Farkle-GARAGE, list 'em all
Discussion in 'Parallel World (790/890)' started by a.c.e., Jan 12, 2020.
  1. a.c.e.
    a.c.e. U Mud, Bro?
    Nov 20, 2018
    533
    Germany
    Got the brainfart to do a list of all I did to my 790R, so why not make it public.
    Will keep my "Umm... just a few bucks" list together and help if something has to be replaced.
    Might update from time to time.
    [sarcasm]For sure I'm totally NOT interested in your list, might get tempted to spend even more bucks.[/sarcasm]
    So feel free to try me...
    I'll start of with some pics and what I did from front to rear, what's still to get and what... well, maybe.
    • Decals: Scrubdesignz x-rut (customized) + mid forks
    • Nav-Mount: SW-motech (modded) + iBracket 60412993300
    • Mirrors: KTM 60312040100 + distance brackets (forward)
    • Handguards: Acerbis X-Factory
    • Levers: AliXpress 33029762393
    • Brake cover: KTM 64113903000
    • Bar riser: KTM 7890193934430
    • Crap Flap: Sweetlamb (ebay)
    • Seat: KTM 63507941000EB
    • Clutch arm: Camel ADV 1-finger
    • Clutch cover: KTM 63512967044
    • Footpegs: Rade Garage large&low
    • Spiked Brake paddle: AliXpress 33063139762
    • Kickstand enlarger: AliXpress 4000138588076
    • Muffler: Wings slip-on
    • Tyres: Bridgestone AX41
    • Rear Sprocket: KTM 5841005104504
    • Fancy Spoke Tubes (to find the nipples fast): Motea SPX
    • Rear Bag (daily): KTM 60012978000
    • Luggage: Enduristan Blizzard + QBag dry roll
    To come:
    • Skid plate: R/G or AXP
    • Battery: JMT HJTZ14S-FP-SI
    • Radiator cover: KTM 63535040000EB
    maybe Baby:
    • 15T Pinion: 58033029115
    • TripleClamp HeadStraight
    • Raximoto Levers
    • Haan Wheels
    leekdesign, OhDuh, KevinBB and 5 others like this.
  2. Kinkysmurf
    Kinkysmurf Adventurer
    Oct 24, 2019
    97
    Deua River
    " Fancy Spoke Tubes (to find the nipples fast): Motea SPX"
    Kinky likes this.
    You got a good bike going on. The best bang for buck ( like the germany brothels eh, bus loads of Austrians over the border every night)
    Sorry kinky went off again.:viking
    The best bang for buck. 15T front, cheap, do it yourself if you have a rattlegun and torque wench and adjust the chain back.
    Next consider a ATZ-10 battery or other brand, that 2.5kg gone from next to your balls ( easy kinky) makes a huge difference in feel when you toss into a corner ( Im talking dirt) even feels better just pushing it around the shed.
    And this is why I dont let kinky do forums, except pornhub. He has his own channel.
    KevinBB, 1coolbanana, nibby and 3 others like this.
  3. a.c.e.
    a.c.e. U Mud, Bro?
    Nov 20, 2018
    533
    Germany
    @Kinkysmurf Thanks for the reminder on the battery, totally forgot about that heavy bit...
    15T might happen sooner than later, just no high need here, I don't go slow very much ;)
    I'll add the battery and the TCM head straight for now.
    C'mon mates, ignore the price tags to prevent excessive madness (you or your wifey :linzi) and show your list.
    I'd like to get some more ideas of what to change or add over the winter time.
    :drif
  4. ramirin
    ramirin Ready to push
    Mar 25, 2008
    1,192
    FIN
    Just as an thought, I already have 15T front but decided to go 48T rear instead to keep front tight in case chain snaps.
    Or to be honest I'm not going that fast (my philosophy: if you dare to go over 90km/h you're on too big road) so I might even go 15+48 but then I look to add some material on front sprocket guard to keep it tight.
