F750/850GS Accessories
Discussion in 'Parallel Universe' started by apexal, Jul 12, 2019.
  1. coldclearsea
    coldclearsea Notorious rascal
    Mar 30, 2009
    310
    Alberta
    Haha well, it’s not so much that it used a lot of tools, just in this case would have been very easy to design for fewer. For instance, the M6 bolts to connect the cross bar could have been M8s like the other connection bolts.
    Not a big deal, I’d buy the product again. Just something I always aim for in my own designs.
  2. coldclearsea
    Mar 30, 2009
    310
    Alberta
    Some Mosko Moto gear arrived yesterday. Took a bit of playing with the tank bag to get lower mounting points I was happy with but I think the end result looks pretty clean and feels rock solid on there. Just need some PPF under the straps and I’ll be good to go with that. A2225583-FE02-46B9-9A11-76D8A647C932.jpeg
    K7TNT likes this.
  3. coldclearsea
    Mar 30, 2009
    310
    Alberta
    Got the Reckless 40 too, which is still a work in progress, but will be perfect once I have it sorted. Only bummer was an incorrect buckle on one of the straps, but I’m hoping they can get the correct one sent out soon. Young company I guess so assembly QC isn’t dialed in yet, but the overall build and material quality seems excellent. 77D00995-530F-4985-8C40-A4D11EEEDDA5.jpeg
  4. okennon
    okennon Been here awhile Supporter
    May 17, 2009
    369
    Surprising and damn flat Suffolk
    Don't know about other states but Virginia vehicle inspection will not allow any obstruction ,including clear plexi over headlights or fog. I've learned to remove those items before arriving. Quick disconnects make it easier.
    coldclearsea likes this.
  5. jrm927
    jrm927 Adventurer Supporter
    Nov 11, 2019
    42
    Madison, AL
    Is there any way you could post a picture showing how you attached the straps under the front of the seat? I was going to mount mine that same way but I ended up routing the straps down and attaching them to the black frame members instead using the provided tie-wraps. After using it that way for awhile now, I've noticed that the straps rub on the inside of my legs so I'm interested in rerouting them using your approach. Definitely use the PPF underneath the straps, my paint is a little chafed where the straps have been rubbing.
  6. coldclearsea
    Mar 30, 2009
    310
    Alberta
    Sure thing, here you go. I just used a small zip tie around each tab. The supplied ones were too wide, but I think these will hold fine. Not sure what those tabs are actually for, but the bosses underneath keep the zip ties from sliding off. And the seat locks back down just fine, that was my main concern before I tried.
    PSYOP SGM likes this.
  7. PSYOP SGM
    PSYOP SGM Adventurer
    Jul 4, 2020
    57
    Alexandria VA
    That's a good idea, I may change the routing of the straps on my Tusk tank bag to match that.
  8. jrm927
    Nov 11, 2019
    42
    Madison, AL
    Thanks! That looks much cleaner than the approach I used. I'll probably re-route mine this evening and try it that way for awhile to see if I like it better. The only possible downside I foresee would be more side to side motion but it's probably irrelevant.
  9. coldclearsea
    Mar 30, 2009
    310
    Alberta
    Swapped my stock (vario style) rack for a GSA style rack, partly so my Mosko Reckless 40 would sit a bit farther back and not hang over the pillion seat, and partly so I can mount a top case without a bunch of extraneous hardware. Everything will get a good shakedown next weekend, going through the Rockies down to Vancouver Island for a bit.
    Edit: for anyone that’s curious, the torque for the 4 M8 mounting bolts is 23 N•m. They had some loctite on them from the factory and breakout torque was about 25 N•m.
  10. sfsmedic
    sfsmedic Been here awhile
    Jun 3, 2019
    143
    Southern California
    I have an 850GSA. I’m getting ready to mount some aux lights and looking for location ideas. Anyone whose done it in an 850 adventure I would like to see where you mounted them and how you like them. Thanks.
  11. K7TNT
    K7TNT Been here awhile
    Nov 20, 2007
    623
    N.E. Wyoming
    Just home form the MOA rally. Loving my set up on this bike. 58EDF6FA-B38C-4E89-9C6A-0A7CE275E81D.jpeg
  12. Drunk_Uncle
    Drunk_Uncle Long timer
    Dec 26, 2009
    3,890
    Boerne, TX
    I bought the Wunderlich upper bar and mounted them there to be safe from tip overs.
    coldclearsea and AdamChandler like this.
  13. coldclearsea
    Mar 30, 2009
    310
    Alberta
    For anyone curious how the Mosko Moto Reckless 40 sits on our bikes, here’s a shot from my weekend excursion. I’ve got the provided heat shield on there, but it’s not even needed. Nothing on the system comes close to the exhaust.
    Of note, you do really need to set this up on the rear rack rather than the pillion seat on this particular bike. The front attachments sit far enough forward that if you had it on the pillion seat, there would really be no practical forward mounting point. Which for me is fine, I wanted it on the rack anyway, but something to be aware of. C4372E76-B1DE-437A-BD83-9ED4EAF854A8.jpeg
  14. PSYOP SGM
    Jul 4, 2020
    57
    Alexandria VA
    I finally got around to installing my SV-Motech crash bars. Super easy install. Motech crash bar.jpeg
  15. Drunk_Uncle
    Dec 26, 2009
    3,890
    Boerne, TX
    So this story isn’t about a K8x, but K7x. The part is also available for K8x. I can’t say enough about @BlackDogCycleWorks products. I have their sump guard on both my 800GSA and 850GSA. Did some serious off road riding in Big Bend this weekend. I didn’t think it was possible, but I put a good size dent in it. Lesser guards could have resulted in a very large wrecker bill and large repair bill.
    SnowGS and BlackDogCycleWorks like this.
  16. heatmizr
    heatmizr n00b-tastic
    Jan 5, 2012
    1,072
    CLT, NC
    And no pic?
    Always wanted to go to Big Bend. Maybe one year I can catch the MotoGP race in Austin and rent a bike for a few days.
  17. Drunk_Uncle
    Dec 26, 2009
    3,890
    Boerne, TX
    K7TNT and coldclearsea like this.
  18. BlackDogCycleWorks
    BlackDogCycleWorks Long timer Super Supporter
    Oct 28, 2014
    1,126
    Sandpoint, ID & Mulege, Baja
    Thanks for the shout-out and hearing about our plate keeping you going after a hit. Working as intended :D
    Thanks again for choosing one of our skid plates!
    -Black Dog Cycle Works
    www.blackdogcw.com
    Scott in Missouri likes this.
  19. marc11
    marc11 Long timer
    Nov 5, 2009
    1,373
    New York
    Too bad you don't answer emails when existing customers have questions about your products....would have resulted in additional sales and praise.
    I will say the skid plate on my 850GSA is as advertised. Strong and easy to remove for oil changes.
  20. BlackDogCycleWorks
    Oct 28, 2014
    1,126
    We try to be diligent about getting back to any emails that come in but we might have missed yours. Our apologies!
    Can you send me a copy of the email and when you originally sent it via PM? It sounds like you may have figured everything out but we'd like to make sure that email isn't going to spam or something. Also, for future needs, you can always call us at (208) 263-4400. It should ring us regardless of where in the US or Baja we might be. Leave a message and we'll give you a callback.
    Again, we apologize for missing your email.
    www.blackdogcw.com
    GSmotomind and Scott in Missouri like this.
