F750/850GS Accessories
Discussion in 'Parallel Universe' started by apexal, Jul 12, 2019.
  1. ssilliman
    ssilliman Been here awhile Supporter
    Jul 3, 2019
    148
    Republic of Texas
    Thanks for the input
  2. mooreph2
    mooreph2 BARBENDER
    Sep 20, 2009
    32
    PARK CITY, UT AND MESQUITE, NV
    How has the seat worked out?
  3. AdamChandler
    AdamChandler Ascending n00b Supporter
    Feb 29, 2016
    7,424
    Hanover, NH USA
    Anyone with the service manual have torque specs for the chain cover? (aka Footrest Plate/Footrest Front Left)
  4. SnoDrtRider
    SnoDrtRider I've been lost here before...
    Mar 21, 2006
    6,911
    South Jersey... Close to the Pines
    A buddy of mine always puts loud "Cans" on his snowmobiles... He got a sled for his girlfriend and put a can on it. Then was always complaining that she would not go fast enough to keep up with the group...
    I told him that maybe it's so loud that she thinks she's going faster than she is so she goes slow. He put the stock exhaust back on and the next trip she was much faster.
    Some people just have a thing in their head that if something is loud it's going fast.
  5. SnoDrtRider
    Mar 21, 2006
    6,911
    AdamChandler likes this.
  6. AdamChandler
    Feb 29, 2016
    7,424
    Hanover, NH USA
    200!!! I had to get out the breaker bar to get it loose so I'm not surprised it was that hard.
    thank you!
  7. SnoDrtRider
    Mar 21, 2006
    6,911
    Take note there is a sequence!
  8. Smithee
    Smithee Head Bottle Washer
    Jul 14, 2010
    330
    Inland Northwest - Walla Walla
    I ordered Wunderlich tank protection bars from SD Moto on 4/20. They shipped on 4/23 and I received them in Washington State on May 3.
    No issues here with delays.
  9. Smithee
    Jul 14, 2010
    330
    I'm thinking seriously about the Dunlop Trailmax Mission.
    BioStrom and tarheel rider like this.
  10. SnoDrtRider
    Mar 21, 2006
    6,911
    There is loctite on the swingarm bolt...
  11. AdamChandler
    Feb 29, 2016
    7,424
    Hanover, NH USA
    Not on mine. My bolt was completely free of any thread locker. [​IMG]
    The only bolt with thread locker was a T30 button head holding the plastic fairing on above this aluminum piece. the rest had nothing .
  12. SnoDrtRider
    Mar 21, 2006
    6,911
    The manual says "Replace Bolt" (not that I ever do that for most bolts) but usually it says that because there is factory applied thread lock on the bolt.
  13. AdamChandler
    Feb 29, 2016
    7,424
    Hanover, NH USA
    Your'e right and I agree that is the norm. I feel 'replace' in this case is due to stretch that occurred when the assembly line exerted 200NM of force on it and maybe it stretched? I will be ordering a replacement and a 1/2" torque wrench that even goes to 200NM.,
  14. heatmizr
    heatmizr n00b-tastic
    Jan 5, 2012
    607
    CLT, NC
    In the car world BMW does use a lot of one-time use stretch bolts. I am assuming the same would apply here for bikes.
  15. SnoDrtRider
    Mar 21, 2006
    6,911
    BMW also said to replace rear sprocket bolts on the 800 GS when replacing the sprocket... I never did but I lived to tell about it!
  16. heatmizr
    Jan 5, 2012
    607
    CLT, NC
    They are very German about things mechanical. It's up to us to apply that proper methodology or not.
  17. mazocar
    mazocar Been here awhile
    Jan 23, 2020
    108
    NJ / NC
    The first time I took apart my triumph tbs engine to replace the starter gear I had to disassemble the whole engine and split the case. When I put it back together the bolts that connected the head to the crankcase were all bent and I was like ehhh whatever they’re going back in. at the time I had no idea what stretch bolts were... needless to say I had an oil leak and had to take it apart again. Put it back together with new bolts and Yamabond as a case gasket and it never leaked again. Yamabond is magic.
    Anyway that’s how I learned about stretch bolts. I remember those were tightened to 150lbs then tightened 90 degrees more in a sequence. 8 total bolts. Learned a lot with that bike! Adjustments.jpg
  18. heatmizr
    Jan 5, 2012
    607
    CLT, NC
    Word!
    I might not buy new ones for a luggage mount, but anything brakes- or drivetrain- related you betcha.
  19. SnoDrtRider
    Mar 21, 2006
    6,911
    A lot of modern engines use torque to yield fasteners for internal engine parts. I have a protractor from Snap on that mounts between a breaker bar and a socket to do the final 90* or whatever the specs call for. Some head gasket sets can be bought with the head bolts right in the box with the gaskets. I was turning wrenches for a living when all this stuff first came out.
  20. MCMXCIVRS
    MCMXCIVRS Long timer
    Nov 13, 2006
    1,642
    Calgary, Alberta, Canada
    Torque-to-yeild will typically have a base torque follwed by a specified number of degrees of tightening following. The base torque is usually fairly low and intended to simply ensure the fastener is fully seated. The final tightening is what applies the clamping force.
    A bolt with just a torque spec alone is very unlikely to be torque-to-yeild as it is far too hard to predict the yield point with torque alone. As noted before, most of the replace after use reccomendations made by BMW is due to their love of encapsulated thread locker on the bolts. That is really nice for factory assembly work, but in the field a good applied thread lock works just fine and will allow reuse of fasteners.
    AdamChandler and SnoDrtRider like this.