    And the one you could add is: https://www.vanaschemotorsports.com/store/p82/790_Billet_Case_Saver.html
    a.c.e. likes this.
  5. braaap!
    braaap! Long timer Supporter
    Mar 16, 2005
    5,371
    Melbourne - AU
    VEREX decat link pipe and open aftermarket exhaust... Aural bliss. Think I may have said this before ;)
    Raximo shorty levers are the biz’
    RG screen not so much...
    Pivotpegz for me:)
    @Camel ADV exhaust shield and clutch arm, bueno!
    TCM headstraight is on its way :)
    PP +20mm seat, bueno!
    TCM + Scott’s damper kit... Molto bene!
    Motoz Knobbies ++
    15T countershaft sprocket on back order....
    More time to ride, not that good for now (bloody werk).
    KTM WA Rally booking slot tomorrow hopefully!!
  6. a.c.e.
    a.c.e. U Mud, Bro?
    Nov 20, 2018
    533
    Germany
    @ramirin Thx, that billet case saver looks dope and makes sense.
    By "not going slow" I mean those really tight first gear clutch slipping slow things,
    as long as I'm not forced to go below 20 km/h I'm fine with switching gears.
    ramirin likes this.
  7. Kinkysmurf
    Oct 24, 2019
    97
    Deua River
    Yes the Vanasche looks like it would do its job, the OEM plastic will do very little I think. The chain is chewing out inside of the cover with the 16T OEM damper sprocket. Since removing the plastic cover, chain guard and mounting a UNdamper sprocket the horrible chain chatter on a rocky downhill is gone.
    Chain failure is very rare with with basic maintenance, especially now with rivet link chains standard. Stops guys F,kn around with circlips when they have little experience.
    90km is a bit slow for here, we have big wide deserts to cross, and 170km is my top speed, The knobs wont take much more.
    Edit. For anyone interested KTM have a upgrade to fix the countershaft leaks.
    I think its only on warranties not a recall, The fix is a Steel Nut to replace the Alloy nut. Torque can then be increased to 120N from 100N.
    This puts more pressure on the o-ring.
    I also saw in Repair manual ( checking Newtons) that the Plastic cover is a wear item like the sliders.
    Sorry Ace I went off topic a bit.
    1coolbanana and braaap! like this.
  8. ramirin
    Mar 25, 2008
    1,192
    FIN
    I've come suspicious with chain as my 690 snapped chain with only 2000kms or so .. there were many of similar cases back then, something wrong with the chain. I was lucky and it just dropped on ground in front of my garage.
    I used to ride fast. With 990 gauge was 180km/h and rpm going still up as it started to lose traction on gravel against wind force. I realized my luck is going to end at some point and removed windshield, that dropped to max 140km/h -> wen't to 690 bouncing on knobbies max 120km/h..
    Of course I sometimes ride faster but try to find roads where I can have fun riding slower. The one thing I don't understand is the people who look for curvy roads and then cut corners.
    I would love to try those deserts, we mostly have narrow curvy trails and wide straight roads.
    #8
    hubilado likes this.
  9. Kinkysmurf
    Oct 24, 2019
    97
    Deua River
    And some bastards dont even send a sticker.
    Shout out to Wings for including a T Shirt, only one.
    I don't do stickers. But do like Alongat's Tripleclampmoto grapic art.
    #9
    1coolbanana, braaap! and nibby like this.
  10. a.c.e.
    a.c.e. U Mud, Bro?
    Nov 20, 2018
    533
    Germany
    That's an interesting way to do the list - Jeopardy-style :D
    #10
  11. braaap!
    Mar 16, 2005
    5,371
    Melbourne - AU
    @Kinkysmurf thanks for the heads up!
    Had mine looked at, at first service and all good but a couple of hundred Kms later I see the tell tale dribble again (I know that feeling)... Happen to have a P/No for the steel CS Nut?... :thumb
    #11
  12. Kinkysmurf
    Oct 24, 2019
    97
    Deua River
    #12
    braaap! likes this.
