    Hanover, NH USA
    $469 is the cheapest. 10-15% off coupons are always available on Black Friday if you can wait.
    Cheapest - https://www.sargentcycle.com/Seats-Accessories/Sargent-Seats-BMW-F750-850GS/ (no grip zones on the edges, different cover)
    Step up - best for touring & standing has grippy sides and a nice lower back arch support - https://www.sargentcycle.com/Seats-Accessories/BMW-F750-850GS-PPlus/
    Enduro style, flat seat - https://www.sargentcycle.com/Seats-Accessories/BMW-F750-850GS-Enduro/
    Here's their 1st and 2nd tier seat heights:
    Our F750GS has a Low Seat, so the rise is only .4" which is completely appropriate. the Low seat from BMW has so little material that this would be a nice increase while still being .6" lower than BMW's standard.
  2. heatmizr
    heatmizr n00b-tastic
    Jan 5, 2012
    1,072
    CLT, NC
    I have the Ralleye seat so it is the tallest (at 35"). I wouldn't mind dropping an inch +/-. But mostly concerned with getting rid of the forward slant which keeps my panties bunched up all the time!
    I am going to disassemble my stock Ralleye seat this winter, and shave down the rear half of the sitting area to be lower, and more dished. It will cost me only time.
    If this fails to improve it, then I will look at aftermarket options next year. Hopefully there will be more of them by then. I was interested in the Seating Concepts that SnoDrtRider got... but read that their seat is 1.5" lower than the standard seat which is lower than my Ralleye by 1.2" already... Not sure I want to drop 2.7" as this may require re-locating my foot pegs and levers. I can get both feet down now (not quite flat) so that would be a lot of unnecessary drop.
    Of course, I might get less wind turbulence being that low.
    AdamChandler likes this.
  3. SnoDrtRider
    SnoDrtRider I've been lost here before...
    Mar 21, 2006
    7,167
    South Jersey... Close to the Pines
    You should go back and read the Seat Concepts web page again I believe it says their seat is 1.5" lower than the Rally Seat...
  4. TitanRanger
    TitanRanger Adventurer
    Aug 2, 2014
    21
    Chesapeake, VA
    F750GS is 7/8, not 1-1/8.
    Horizoneyes likes this.
  5. TitanRanger
    Aug 2, 2014
    21
    Chesapeake, VA
    I'm using the aforementioned bracket. It is a quality piece of metal. I'm using it to mount my NAV6 above the TFT. No vibration at superslab speeds. Easy to install, too.
  6. slackline
    slackline Been here awhile
    Dec 1, 2009
    298
    Inland PNW
    I got the SC kit, and it is way better than the OEM forward "push" into the tank. Still there a little bit, but it's so much better and way, way cheaper than a Sargent.
  7. TitanRanger
    Aug 2, 2014
    21
    Chesapeake, VA
    SnoDrtRider, I have had zero issue with side-to-side movement, nor vibration with the $30.00 import. I'm sure the Dresden mount at $120+ mount is a fine piece of engineering, but sometimes less is more.
    SnoDrtRider and heatmizr like this.
  8. heatmizr
    Jan 5, 2012
    1,072
    CLT, NC
    Hear that apexal?? ;-P
  9. SnoDrtRider
    Mar 21, 2006
    7,167
    I would have likely tried this mount but did not see them until I built my own for $30.
  10. heatmizr
    Jan 5, 2012
    1,072
    CLT, NC
    You are sort of right! I was reading the specs off the Sargent site... My bad.
    On the Seat Concepts it says it's 1.5" lower than the GS Adventure... but I have no idea how that compares to my GS with rally seat...
    * just looked it up, GS Adventure standard C is 34.4. Which would still leave me 1.9 in lower than my current seat... A bit much.
    Have you seen anywhere on their site where they show examples of the different fabric choices? They list three different kinds but I don't know which is which in the picture.
  11. SnoDrtRider
    Mar 21, 2006
    7,167
    https://seatconcepts.com/pages/materials-gallery
    I had a Carbon Fiber with Low Slip on my last one and it was good. This time I figured I would try the Diamante... I didn't care for it when I first took out out of the box but after using it I like it a lot.
    It is like a synthetic suede and dries very quickly when wet...
  12. burangs
    burangs Javenturer
    Jul 28, 2015
    117
    Columbia, SC USA
    I placed an order for a Sargent last night. Really looking forward to it as my bottom needs a break! I ordered the low base with orange welt to match my Ice Grey GSA.
  13. TommyTuenz
    TommyTuenz Adventurer
    Sep 21, 2015
    40
    Colorado Springs
    Just pre-ordered the Sargent as well, with lupin blue welt for the GSA. The stock seat has parts of my anatomy buzzing after 45 minutes or so in the saddle. I'm hoping a different density of foam will mitigate that somewhat.
  14. heatmizr
    Jan 5, 2012
    1,072
    CLT, NC
    I mounted this fr fender extension this morning. Used the 4 plastic rivets it came with, then added a 5th larger one I had sitting around.
    It is as advertised.
    Once I add the Wunderlich skid plate (if it ever ships) the combo should keep most of the crap out of that area.
  15. Horizoneyes
    Horizoneyes Adventurer
    Mar 10, 2019
    24
    Usa
    looking for suggestions on auxiliary brake light for safety / visiblilty
    thanks
  16. AdamChandler
    Feb 29, 2016
    10,192
    Hanover, NH USA
    Two primary options that are plug & play
    Denali B6 Brake Light (Requires CanSmart Module)
    Clearwater Billie (Requires CanOpener)
    There are other options out there but most require a bit of electrical knowledge. Those 2 are plug & play
    NOVA_F850GSA and Horizoneyes like this.
  17. Horizoneyes
    Mar 10, 2019
    24
    Usa
    Thanks Adam, confirms my research
  18. AdamChandler
    Feb 29, 2016
    10,192
    Hanover, NH USA
    As someone who will soon have the B6 and has the Billie now, I can't wait to post a comparison video showing the 2 in action. The strobe when braking effect both offer is great for getting people's attention.
  19. heatmizr
    Jan 5, 2012
    1,072
    CLT, NC
    Has anyone personally viewed the stock brake light action that supposedly gets extra bright when you brake hard? Does it work well?
    SnoDrtRider, have you witnessed this on your wife's bike?
  20. SnoDrtRider
    Mar 21, 2006
    7,167
    No but I will check it out... She is usually behind me and never mentioned mine modulating to different levels.
    Is this in the owner's manual? First time I have heard about it.
