F750/850GS Accessories
Discussion in 'Parallel Universe' started by apexal, Jul 12, 2019.
  1. tarheel rider
    tarheel rider Tight Lines Supporter
    Nov 8, 2012
    436
    Research Triangle, NC
    Looking to Mount Cyclops accessory lights to my ‘19 F850GSA . Has anyone installed them and are they plug and play? If I can’t find the answer then I will probably go with the Clearwater or Denali.
  2. mazocar
    mazocar Been here awhile
    Jan 23, 2020
    108
    NJ / NC
    I think most of us with 850s have a problem with the barkbuster type guards running into the tft. I believe that can be solved by risers.
    I was looking into some lever guards a while ago and I couldn’t find a solution so I figure I’ll eventually get some shorty levers to remedy that
  3. ab8mi
    ab8mi BMW 850 GS
    Nov 4, 2019
    29
    Boerne, TX
    If you have the Denali CanSmart or EZ HexCan module you can control almost any LED based light.
    tarheel rider likes this.
  4. ab8mi
    ab8mi BMW 850 GS
    Nov 4, 2019
    29
    Boerne, TX
    Bark Buster now makes a hand guard system specifically designed for the 850 GS, some of the generic ones would definitely hit the TFT
    mazocar and heatmizr like this.
  5. heatmizr
    heatmizr n00b-tastic
    Jan 5, 2012
    607
    CLT, NC
    Yes, I have the 850 GS specific kit, no issues whatsoever, and no riser.
    mazocar likes this.
  6. Drunk_Uncle
    Drunk_Uncle Long timer
    Dec 26, 2009
    3,615
    Boerne, TX
    Mazocar I have Touratech R1250GS Hand guard kit on my 850GSA w/ 20mm risers and no issue. Kit bolts right on.
    mazocar likes this.
  7. RSDA
    RSDA 2019 F 750 GS
    Jan 21, 2020
    37
    Maine (Canadian ex-pat)
    Installed lowered footpegs from Suburban Machinery today. Nice piece of kit. A bit bigger but not outrageous. Great grip pattern. Passed on the SW-Motech or Wunderlich offerings...I'd be fussing with them forever. A bit more vibes out on the road, though.
    From their site: "The grip surface is 2.0" lower than the factory peg with its rubber insert in place and approximately 1.25" lower than the steel grip surface." The reduced knee bend is perfect for me (34" inseam).
    Put the brake pedal at perfect height—was a bit too low previously. Will adjust the shifter tomorrow.
    (FYI—that bit cut out of the right side footpeg in the last photo is necessary to accommodate the brake pedal mounting bolt on the 1200GS. Same pegs used for this bike.)
    https://www.suburban-machinery.com/F700GS.html
    https://www.suburban-machinery.com/bmwindex.htm
    EDIT: these didn't end up putting my feet quite where I wanted. For sale. Contact me if interested.
    AdamChandler likes this.
  8. SaTaNaX
    SaTaNaX Forero Maniaco Compulsivo Supporter
    Jan 9, 2007
    66
    Murcia, Spain
  9. SaTaNaX
    Jan 9, 2007
    66
    Murcia, Spain
    Adapter Left in 3
  10. iamadventurous
    iamadventurous Adventurer
    Feb 27, 2019
    49
    Worcester, MA
    Just dropped my 750Gs bike off road and badly bent the rear brake pedal. I was wondering if anyone here who has changed their brake pedal could share the experience. There is very little room to access the screw on the body side of the bike. Just wondering whether I should attempt this myself or “leave it to a professional.”
  11. heatmizr
    Jan 5, 2012
    607
    CLT, NC
    First, get your vise grips out and just bend it back. At least so it's usable in the meantime. You may find that it still works just fine and hold off on upgrading...
  12. iamadventurous
    Feb 27, 2019
    49
    Worcester, MA
    In fact it actually works even better than before. Now I can actually use it when I am standing up off-road :) Just concerned about its structural integrity.
  13. heatmizr
    Jan 5, 2012
    607
    CLT, NC
    It's steel. It'll be fine.
  14. iamadventurous
    Feb 27, 2019
    49
    Worcester, MA
  15. tex2
    tex2 Adventurer
    Apr 1, 2016
    34
    iowa
    I have those for the 850. Very easy to install and high quality product - solid. Very impressed.
    iamadventurous likes this.
  16. Phoenix101
    Phoenix101 Long timer
    Nov 24, 2008
    3,724
    Right Side of WA
    after you get the brake pedal fixed... put one of these one https://www.chapmoto.com/drc-braker...pah6gIV3x-tBh1YwA85EAQYBSABEgJaRvD_BwE#92=151
    I think another brand is the brake snake
    AdamChandler and iamadventurous like this.
  17. iamadventurous
    Feb 27, 2019
    49
    Worcester, MA
    Good to hear. I think I will put in an order, I have bashed my bike enough already.
  18. heatmizr
    Jan 5, 2012
    607
    CLT, NC
    I have my reservations about those 'brake snakes'... They don't seem like a good idea to me.
  19. K-Ace
    K-Ace n00b
    Oct 12, 2019
    2
    New Hampshire (Seacoast)
    Wow that looks like a good product. I like how it looks and that it doesn't cover up the logo. The installation looks really good too, thanks for sharing!
  20. SnoDrtRider
    SnoDrtRider I've been lost here before...
    Mar 21, 2006
    6,911
    South Jersey... Close to the Pines
    They are actually made to keep sticks from getting jammed between the pedal and the case/frame... The do little to keep from bending the brake pedal.