  13. 1coolbanana
    1coolbanana Long timer
    Aug 25, 2009
    6,828
    NW Sydney, Australia
    Has the steel nut replaced the alloy nut? (I havent looked yet)
    All the 9XX and 1X90 had steel.
    #13
  14. Kinkysmurf
    Oct 24, 2019
    97
    Deua River
    If you go in for warranty with a leak, you get the new nut ( I was told by KTM)
    If its not leaking, dont worry. Your not missing out. Im trying to leave this alone here, because its ACE's thread.
    #14
    1coolbanana likes this.
  15. a.c.e.
    a.c.e. U Mud, Bro?
    Nov 20, 2018
    533
    Germany
    Nah it's for everyone!
    But a steel nut is a pretty short list ;)
    #15
  16. fiascoj
    fiascoj Adventurer
    Jul 29, 2014
    31
    SF
    Those 1*90 mirrors look so much better than stock 790advR round mirrors! @a.c.e. , where did you get the distance brackets?
    #16
  17. a.c.e.
    a.c.e. U Mud, Bro?
    Nov 20, 2018
    533
    Germany
    #17
    fiascoj likes this.
  18. ramirin
    Mar 25, 2008
    1,192
    FIN
    Ok, to complement @a.c.e. idea of listing - here's where I'm now
    - 2,5x18 / 1,85x21 Haan&Excel with Mitas C-18 and C-21
    - WP xplor pro @270mm
    - PP high seat
    - Clean front from wires and Exc mask turning with handlebar
    - Exc handlebar + exc grips
    - Clake two (hydraulic clutch & left hand rear brake)
    - Pivot pegs
    - Vanasche sprocket guard
    - 15/48 gearing
    - Single front brake & disable abs
    - Wings muffler & Arrow decat
    - PCV
    - AXP skid
    - 640 mudflap
    - My blood and tears =)
    Ripped apart at the moment, no idea if it's going to be a motorcycle ever again :lol3
    More in https://advrider.com/f/threads/790-adv-r-xc.1420846/
    #18
  19. fiascoj
    fiascoj Adventurer
    Jul 29, 2014
    31
    SF
    #19
  20. windblown101
    windblown101 Long timer Supporter
    May 17, 2010
    8,134
    Star Tannery, VA
    My 790R is pretty basic but the farkle/mods still adds up quickly it seems. Luckily I had a lot of this stuff on the shelf already from other bikes so the shell shock was reduced a fair amount deal.
    KTM Stuff:
    KTM Handlebar clamp GPS mount Part #64112992033
    KTM Heated Grips #64112964044
    KTM Cruise Control Switch #76011270100
    KTM XC-F handlebar #7900200100030
    KTM 15T (-1 tooth) Damped front sprocket #58033029115
    KTM branded foam air filter #63506915000
    KTM Branded Cycra Probend handguards
    KTM QS+ disable option
    Aftermarket Accessories
    Enduro Engineering Skidplate #24-1319
    Bosley foot pegs -20mm https://www.facebook.com/Bosleys-Pegs-1329344163774808/
    Rottweiler Quick Flip mirror mounts w/CRG mirrors
    TripleClampMoto stabilizer mount w/Scotts damper
    Perun rear rack
    TDM Rear chain guide (Not installed yet)
    Misc
    Homemade soft luggage standoff for left side of bike.
    Luggage options depending on what I'm doing that fit and work well:
    Wolfman Enduro Tankbag
    Wolfman Daytripper saddle bags
    Mosko Reckless 80 saddlebags
    Kreiga 10 liter tail bag
    On the wish/experiment list still:
    Tall seat
    47 tooth rear sprocket
    Single front caliper conversion
    #20
    Perun, ramirin, 1coolbanana and 2 others like this.
