F850GS accessory power
Discussion in 'Parallel Universe' started by Yossarian™, Oct 23, 2021.
  1. Yossarian™
    Yossarian™ Deputy Cultural Attaché
    Jul 9, 2007
    13,452
    the 'Ha
    I'll be on a rental F850GS in February, and would like to know if it has a 12V accessory power port. I am assuming that it's a 2020 or newer.
    If so, what type (DIN/Powerlet, etc.) and where is it located?
    Thanks in advance for your responses!
  2. marc11
    marc11 Long timer
    Nov 5, 2009
    1,447
    New York
    If 2021 then yes, on the left dash side is a din style plug and on the right dash is a USB socket. Prior to 2021 I think you only had a single din style socket on the right side of the dash.
    Yossarian™ likes this.
  3. FredRydr
    FredRydr Danger: Keep Back 300 Ft.
    Aug 16, 2005
    4,481
    Carlisle Pennsylvania USA
    But be prepared for CANbus to shut down the circuit if it determines there's too much power draw. That's why many owners rewire the accessory socket via a fused cable directly to the battery.
  4. Yossarian™
    Jul 9, 2007
    13,452
    the 'Ha
    I am going to plug a GPS into it, so should be good. Thanks, guys, for the information.
  5. Drunk_Uncle
    Drunk_Uncle Long timer
    Dec 26, 2009
    3,950
    Boerne, TX
    I have run my phone on that port on my 2019 without issue.
  6. Yossarian™
    Jul 9, 2007
    13,452
    the 'Ha
    Follow-up question if anyone is still reading.
    How does one access the battery on this bike? I may consider hooking up a power line directly to run a heated jacket. Any gotchas in doing so?
    GSmotomind likes this.
  7. MCMXCIVRS
    MCMXCIVRS Long timer
    Nov 13, 2006
    1,787
    Calgary, Alberta, Canada
    Battery is easy to get to, just remove the seat.
    marc11, GSmotomind and Yossarian™ like this.
  8. marc11
    marc11 Long timer
    Nov 5, 2009
    1,447
    New York
    Yep as stated under the seat, nothing special to be concerned with directly connecting a heated jacket to the battery.
    #8
