F800gs ROX Risers. Question
Discussion in 'Parallel Universe' started by Danny L., Aug 18, 2019.
  1. Danny L.
    Danny L. Adventurer
    Apr 8, 2019
    10
    Cincinnati
    I am attempting to install ROX risers on my f800gs and I’m finding it extremely difficult to the a grip on the stock clamp screws (torx) that hold the base of the ROX risers. I can’t get them tight enough to hold the bars securely. Any tricks?
  2. Rider 101
    Rider 101 Time poor
    Feb 8, 2012
    3,320
    Avoiding the coal holes Upper Hunter NSW
    Because there is bugger all clearance between the riser and the clamps I found it best to roll the risers forward and that gives better access to the rear screw. If you try to have the risers central you won't be able to get a torx key to fit in.
  3. KILR0Y
    KILR0Y Was here...
    Jul 8, 2016
    163
    What he said, plus tighten the rear first with bars rotated forward. Then push the bars back & tighten the front.
  4. Danny L.
    Danny L. Adventurer
    Apr 8, 2019
    10
    Cincinnati
    Thanks for the replies! That is what I was doing, but I was just curious if anyone had found a better solution.
  5. Paulie M
    Paulie M Been here awhile
    Sep 14, 2012
    101
    St Albert, Alberta, Canada
    Change the bolts out to some Allen head bolts from your local nut ant bolt shop. That shout solve the issue.
  6. bnc1
    bnc1 Adventurer
    Feb 12, 2015
    40
    And then shorten the short leg of your Allen wrench to about 5/8" long.
  7. bnc1
    bnc1 Adventurer
    Feb 12, 2015
    40
    Also, if you find your brake line is a bit tight with the Rox Riser....
