F800GS Front Fender Failure Caused Catastrophic Crash
Discussion in 'Parallel Universe' started by Lost Roadie, Mar 10, 2011.
Thread Status:
Not open for further replies.
  1. Dorzok
    Dorzok Long timer
    Jun 10, 2008
    6,361
    SoCal
    When'd you change your screen name?
  2. Singletrack_mind
    Singletrack_mind Cave Man
    Aug 29, 2008
    498
    Northern New Mexico
    My experience this past Thursday was not as dramatic as the story that started this thread because I was barely going 5mph at the time. I was doing my damnedest to get moving faster, but I was sunk in some amazingly sticky red clay East of Chinle, AZ. The fender was packing with mud and I was resisting the proper solution, which would have been to remove the fender and the right-hand brake caliper. I had to do that soon enough as it turned out.
    The fender cracked straight across the top, on a line from one fork tube to the other. The forward half of the fender was pulled ahead by the mud and partially ripped off it's lower mounts. Interestingly, the rear half of the fender stayed more or less in place and was not pushed forward.
    It was not that difficult to free the cross-over hose from the fender stays & strap the caliper onto the windshield and headlight mounts so it hung just in front of the turn signal. One of the orange DOT reflectors off the fork guard on the fender made a perfect brake pad spacer, I wrapped zip-ties around it to make sure it stayed in place. I was running a Pirelli MT21 and found I could actually make forward progress in the mud with that fender removed.
    The mud brought us all to a stop and killed three clutches, we spent the night in the woods but that's a story for the ride report elsewhere. I rode 300 miles home with the single brake and am beginning the project of fender elimination and brake line re-routing. I'll post the results when I'm done sometime this winter. Meantime I'll replace the OEM fender and stay out of the mud. (anyone got a used one to sell me? PM me if so . . .)
  3. SpadedAce
    SpadedAce Injun!
    Sep 19, 2011
    14
    Tampa FL
    Chitown -- very sorry to hear about your crash, and what happened to both you and GS, but also very glad you shared it with us.
    I'm just wondering, would it be more advisable to change to a dual cable for the front brake lines or to put the high-fender on? Or Both? Seems like both would be overkill, but what's a few hundred clams when your life is at stake?
    Thoughts?
  4. yen_kofu
    yen_kofu n00b
    Mar 7, 2010
    6
    the video "F800GS Front Fender Failure Caused Catastrophic Crash "
    Good to Put On my YouTube Channel !
    May l ?<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:eek:ffice:eek:ffice" /><o:p></o:p>
  5. selaznog
    selaznog Roadless Warrior
    Aug 11, 2007
    3,749
    Santa Fe
    Lost Rider,
    Can you please give us a review of your single brake system? Any changes to the brake system other than simply removing the other side and excess plumbing? I removed one side from a 950ADV I used to have and I never missed the extra braking power. After seeing your experience I'm hoping to do the same for my 800. Thanks.
    selaznog
  6. LukasM
    LukasM Long timer
    Nov 15, 2006
    5,511
    On a RTW ride - currently touring the U.S.
    The F800GS uses the same calipers and the same size discs as the 950 Adv. If you liked it on that bike that's even slightly heavier, it wouldn't be any different on the F800.
  7. Phil J
    Phil J Dirty Guy
    Dec 24, 2007
    6
    Burlingame, CA
    The exact same thing happened to me in Black Rock Desert in 2009. While riding on the playa fully loaded at about 40mph my front fender clogged up with mud and exploded, then the cross-over brake line caught on TKC-80 knobby tread and I did a header although I had a somewhat softer landing than you had. Looking up at the sky after the get-off I'm thinking, "What the f... happened".
    BMW knows about the problem with the poor fender/break line design and will do nothing about it. I'm just wondering if a rider has been killed due to this poor design. I would definately put in my $.02 in on a lawsuit. I have lots of pictuers documenting my event.
    Sign me "Pissed".
  8. _cy_
    _cy_ Long timer
    Sep 25, 2011
    6,845
    Tulsa, Oklahoma
    unreal... more F800GS problems
  9. Flashback
    Flashback Mommys Lil Monster
    Jul 6, 2007
    3,233
    Hawai'i Island
    YAH. That fender is a problem. BMW knows. I've been procrastinating on doing anything with mine...but I should, plus the current fender is unsprung and dead weight on the tire.
    I'm guessing that it's one of those things for BMW -> costs less to ignore it than to fix it. Plus, BMW is careful about ensuring that the fine print for this bike that they don't call it a dual sport. It's a street bike by their own documentation. I doubt that legal action would go anywhere short of there being an actual death -> otherwise this problem would have been fixed a long time ago.
