F800GS Toolkit needs
Discussion in 'Parallel Universe' started by itsatdm, Oct 4, 2008.
  1. Pilotuh1b
    Pilotuh1b Been here awhile
    Apr 13, 2014
    305
    ACT
    Some handlebar clamp bolts were etorx but they were changed to torx in later years I think. Or if your bike is modded.
    The only ones I think I’ve come across.
    Oh, some caliper bolts maybe? Somewhere down on the front wheel but not for wheel removal from memory.
    KTM Deano likes this.
  2. KTM Deano
    KTM Deano Adventurer
    Aug 12, 2013
    84
    Okay thanks yes that' what had me puzzled. My handlebar clamps are torx, so just wanted to double check in case I was missing something. Thanks for replying
  3. KTM Deano
    Aug 12, 2013
    84
  4. El Pacifico
    El Pacifico Long timer
    Jan 17, 2012
    1,237
    Hood River, Oregon
    2011 F800GS. I've been using the same oil filter removal tool for a while. The last time I changed the filter, the tool would not "bite" the filter enough for me to unscrew it. It was a pain but I eventually was able to remove the filter and install a new one. What tool is out there nowadays? Links would be appreciated. Thanks!
  5. Reaver
    Reaver How Did I Get Here?
    Aug 7, 2008
    19,125
    Zona Sur Costa Rica
    Dozens of different brands of oil filters, dozens of shapes, dozens of tools available. Take a new filter of whatever brand it is to a Auto or Harbor Freight store.
    El Pacifico likes this.
  6. A319
    A319 n00b
    Apr 29, 2020
    8
    Denver
    My Axles seem to be 17mm/24mm as well, but my Owner Manual states differently (see pic). Did they change these mid-year? I have an F800GS Adventure-recently purchased, and am putting together my kit.
  7. The Maz
    The Maz Clueless and lost
    Feb 14, 2013
    488
    Medicine Hat , AB
    Those figures are the size of the bolt and thread pitch.
    M16x1.5 is the size of the threads on the axle.
    You will need a 24mm socket to fit the nut that goes on the axle.
    Motoriley and A319 like this.
  8. A319
    A319 n00b
    Apr 29, 2020
    8
    Denver
  9. mustardfj40
    mustardfj40 Been here awhile
    Apr 27, 2012
    231
    Siicon Valley, California
    There're at least 2 versions of the bead breaker: An lighter (9.6 oz) shorter 11" aluminium version and heavier (2lbs) steel and longer 16" version. Which one you guys get? I like the lighter version but concern that it does have enough leverage to pop a Mitas E07 tire. Thx
  10. B_C_Ries
    B_C_Ries Long timer
    Mar 15, 2013
    11,385
    Imperial Valley, California
    I carry the aluminum ones and they have always worked. I like them so much I bought the steel ones and have those in my garage. That being said, with the rear tire they don't always just pop the bead, I often need to use them 4-5 times in an area of the tire before I get the bead to release. Still I haven't found any better way to get the job done with a tool I feel like carrying.
  11. NEEnduroRider
    NEEnduroRider Adventurer
    Nov 26, 2016
    12
    I carry the motion pro bead breakers work fine for the E07/e07+
  12. Bali Davo
    Bali Davo Been here awhile
    Mar 31, 2017
    115
    Allen heads strip out too easy , I much prefer the torx
  13. Moto Mikey
    Moto Mikey Been here awhile
    Jun 28, 2008
    507
    Cambridge, UK
    I'm in the process of entirely redoing my toolkit. Looking to make it as light and compact as possible while still being fully functional.
    What does everyone recommend for socket and bit drive size? 1/4" or 3/8"?
  14. B_C_Ries
    B_C_Ries Long timer
    Mar 15, 2013
    11,385
    I went with 3/8" mainly because of the rear wheel nut. I use a Craftsman 15/16" socket because it fits perfectly and is a 6 point. I was unable to find a 3/8" drive 24mm in 6 point. I also carry a flex head breaker bar instead of a ratchet because there is very fine dust where I ride. I had a ratchets stop working because of the dust finding its way into the ratchet gears, and have seen ratchet break gears because the mechanisms were not fully engaging as a result of dust and oil collecting in the gears. (this probably won't happen if you disassemble and clean your ratchets once in awhile like I do now, still the flex head breaker bars a kind of foolproof and I like to stick a small pipe on the end for extra leverage on the back axle nut) In over 40 years of riding I've repaired flat tires more often than every other type of road/trailside repair combined.
  15. B_C_Ries
    B_C_Ries Long timer
    Mar 15, 2013
    11,385
    Check it out T40, T45, T50 and T55
  16. JRWooden
    JRWooden Homeless motorcycle vagabond ... and ... loving it
    Jul 5, 2008
    6,380
    The great state of confusion
    Damit... I wasn't thinking I bought a set of "standard" 1/4" / 3/8" sq. drive...
    :doh the bits would be much more compact....
  17. B_C_Ries
    B_C_Ries Long timer
    Mar 15, 2013
    11,385
    I didn't know these ones existed until I saw them, they are 10mm drive hex bits. Previously I just carried a 3/8" drive T45. I'll probably never need a T50 or T55 on the side of the road but these bits pack a lot smaller than the common style ones. So having them just in case is no big deal.
    JRWooden likes this.
  18. JRWooden
    Jul 5, 2008
    6,380
    What brand/where did you purchase?
    Do they seem to be good quality steel, or have you had any reason to "exercise them" yet ;-)
  19. B_C_Ries
    B_C_Ries Long timer
    Mar 15, 2013
    11,385
    It was part of a 40 piece Chinese set on E bay. I always test Chinese tools as soon as I get them and these seem solid. The 10mm drive 4 mm hex and T20 look kind of silly. I'm happy with price and the parts of the kit I intend to actually use.
  20. B_C_Ries
    B_C_Ries Long timer
    Mar 15, 2013
    11,385
    I can remove my oil drainplug now
