F800gs - Almost perfect except for poor suspension.
Discussion in 'Parallel Universe' started by mac444, Oct 22, 2008.
  1. Snowy
    Snowy Long timer
    Dec 2, 2008
    2,562
    Thanks, I'm just doing some sums. The Showas cartridge top section has the external thread and an internal thread. I doubt there's enough metal there to start cutting any off the outside.
    It's only half a mm, but, there's only a couple of mm in it. Then there's the machining of the axle clamps.
    I was just explaining it to my father, a retired machinist, and he says stop stuffing around and buy a KTM...or a 4x4...or some new walking boots. I think he's just cranky that I woke him at midday.
    I always wondered why I left it so long between phone calls...
  2. Gangplank
    Gangplank Advenchaintourer
    Jul 20, 2003
    2,316
    Las Vegas
    What about machining the stock top cap to fit the showa adjusters? I have my old fork internals & top caps around here somewhere of ya need an extra set.
  3. Bayner
    Bayner Long timer
    Mar 27, 2008
    2,366
    Penticton, BC, Canada
    I finally blew the valving in one of the Bitubo inserts. :cry
    I decided to throw the original cartridges back in to finish out the season (using the stronger springs from Bitubo). As I was pumping the rod to bleed the air out on assembly it occurred to me that it feels like there is no compression dampening at all in the stock cartridges. There is however noticeable drag on rebound. I was thinking I was going to at least find the opposite when I did the other fork leg, but nope, same thing. So I'm just wondering if anyone else noticed this.
    Seems to me that having no extra compression resistance from valving and a soft original spring it's no surprise so many are having success with just about anything they throw into the front forks....
  4. johngil
    johngil Reseda, CA
    Jun 28, 2007
    3,817
    May not be worth the $$$ for you, but I have a shop in CA that can get the Bitubos rebuilt and even re-valved if that's what you want.
  5. bxr140
    bxr140 Flame Bait
    Jan 25, 2007
    1,041
    On high
    While your damper may or may not be representative of the as-designed characteristics, it's typical that rebound takes significantly more force than compression, in part because compression is helped by the spring and rebound is working against the spring.
    I recall pretty minimal pumping force on compression when I had my dampers out, though not enough to think it way out of the ordinary.
  6. Bayner
    Bayner Long timer
    Mar 27, 2008
    2,366
    Thanks johngil. May as well post that up so it's in the thread in case anyone else decides to do the same. I'm going to swap in some alternate shiver internals and try that route. I'll tear down the Bitubos just to see what failed at some point... I'm betting a snapped valve disc and maybe a broken top-out spring by the way it sounded.
  7. johngil
    johngil Reseda, CA
    Jun 28, 2007
    3,817
    I thought I had really broke my Bitubos beyond repair. It wasn't pretty.
    The guys at Catalyst Reaction didn't blink an eye and even made their own tooling to re-charge the cartridges.
    http://www.catalystsuspension.com/
    Ask for Tige or James.
  8. MTrider16
    MTrider16 Ridin' in MT
    Oct 16, 2006
    1,870
    Eastern Montana
    Well Kids, It looks like I need to write a retraction. After pounding around the CDT following some moto's and then trying to find jeep tracks in the Custer National Forest and in the Bighorn Mountians with the Mobius gang, I have about 2500 miles on the Ohlins Nix kits with rear shock. They have done very well at keeping the pig in line over some rough trails, as well as pounding out some pavement connecting sections. I'll give them a thumbs up even with the $2100 price tag for the fronts and rear.
    David
  9. Singletrack_mind
    Singletrack_mind Cave Man
    Aug 29, 2008
    498
    Northern New Mexico
    Here's a question that's un-related to this otherwise interesting fork discussion:
    I have a 2009 with 45K miles on it. I had Trail Tricks do the front and Race Tech re-valved and serviced the rear last spring. The Trail tricks fork mod was a very subtle improvement, the Race Tech shock re-valve & straight-rate spring was a bigger improvement, but neither end is perfect. now, in fact, something's gone actually wrong & I can't find the problem.
    Something related to the rear wheel gives a jarring clunk through the seat and frame over certain bumps. This has been going on for a month or so, perhaps getting more pronounced with time. It is hard to induce reliably, but the ride up my dirt road road or certain speed bumps makes it obvious. There is no sound that I have noticed associated with it. I have checked wheel bearings, swing arm bearings & shock mounts, found no play. I removed the seat and cover and inspected the upper mount which has been know to bend and break. No problem there. I adjusted the chain. In case I was wrong about it being in the rear, I checked headset bearings and fork bushings too. Center stand and side stand seem the same as always, and this thunk seems much too solid for a bouncing centerstand anyway. I took my Jessie bags completely off, and removed the tool kit from under the seat in case it was knocking around. Seat seems the same as ever, a little play in the back, but this is a hard thunk, like bottoming the suspension. I have checked that preload and rebound are still where I set them. There is oil visible where the inner and outer shock jackets slide over eachother, but no oil dribbling off the bottom of the shock, hence no real leak. Bouncing the front or rear of the bike at a stand-still does not produce the thunk. Rebound damping still seems to be functional. I talked to Race Tech and they said there isn’t really anything that could change inside the shock (although I know internals can and do break; witness Johngil's shim stack, above).