  10. JoelWisman
    JoelWisman Long timer
    Apr 22, 2009
    1,392
    STL, MO, USA
    If the fact that it is possible to have something on a motorcycle break and cause a crash was grounds for a judgement, there wouldn't be any Harleys on the road. They can't brake or turn and it causes crashes all the time.
    Rather then wait to become a statistic, I would rectify the weakness my self and reroute your brake line.
  11. _cy_
    _cy_ Long timer
    Sep 25, 2011
    6,845
    Tulsa, Oklahoma
    true da... my 73 HD FX Superglide came with defective rear brakes. first year for disc brakes on HD and it showed. rear brake caliper would drag against disc, get red hot, boil brake fluid.. NO brakes.
    it was an acknowledged problem, but HD never issued recall of any kind for the piece of shit rear disc brakes.
  12. Durden
    Durden Freak!
    Aug 12, 2005
    477
    Calgary, Alberta
    I'll accept a front fender exploding if it gets jammed with mud (thats the consequence of a low profile front fender), but the low cross over brake line in my opinion is just plain scary.
  13. albany23
    albany23 Aficionado
    Jun 29, 2010
    77
    Constanta, ROMANIA
    Just in to say Hi to my man Chitown!! Hi,Finn !! Big fan, you'll get me in a lot of 'trouble' with the missus, you know, riding bikes and farkling and missing suppers!!! Keep riding and stay free!!
    Btw, EVERY TIME i ride my F800 on a rocky road, the split second i reach about 50kph your video pops in my brain!! Scary stuff, i instantly do a two second check-up of my gear, state of tyres, ALWAYS check my front fender and beake lines. You sure scared the living crap out of many of us!!
    Two wheels down,
    Mihai from Romania
    " 'cause tramps like us,
    Baby, we were born to run. "
  14. albany23
    albany23 Aficionado
    Jun 29, 2010
    77
    Constanta, ROMANIA
    Hey guys,
    Any word on Finn? I tried to enter lostrider.com, (i have in my bookmark bar, for crying out loud), and it's password portected. Anything going on i don't know about? Help with some info....
    Thanks,
    Mihai
  15. Motorfiets
    Motorfiets Long timer
    Oct 1, 2007
    2,981
    Southern California
    he's gone AWOL
  16. Hucker
    Hucker Lost
    Dec 3, 2009
    696
    Southern AZ
    Riding the piss out of his bike...
    Site is password protected because he sold out of his kit (or so I heard...). Glad I got mine while the getting was good.:deal
    BTW - he'll be back with some kick ass RR. :evil And I can't wait for it!
    He's inspired the inner-farkler in all of us. My wife HATES him.:lol3
  17. señormoto
    señormoto Supermoto Abuser
    Jul 10, 2007
    1,110
    California + Costa Rica
    All I get on http://lostrider.com is a domain parking page - not a password protected / authentication (401) required page.
    oooh. correction: http://[B]www[/B].lostrider.com has a 401 page: which means his DNS is setup incorrectly. Usually you'd have the * A record set to the same as the www A record, or just * as the main A record which www would answer to. Really, who actually uses the www distinction anymore anyway?
    But yeah, he's busy. Not a big deal.
  18. woody's wheel works
    woody's wheel works Built to Last Super Supporter
    Jun 24, 2004
    3,576
    39*40'33.86N 104*59'54.69W
    FYI,,for those of you wondering what he's doing....
    just in today...a progress report...
    ''Hey Woody,
    Just wanted to share a couple images, I'm putting your wheels to good use. Matter of fact I'm trying real hard to break them and am unsuccessful.
    Feel free to use any of my photos as you please.
    Thanks again. ''
    Finn
    The rest are here:
    https://lostrider.smugmug.com/Motorcy...3609&k=Xv3GN7h
    looks like he's busy,,,i told him to beat the s--- out of em,,,,lordy, he's really taking me seriously:wink:
    attaboy finn...
  19. Durden
    Durden Freak!
    Aug 12, 2005
    477
    Calgary, Alberta
    ^^^ WOW! Very impressing climbing on a bike that heavy and fully loaded - props! Sweet mods to the F8, its looking good.
  20. Pariahtize
    Pariahtize Misrepresented
    Jul 15, 2009
    1,888
    Northern Front Range, CO
    Damn. . . i'm all freaked out now about my low fender and TKC80 on my 950A. . . :eek1 hevn't heard of this problem before, but it's hard to forget your recorded crash!!
    So glad to hear that everyhting has turned out well for you! Progressive took very good care of me on one of my accidents.
Thread Status:
