F750/850GS Accessories
Discussion in 'Parallel Universe' started by apexal, Jul 12, 2019.
  1. Pch123
    Pch123 Bar Crossings
    Dec 19, 2012
    1,747
    East Coast Australia
  2. Pipeman
    Pipeman Been here awhile Supporter
    Jul 5, 2010
    463
    North Central Pa.
    Installed Dominator link pipe, nice weight savings and sounds great ! 20 minutes to install .
    AdamChandler likes this.
  3. heatmizr
    heatmizr n00b-tastic
    Jan 5, 2012
    1,072
    CLT, NC
    That bend looks a little better than the Remus...
    What kind of footpegs are those? They look interesting.
  4. Pch123
    Dec 19, 2012
    1,747
    Not sure if you realise , you can buy rubber inserts for Pivot Pegs if the steel cutter look worries you. Personally not an issue for me, but for those who do worry about sharp edges.........
    AdamChandler and slackline like this.
  5. apexal
    apexal Long timer
    Nov 7, 2010
    1,054
    Dover, NH
    I followed that link already and wrote an email as instructed. They wrote back and said that I could lower the pegs by swapping location of the spacer. That's the only option that they gave me. I just wrote again asking if your proposal would work on my 850 and how to do it.
    In the mean time, any chance that you could provide photos and/or details, like what you mean by mounts and collars? Thanks.
  6. apexal
    apexal Long timer
    Nov 7, 2010
    1,054
    Dover, NH
    I used to race enduros and hare scrambles long ago and one of the first mods we did was to get out a file and sharpen the teeth on our foot pegs. Rubber pegs might be okay for the street but get some mud on those things and you'll wish for teeth. Sharp teeth.
  7. Pipeman
    Jul 5, 2010
    463
    North Central Pa.
    SW Motech EVO Adjustable
  8. Duitser
    Duitser Been here awhile
    Jun 1, 2019
    164
    South Africa
    Would there be a link pipe available for the 700?
  9. Horizoneyes
    Horizoneyes Adventurer
    Mar 10, 2019
    24
    Usa
    When you flipped the Nav mount, does it eliminate the horrible glare when the sun is behind your back? I'm looking at spending $130 for the mount from Motorrad in Dresden mentioned in the first post in this thread, but if flipping allows the screen to be seen in bright light, i'm in
  10. Horizoneyes
    Mar 10, 2019
    24
    Usa
    I'm about to purchase this mount. Are you very happy with it and does it eliminate the horrible glare that you get when it's in the original factory mount? Have you seen any other mounts that you would consider? ...such as this one? https://www.aliexpress.com/item/33042315385.html?spm=2114.12057483.0.0.16434593VETtpE or
    https://www.mv-motorrad.de/en/MV+GPS+Holder+for+BMW+F750GS+for+original+BMW+GPS+devices.htm
    Also trying to decide between the rox riser you got or their 2" Pivot riser. I have the 2019 750 low and I'm 5'5"
    Thanks for all your info!!
  11. slackline
    slackline Been here awhile
    Dec 1, 2009
    298
    Inland PNW
    For those of you looking to buy the mount from Dresden, my buddy fabricates one identical to it for way cheaper. @ForefrontFabrication is his inmate name on here. Based out of Spokane, WA area.
    ETA: It is what I have on mine.
  12. heatmizr
    Jan 5, 2012
    1,072
    CLT, NC
    I doubt it, it really only moves it an inch or two, did not change the angle.
    I too want that Motorrad mount, that will be my final solution.
  13. heatmizr
    Jan 5, 2012
    1,072
    CLT, NC
    Perhaps he could post some pics of his work?
    I would be happy to see some similar solutions that are hand made, and reasonably priced.
  14. Phoenix101
    Phoenix101 Long timer
    Nov 24, 2008
    4,398
    Right Side of WA
    besides BMW or MCMXCIVRS... anyone know of a good source for a 34mm wrench that would easily pack on the bike?
  15. SnoDrtRider
    SnoDrtRider I've been lost here before...
    Mar 21, 2006
    7,183
    South Jersey... Close to the Pines
    No matter where you mount the GPS it will always have some glare depending on sun angle but the more upright you can get the screen the less glare.
    I made this mount and wish I had made it wider because the lock cylinder hits the arm preventing me from being able to rotate the GPS any more.
    The only glare I get is what you see here unless the sun is directly on the screen which only happens for about an hour a day when the sun is at that certain angle.
    Horizoneyes likes this.
  16. apexal
    apexal Long timer
    Nov 7, 2010
    1,054
    Dover, NH
    Hi Al,
    The PP-60MK3 Pivot Pegz can only be lowered by 7mm and it is achieved by moving the spacer.
    The members on the forum are referring to other Pivot Pegz for some other bikes such as KTM, Honda, Yamaha which get lowered by swapping and flipping the mounts to the other side of the bike. They do not have spacers and so they need to swap the mounts over... this is not applicable to the PP-60MK3 BMW Pivot Pegz.
    Hope this helps to answer your questions.
    Kind Regards,
    James
    PIVOT PEGZ SUPPORT
    Phoenix101 likes this.
  17. Pch123
    Dec 19, 2012
    1,747
    I have 60 MK3 on my 1200 Gs and they are swapped and mounts flipped over. Did it myself.
  18. burangs
    burangs Javenturer
    Jul 28, 2015
    120
    Columbia, SC USA
    Just a heads up...
    I bought the Hornig Nav Mount based on previous experience with one on my R1200RS. Simple enough piece and well made, but it does NOT work well on the GSA because of the screen adjustment lever. It only allows enough rotation for full extension and about 2/3 lowered, causing a great deal of turbulence in the lower setting. I was considering modding the lever, but rather, I think I’ll look at a different design. It will fit a GS —no problem.
  19. slackline
    Dec 1, 2009
    298
    Inland PNW
    That's the mount he made me, first version. He's since made it better for others on advrider. I have full range of motion on the windscreen. No interference. Solid mount that eliminates vibration.
    jmcarter and Horizoneyes like this.
  20. apexal
    apexal Long timer
    Nov 7, 2010
    1,054
    Dover, NH
    Show me photos and I will believe it. And please tell me what "mounts" are. Third time I asked. I know that you are trying to be helpful but am I supposed to disbelieve the manufacturer? If you have something contrary to what PP says why don't you give them the info so they can share it?
