F800GS Tire Change/Brake Caliper Question
Discussion in 'Parallel Universe' started by rockinrog, Mar 3, 2009.
  1. rockinrog
    rockinrog Long timer
    Mar 5, 2008
    3,852
    Central PA
    I was wondering if anyone else has had this problem. The manual shows the securing screws of the right hand caliper are supposed to be torx but what I have on mine is different..forgive me if I have the termonology wrong but the pictures will tell the tale.
    http://farm4.static.flickr.com/3549/3327250332_fc6cbe8042_o.jpg
    What is on my GS:
    http://farm4.static.flickr.com/3583/3327250058_152fc179b3_o.jpg
    It wouldn't be a big deal, but I have the torx that is supposed to be on there but not the socket for what is actually on there.
    Can someone tell me what its called and/or what size it is so I can go buy one.
  2. tmex
    tmex Long timer
    Apr 20, 2006
    2,039
    NorCal
    My caliper bolts are exactly like yours - they are Torx but male instead of female. I prefer what you and I have since they are much easier to drill for safety wire.
  3. rockinrog
    Mar 5, 2008
    3,852
    Central PA
    Glad to know I am not special. I am just glad my first tire change was in the garage and not on the road as BMW supplies the regular torx in the tool kit. I needed a E-12 External torx socket.
  4. Bucko
    Bucko In a parallel world
    Mar 20, 2004
    831
    South Coast, CA
    The F800GS tool kit sucks donkey dong. Don't go beyond the county line until you put together your own set. There's a thread on what you need here: http://www.advrider.com/forums/showthread.php?t=392198 If that link is hosed (my first attempt), check the Hall of Wisdom Sticky in Beasts.
  5. jessehere
    jessehere Ridin'
    Apr 6, 2005
    879
    Jersey(EXIT 10)
    fyi, those fancy male tork heads seem to work fine with a regular socket for me. ymmv
  6. kkug
    kkug Been here awhile
    Feb 9, 2004
    981
    Escondido Ca .USA
    If you have Harbor Freight Tools in your area they have both sets of Torx Sockets.
  7. tmex
    tmex Long timer
    Apr 20, 2006
    2,039
    NorCal
    Torx fasteners are getting very common. I have purchased Torx tools from Home Depot, Lowe's, All Parts Auto Store, and Ace Hardware. Even the cheapy combo tool sets these days usually have a set of Torx Allen style drivers in the mix. The Torx shape is much more robust than the hex shape, and the fasteners are much less prone to rounding edges.
    I would even expect Torx fasteners to start appearing on KTM's someday.
  8. jessehere
    jessehere Ridin'
    Apr 6, 2005
    879
    Jersey(EXIT 10)
    :lol3
    I bet you need them to tighten up those funky gooogles too:lol3
    #8
  9. tmex
    tmex Long timer
    Apr 20, 2006
    2,039
    NorCal
    No. The goggles are ingenious - there are no hinges, no fasteners, and they do not hurt your ears or the bridge of your nose. They are supported by your head which was designed for that purpose.
    I have no idea why they did not catch on. Probably because they are a bitch to stick in your pocket. and they do not look cool when you prop them on your forehead (to look cool) like you do with ordinary sunglasses. At least I have never sat on them.
    #9
  10. johngil
    johngil Reseda, CA
    Jun 28, 2007
    3,817
    My '08 KTM had torx/hex combos on practically every fastener.
    #10
  11. Dert Gerl
    Dert Gerl Been here awhile
    Aug 30, 2007
    205
    Prescott, AZ
    You don't need to take the calipers off to change your tire.
    I just put a big ole honkin knobby on the front last weekend and there is enough flex to allow you to pass the tread thru w/o removing either caliper even with the tire aired up and ready to go.
    Any yes, the newer KTM's are already torx. Makes it nice to set up a tool pack for both ...
    #11
  12. ]I)Money
    ]I)Money D NOT I Supporter
    Mar 8, 2006
    4,029
    Central central.
    You are 100% correct.
    #12
  13. mdski
    mdski Adventurer
    Feb 26, 2009
    42
    WDC
    +1
    If you still have space issues, just remove the two small torx screws that secure the front fender to the lower fork and rotate the caliper away from the wheel. You only need to do one side. That worked for me.
    But to answer your question- yes, mine looks like that too.
    #13
  14. tmex
    tmex Long timer
    Apr 20, 2006
    2,039
    NorCal
    I am just curious why removing the two fender screws is percieved to be easier than removing the two caliper bolts? It is pretty common on dual rotor front brake bikes to pull the calipers for wheel changes so when I looked at it initially I actually concluded (incorrectly) that the calipers had to come off for a wheel change. The manual supported that impression so I just did it. It is extremely simple. Why fight it? Is it a torque issue?
    #14
  15. Dert Gerl
    Aug 30, 2007
    205
    Prescott, AZ
    You don't have to take either out. The fender is the only thing that keeps the bottom of the fork legs from spinning freely. That fender also has quite a bit of flex to it. When you're ready to take the tire through the calipers just roll the wheel right up to them to were the tread hangs up, grab hold of the calipers or fork legs and pull them away from the tread and roll the tire thru. Super easy. Not that taking the calipers off is difficult, but coming from the dirt bike world I thought it strange that I had to take so much stuff off ... so I didn't. You don't need much pressure to move the calipers apart far enough to get the tire through ... it's plastic.
    The end result was a tire change that was easier than dirt bike tires!
    #15
  16. tmex
    tmex Long timer
    Apr 20, 2006
    2,039
    NorCal
    Thx DG. Good description. I'll try that next time.
    #16
  17. Dert Gerl
    Aug 30, 2007
    205
    Prescott, AZ
    My mind set was that of fixing a flat on the side of a trail and taking the path of least resistance to get rolling again ... or that I'm just lazy! :D
    #17
  18. mdski
    mdski Adventurer
    Feb 26, 2009
    42
    WDC
    Just giving an option for those of us without the proper tools. I didn't have the tool to remove the caliper, but did for the fender. I've never had the need for the torx type sockets that the GS has.
    Next time I'll put more muscle into spreading the calipers apart without removing anything. I was being a wuss and didn't want to scratch my pretty new bike.........yet :wink:
    #18
