F800GS Instrument Cluster
Discussion in 'Australia' started by Oldtom, Apr 25, 2015.
  1. stoz
    stoz Adventurer
    Oct 10, 2009
    10
    Queensland Australia
    Thanks for the tip on removing the needles it worked a treat.
    #21
  2. filterfool
    filterfool n00b
    Apr 5, 2009
    1
    Hi. I noticed your posting (above) on fixing your instrument cluster. I am having the same problem on my 2007 R1200R.
    Would you please send me the information on the capacitor you replaced? That is, a description suficient for me to purchase one.
    Also, if you have any additonal pictures of how you acomplished the repair, would you please sned them to me?
    I am mechanically suficent to chaneg oil etc., but iI am hesitant about working on the cluster. I do have a soldering iron.
    Thanks for any help ypu can give me.
    filterfool aka Steve
    #22
  3. SamZone
    SamZone n00b
    Dec 11, 2008
    2
    This posting was a good resource for me too. I have successfully repaired my cluster board with the help of a great old school electronics tech, however, the stepper motor for the tachometer was damaged in the process and now seems dead. When I pulled the needle off using the two spoons method, the shaft came out of the motor. That is not supposed to happen. I now have a problem finding a replacement motor with these markings. I'm going to post a photo in the hopes that someone will see this who can help. Once the part is sourced, the replacement should be easy because it is attached with four soldered pins.
    #23
  4. WayneC
    WayneC Long timer
    Oct 3, 2008
    5,271
    Sydney, Australia
    SamZone
    The stepper motors are common to many dash assemblies on EU cars & Bikes, the F800 one is the same as the F650GS single 2000-2009, Juken/Switec, note the change from X15 to X25 stepper on the later year models, current compatible unit is X27-288 Juken stepper motor Code: SEI-X27-288
    F650GS Single Stepper Motor Markings
    151)322.0 x15*288 ... 151}22.0 x15 288 ... 133>02.4 x15 288 ... 085}19.0 x15 288 ... 086>14.4 x15 288 ... 131>36*8 x25 288 ... 133}43*8 x25 288 ... 143}43*8 x25 288
    They are available from the supplier below
    https://www.mte.net/catalog/speedometer-parts
    #24
  5. Happy Snapper
    Happy Snapper GOMOB.
    Feb 14, 2009
    3,932
    Brisbane, almost heaven!
    Slowly, gently and with much feeling... twist the pointer off.
    Did it for years repairing VDO, Smiths and Start Warner Instruments.
    #25
  6. thomaslmc
    thomaslmc n00b
    May 19, 2020
    1
    Melbourne, Australia
    Hello,
    I am looking for replacement lcd display but have no idea where to get them from. Wreckers are quoting $250 for the whole instrument cluster. Was wondering if anyone knows a source. Much appreciated!
    #26
