1. Livestream NOW at 11AM PST / 2PM EST!
    Baldy Interviews + Noraly "Itchy Boots" from Youtube YouTube Live Chat here
    Dismiss Notice
F800GS Valve Adjusting step by step.
Discussion in 'Parallel Universe' started by Camel ADV, Sep 26, 2010.
  1. beeper
    beeper Badger tickler
    Sep 2, 2009
    823
    Wisconsin
    I reused the gasket with some fresh black RTV where the original sealant was, no problems.
  2. Bayner
    Bayner Long timer
    Mar 27, 2008
    2,372
    Penticton, BC, Canada
    Yeah, you just want to get off what you can without damaging the gasket. It's not as hard as you may think.
    Canada Mike likes this.
  3. Canada Mike
    Canada Mike Been here awhile
    Oct 16, 2009
    470
    Langley BC
    I have had good success with a old piece of windscreen. It's sharp and will clean off the excess without damaging the mating surfaces.
  4. tofire409
    tofire409 Geared up and ready.
    Sep 6, 2009
    898
    Toronto, CDN
    Thanks for all of the reply's!
    I did end up with both gaskets and 4 bolts in the kit when I did it last time, and they are the post leak version.
    I've used the fake credit cards that come in the mail to scrape the sealant off...good to know that there are some that have had success in reusing the gasket and bolts.
  5. Canada Mike
    Oct 16, 2009
    470
    Langley BC
    Credit cards is a really good idea as well.
  6. antonyp
    antonyp Adventurer
    Oct 25, 2008
    42
    Cyprus
    Yes. If all else fails you could use it to buy a new set of parts - LOL !
    Sent from my SM-G800F using Tapatalk
  7. ontrip
    ontrip Been here awhile
    Aug 14, 2011
    814
    Toronto, Ontario
    My tech convinced me to spend the $125 for the gasket set. Motorrad Shop in Aurora, Ontario.
  8. Canada Mike
    Oct 16, 2009
    470
    Langley BC
    Dido. Not worth the time to take it all apart again if it leaks.
  9. Reaver
    Reaver How Did I Get Here?
    Aug 7, 2008
    18,792
    Zona Sur Costa Rica
    Working at the Dealer, checking hundreds of bikes, we didn't replace the gaskets on valve covers that were on top like the F bikes (unless it was the old design of course). The Flying Bricks with the side mounted covers, always.
  10. Canada Mike
    Oct 16, 2009
    470
    Langley BC
    Good to know!
  11. Loutre
    Loutre Cosmopolitan Adv Super Moderator
    Nov 28, 2010
    13,452
    :o)
    haven't replaced my side gaskets in 7x valve checking. I'm cheap and I check 'em 4x a year. at 20 bucks that gasket that oil change + valve clearance would get expensive :lol3. anyhow still not leaking to this day (knock wood)
  12. Reaver
    Aug 7, 2008
    18,792
    Zona Sur Costa Rica
    You have a Pregnant Elephant, not a Flying Brick.
    The Airheads and Oilheads and Hexheads don't get changed till they're old and brittle.
    JVB will tellya.
  13. Canada Mike
    Oct 16, 2009
    470
    Langley BC
    So what's your secret to ensure the gasket and surfaces are free of oil? Alchohol?
  14. Indy Unlimited
    Indy Unlimited Long timer
    Jan 21, 2007
    1,942
    Parker, CO
    Permatex Ultra Black is my secret weapon. Have done three times now and never leaked.
  15. Loutre
    Nov 28, 2010
    13,452
    :o)
    clean them with chain cleaner, rub it dry and call it a day. no issues on my boxer so far.
  16. Reaver
    Aug 7, 2008
    18,792
    Zona Sur Costa Rica
    Yes, alcohol works for me.
    foogr01 and Canada Mike like this.
  17. Canada Mike
    Oct 16, 2009
    470
    Langley BC
    I knew I should have been more specific when I saw you lingering.
    Reaver likes this.
  18. Singletrack_mind
    Singletrack_mind Cave Man
    Aug 29, 2008
    498
    Northern New Mexico
    Just as a data point, I just checked my valves again at 50K miles on a 2009 F800GS, and am pleased to report no change since I checked at 35K. Over the life of the bike, all the intakes have remained at .20mm. The exhaust valves on the #1 cylinder have stayed at .30mm, but the exhaust valves on the #2 cylinder had loosened to .35mm between 24K and 35K miles. That was why I got in there to check them again at 50K, I wanted to make sure they hadn't moved any further, and they haven't.
    I changed the valve cover gasket the first time I went in there, but it leaked just as badly after as it had done since new so the next two times I didn't bother. Over-all this is about the only complaint I have about the engine; for a modern machine it weeps A LOT of oil both at the valve cover gasket and around the back of the left side cover. Cleaning the RTV off the old valve cover gasket is not hard, but doing a good job cleaning the sealing surface on the head is a really tedious process what with poor access and making sure you don't drop any little bits of RTV down the cam chain tunnel.
    DainBramaged, Canada Mike and beeper like this.
  19. Motoriley
    Motoriley Still riding like crap after all these years.
    Feb 14, 2003
    2,975
    Deepest darkest burbs of Montreal
    A little video of my valve adjustment experience. Not really a complete how to but some insight may be there.
  20. Flopix
    Flopix Been here awhile
    Aug 27, 2016
    101
