f800gs rim locks
Discussion in 'Parallel Universe' started by tmex, Nov 18, 2008.
  1. tmex
    tmex Long timer
    Apr 20, 2006
    2,039
    NorCal
    Going to mount TKC80's next week. What are folks doing about rim locks?
  2. spoof
    spoof on backwards
    Oct 21, 2003
    315
    Santa Fe, NM
    For TKCs?!?
    How low are you planning to go?
    Jimmy Lewis said on the GS Trophy thread that they ran Karoos at 20-25 in Tunisian sand dunes. Not exactly true knobbies, he acknowledged. But no need for rim locks at those pressures either.
    I bow to you if you are going to get so burly with the 800 as to need rim locks.
    :bow
  3. tmex
    tmex Long timer
    Apr 20, 2006
    2,039
    NorCal
    I just was not sure if 20 was a high enough pressure to not be concerned. The rim is not drilled for them , so apparently BMW agrees with you. Thanks.
  4. tmex
    tmex Long timer
    Apr 20, 2006
    2,039
    NorCal
    double post - not my doing...
  5. johngil
    johngil Reseda, CA
    Jun 28, 2007
    3,817
    I don't know where you could find a rim lock for the rear rim. It's wide enough for a truck.
    I guess you could go old school w/ some sheet metal screws.
  6. tmex
    tmex Long timer
    Apr 20, 2006
    2,039
    NorCal
    Indeed :1drinkhence the post. I think I'll follow Spoof's advice on this one.
  7. Bayner
    Bayner Long timer
    Mar 27, 2008
    2,409
    Penticton, BC, Canada
    I'm using the screw method on my KTM, worked out fine so far. Easier to change tubes/tires also with no internal lock.
  8. johngil
    johngil Reseda, CA
    Jun 28, 2007
    3,817
    I was going to saw that bitch off myself!
    More beer fixed the problem (eventually).
    #8
  9. tmex
    tmex Long timer
    Apr 20, 2006
    2,039
    NorCal
    I was afraid of that. Thanks for the warning. Good thing I have lots of beer and no close neighbors.
    #9
