Fastway footpegs on the GS1200
Discussion in 'GS Boxers' started by kirkmoon, Oct 3, 2004.
  1. GSDonovan
    GSDonovan There and back again
    Mar 1, 2007
    900
    East Greenwich, RI
    The spacers just adjust the angle of the footpeg relative to the bike which affects how it points your knees in towards the tank. I didn't use any of the spacers and the footpegs are nice and level like the stock pegs.
  2. Longer
    Longer Been here awhile
    Jul 20, 2007
    168
    Ottawa, CANADA
    Gotcha on the angle but I just don't understand why these two particular washer/spacers are a larger diameter than the m6 bolt and the rest of the supplied spacers (in the baggie).
    Just seems odd to me...
  3. Flyboy08
    Flyboy08 Been here awhile
    Mar 16, 2007
    932
    NYC..no dirt here!
    I like mine as well...so much so that I have scraped them:lol3
  4. BMW Kurt
    BMW Kurt Philosopher
    Jul 23, 2006
    15,611
    Democratic Republic of the Disunited States
    I put these two spacers on top of the collars and ran the pin with the circlip through them. Funny, but on mine I had to use all of the washers to get my pegs level using the camber system :dunno
  5. Longer
    Jul 20, 2007
    168
    Ottawa, CANADA
    I was thinking that these might be used for spacing with the collars but wasn't 100%...I really should have gone down to the bike first before posting. As I tell the other techs that I work with: "look with your eyes and not with your mouth". I guess I should take my own advice!
    Thanks for the help guys, I can't wait to scrape mine too!
    Longer
  6. m0to
    m0to Under the Big Hard Sun
    Sep 19, 2006
    369
    San Diego, CA
  7. hapbob
    hapbob Been here awhile
    Nov 19, 2006
    789
    Thumb of Michigan
    Got mine Today... Back orderd for 4 weeks... for those looking to buy them. Went on OK one collor was a bittch to get in......I tried to press it in with my bench vice....Vice now stripped/broken! The coller is in enough to fit on the bike but still not in flush. I fiddled with return springs for 20 minutes then decided to run in the house and check this thread for a picture...then I put them on in 2 minutes with the help of photos here. Great resource no doubt. 5 degrees right now so will have to wait to try em out...
  8. VON STRIDER
    VON STRIDER CHICKEN LICKIN' GOOD
    Sep 4, 2008
    8
    MUSKY BONE, MI (WEST MITTEN COAST)
    Does anybody know of a manufacture of fat &/or swivel foot pegs for a '89 R100GS. Something similar to Fastways or comparables.
  9. jwd98056
    jwd98056 Been here awhile
    Dec 23, 2006
    111
    Renton, WA
    According to this thread on the Airhead Beemers Club, Fastway Evolution IIs will fit the R100. The model number is 22-2-403.
  10. tallguy-09
    tallguy-09 Smile 4 Miles
    Aug 6, 2009
    1,440
    Vancouver
    I have them in the lowest position, had to lower the shifter via the linkeage adjustment procedure a little bit downward. Before I couldn't switch to 2. gear and had trouble with 1st (had to lift my boots of the pegs. That's a problem only if you have size 14 boots and very long legs (37" inseam here).
  11. turnerm
    turnerm Long timer
    May 5, 2008
    1,030
    Treasure Coast, FL
    I installed my Fastways today and I had the same issue with regards to shimming the right and left. The left side required more shims to level the peg. The right side didn't need any at first, but after leveling the left, I may add a thin shim.
  12. JimVonBaden
    Feb 11, 2005
    90,968
    Alexandria, VA
    WAY to much Loctite. It only needs one small drop to hold.
  13. mung
    mung Long timer
    Apr 18, 2008
    1,113
    Idaho
    Those screws do not need any loctite.Have had those pegs on my dirt bikes for a long time and they have not even loosened with no thread sealant.When it is time to replace the screws the ends will be very worn and will be much easier to replace if there is no locking compound on them.
  14. JimVonBaden
    Feb 11, 2005
    90,968
    Alexandria, VA
    Probably true, just following the installation instructions.
    https://www.promotobillet.com/files/p-17831/footpegs/evo_instructions_web.pdf
  15. turnerm
    turnerm Long timer
    May 5, 2008
    1,030
    Treasure Coast, FL
    Got mine installed today and I love them.
  16. JimVonBaden
    Feb 11, 2005
    90,968
    Alexandria, VA
    Wow, like art!:deal
  17. Travman
    Travman Long timer Supporter
    Aug 19, 2010
    1,036
    Marietta, GA
    In stalled the new Adventure pegs on my GSAW. Took about 30min or so and most of that was playing with the various shims. My thanks to Turnerm for the hint on different leveling shims needed on each side. I mounted these very slightly raised. The right side was a little tougher getting the spring right and by the pics you can see that the left has no interference with the kickstand. I mounted these in the low position but even there, they are only about a 1/4" lower than the stock pegs. Leaving for a 4-day trip on Friday so will get some quality time with them but they feel like I'll be able to move my feet around much more than on the stocks.
  18. abrasive
    abrasive Been here awhile
    Aug 17, 2008
    244
    UT
    Looks good. :clap. About to install a set of those myself, on a GSAW.
  19. bracky72
    bracky72 Long timer
    Feb 22, 2011
    1,069
    Charles Town, West Virginia
    I've had the adventure footpegs for a while now. I think you will really like them. They get in the way a slight bit when your feet are on the ground but it's a small price to pay for their awesome size.
  20. Ronh21
    Ronh21 Adventurer
    Nov 25, 2012
    24
    Berryville, VA
    Just a quick threadjack. What size is the torx bolt holding that shifter on?