    So has anyone had an experience like this, and if so, what was it?
  10. Indy Unlimited
    Indy Unlimited Long timer
    Jan 21, 2007
    1,941
    Parker, CO
    Hey Singletrack mind,
    I suspect your bearings are shot in the upper and/or lower mount of the shock. This crates a clunk since the bearing now has play and the shock may be fine.
  11. Singletrack_mind
    Aug 29, 2008
    498
    Northern New Mexico
    Indy, I'd like to believe you and suspected something like this initially, but I'm pretty sure that'd show up as vertical play. With the bike on the center stand and the wheel in the air I'd expect to be able to feel that when tugging upward on the wheel or swingarm, but I can't, there's no apparent slop there.
    At some point I'll pull the shock to have my local shop strip & inspect the internals, that'll be the moment to give the upper and lower eyes a real close look.
  12. Indy Unlimited
    Jan 21, 2007
    1,941
    Parker, CO
    Okay but very strange to see that it is in the internal shock. Let us know the final verdict.
  13. mxz
    mxz Been here awhile
    Sep 11, 2015
    756
    The simplest solution is usually the right one. Uhh, have you tried wiggling the brake rotor (or disc as we call them in Europe) with your hand to see if it has play? Back and forth and side to side? F800s have full floating rotors that tend to change over time in terms of loseness and start to introduce play. The pins that hold the rotor can become a bit loose and upon impact the rotor hits the mount and clunks. Some brand new (like mine) have a metallic clunk both front and rear straight outta factory! It's a bit annoying really.
  14. Singletrack_mind
    Aug 29, 2008
    498
    Northern New Mexico
    Indy was right. The top shock eye was badly ovallized. Actually more like a bow-tie profile, if you imagined the bore in a longitudinal section view. I believe this was caused by the bending of the top mount bolt. When I re-fit the shock after RaceTech re-built it, I fit a new straight bolt, but the original one had bent, and now, the new bolt has bent at least as badly. Time to re-engineer what BMW hath wrought.
    I am thinking the reason I could not detect this at the rear wheel with the bike on the centerstand was that there was enough lateral pressure from the bolt to bind the shock eye end to end so my feeble efforts to raise the wheel and feel for some slop were not enough to shift the eye on the bolt. Going down the road it knocked horribly though. I hadn't ridden the bike in a while due to snow & ice on the driveway, but when the truck starter failed I needed to get the bike out and was shocked (ha) how bad it had gotten. Ride it every day and you slowly get used to problems. Take a break from riding and experience the problem fresh and it can be surprising what you were putting up with.
  15. Barakaiki
    Barakaiki Been here awhile
    Sep 21, 2012
    653
    Fascinating thread.... even now, 8 years later
  16. Barakaiki
    Sep 21, 2012
    653
    8 yrs later and I'm feeling these woes on my F800GSA
    Sent from my iPad using Tapatalk
  17. Merlin32
    Merlin32 Been here awhile
    Nov 9, 2014
    763
    North East US
    Just keep in the weight specs and the suspension is fine. I e 160 lb rider if you have 30 lbs gear lol. I'm 195 and the suspension is ok. Could be better but I'd rather wait to blow something out then I'd address it. Yea if yr 240 it's going to present an issue....
  18. Trekka273
    Trekka273 Been here awhile
    Jul 7, 2011
    224
    Sunbury, Victoria, Australia
    It isn't hard to upgrade your suspension..... It also isn't cheap, but when done it completely transforms the bike.
    Barakaiki likes this.
  19. Barakaiki
    Sep 21, 2012
    653
    Operative word: COMPLETELY.
    So true. I feel like I have a new bike on road and off. It's funny how you don't realize what you've been missing until you have it done. Balanced chassis = more traction, smoother inputs, confidence.
    Merlin32 likes this.
  20. Barakaiki
    Sep 21, 2012
    653
    And I would add that one shouldn't get caught up in the hype of adjustable suspension. Sometimes it's more work than it's worth, because of the whack a mole nature of changing and evaluating change. Get a good suspension tuner to create a nice damping curve through good Spring rates and valving and be done with the fiddling, IMHO
